具体程序如下,大家帮忙看看指导一下,在此谢谢了
// Generated Initialization File //
#include "C8051F330.h"
#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define n_max 120 //采样点个数
#define Lcd_Bus P1
***it RS=P0^5;
***it RW=P0^6;
***it E=P0^7;
***it PSB=P0^0;
***it RST=P0^2;
uchar xdata smp[n_max];
uchar xdata lvbo[80] ;
uint result;
uint n;
void DrawPoint(uchar X,uchar Y,uchar Color);
void ceshi();
void clrscreen();
unsigned int AdResult, n;
// Peripheral specific initialization functions,
// Called from the Init_Device() function
void PCA_Init()
PCA0MD &= ~0x40;
PCA0MD = 0x00;
void Timer_Init()
TMOD = 0x01;
TL0 = 0x0C;
TH0 = 0x10;
void ADC_Init()
AMX0P = 0x03;
AMX0N = 0x11;
ADC0CN = 0x81;
void Port_IO_Init()
P0MDIN = 0xF7;
P0SKIP = 0xED;
P1SKIP = 0xFF;
XBR1 = 0x40;
void Oscillator_Init()
OSCICN = 0x83;
void Interrupts_Init()
IE = 0x82;
EIE1 = 0x08;
// Initialization function for device,
// Call Init_Device() from your main program
void Init_Device(void)
PCA_Init();
Timer_Init();
ADC_Init();
Port_IO_Init();
Oscillator_Init();
Interrupts_Init();
void Time0_Interrupt() interrupt 1 //定时器0 的中断 中断优先级为1
TR0 = 0;
TL0 = 0x0c;
TH0 = 0x10;
TR0 = 1;
void ADC0_Interrupt() interrupt 10 //ADC的中断,中断优先级为10
EIE1 = 0x00;
AD0INT = 0;
AdResult = ADC0H * 256 + ADC0L;
ceshi();
clrscreen();
DrawPoint(56, 55,1);
DrawPoint(57, 55,1);
DrawPoint(58, 55,1);
DrawPoint(59, 55,1);
DrawPoint((n % 128), (result / 20),1);
n++;
EIE1 = 0x08;
/*------------------检查忙位-----------------------------*/
void chk_busy()
RS=0 ;
RW=1 ;
E=1 ;
Lcd_Bus=0xff ;
while((Lcd_Bus&0x80)==0x80);
E=0 ;
/*------------------延时子程序-----------------------------*/
void delay(unsigned int t)
unsigned int i,j ;
for(i=0;i
for(j=0;j<10;j++);
/*------------------写命令到LCD------------------------------*/
void write_com(unsigned char cmdcode)
chk_busy();
RS=0 ;
RW=0 ;
E=1 ;
Lcd_Bus=cmdcode ;
_nop_();
_nop_();
_nop_();
delay(5);
//------------------在数据写入的时候加入适当的延时
E=0 ;
delay(5);
/*-------------------写数据到LCD----------------------------*/
void write_data(unsigned char Dispdata)
chk_busy();
RS=1 ;
RW=0 ;
E=1 ;
Lcd_Bus=Dispdata ;
_nop_();
_nop_();
_nop_();
delay(5);
E=0 ;
delay(5);
/*------------------初始化LCD屏--------------------------*/
void lcdreset()
delay(10);
PSB = 1;
RST = 1;
delay(10); //并口方式
RST = 0; //液晶复位
delay(10);
RST = 1;
delay(5);
write_com(0x30);
delay(50);
//选择基本指令集
write_com(0x30);
//选择8bit数据流
delay(20);
write_com(0x01);
//清除显示,并且设定地址指针为00H
delay(50);
write_com(0x06);
//指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位
delay(5);
write_com(0x0c);
//开显示(无游标、不反白)
delay(10);
/*------------------显示字符串--------------------------*/
void hzkdis(unsigned char code*s)
while(*s>0)
write_data(*s);
s++;
delay(50);
/*------------------首屏显示--------------------------*/
void ceshi()
write_com(0x01);
//清除显示,并且设定地址指针为00H
delay(50);
write_com(0x80);
//第一行(如果是地址是:80H,即LCD的第一行的第一个位置显示)
hzkdis("东大");
write_com(0x90);
//第二行(如果是地址是:90H,即LCD的第二行的第一个位置显示)
hzkdis("08班的");
write_com(0x88);
//第三行(如果是地址是:88H,即LCD的第二行的第一个位置显示)
hzkdis("心电");
write_com(0x98);
//第四行(如果是地址是:98H,即LCD的第二行的第一个位置显示)
hzkdis("波形");
//------------------清整个GDRAM空间----------------------------
void clrgdram()
unsigned char x,y ;
for(y=0;y<64;y++)
for(x=0;x<16;x++)
write_com(0x34);
write_com(y+0x80);
//行地址
write_com(x+0x80);
//列地址
write_com(0x30);
write_data(0x00);
write_data(0x00);
void clrscreen()
write_com(0x01);
_nop_();
_nop_();
_nop_();
delay(10);
uchar ReadByte(void)
unsigned char byReturnValue ;
chk_busy();
Lcd_Bus=0xff ;
RS=1 ;
RW=1 ;
E=0 ;
E=1 ;
byReturnValue=Lcd_Bus ;
E=0 ;
return byReturnValue ;
//增加画点子程序
uchar Row,Tier,Tier_bit ;
uchar ReadOldH,ReadOldL ;
write_com(0x34);
write_com(0x36);
Tier=X>>4 ;
Tier_bit=X&0x0f ;
if(Y<32)
Row=Y ;
else
Row=Y-32 ;
Tier+=8 ;
write_com(Row+0x80);
write_com(Tier+0x80);
ReadByte();
ReadOldH=ReadByte();
ReadOldL=ReadByte();
if(Tier_bit<8)
switch(Color)
case 0 :
ReadOldH&=(~(0x01<<(7-Tier_bit)));
break ;
case 1 :
ReadOldH|=(0x01<<(7-Tier_bit));
break ;
case 2 :
ReadOldH^=(0x01<<(7-Tier_bit));
break ;
default :
break ;
write_data(ReadOldH);
write_data(ReadOldL);
else
switch(Color)
case 0 :
ReadOldL&=(~(0x01<<(15-Tier_bit)));
break ;
case 1 :
ReadOldL|=(0x01<<(15-Tier_bit));
break ;
case 2 :
ReadOldL^=(0x01<<(15-Tier_bit));
break ;
default :
break ;
write_com(0x30);
void main()
uchar colour=1 ;
uchar count=0;
// uint ADzhi;
RW=0 ;
Init_Device();
lcdreset();
ceshi();
clrgdram();
delay(50);
clrscreen();
TR0 = 1;
n = 0;
while(1);
