近期完善了一下AT32 bsp 主要有
1,修复了使用scons -- dist生成工程后无法使用menuconfig问题
2,开启RT_USING_SDIO时同时开启RT_USING_DFS解决报错
3,工程默认使用板载ATLINK
4,RTC升级至2.0(之前rtc驱动已编译不过,升级后测试正常使用)
问题1很简单,AT32自己写了sdk_dist.py
BSP dist function
def dist_do_building(BSP_ROOT, dist_dir):
from mkdist import bsp_copy_files
import rtconfig
print("=> copy at32 bsp library")
library_dir = os.path.join(dist_dir, 'Libraries')
library_path = os.path.join(os.path.dirname(BSP_ROOT), 'Libraries')
bsp_copy_files(os.path.join(library_path, rtconfig.BSP_LIBRARY_TYPE),
os.path.join(library_dir, rtconfig.BSP_LIBRARY_TYPE))
print("=> copy bsp drivers")
bsp_copy_files(os.path.join(library_path, 'rt_drivers'), os.path.join(library_dir, 'rt_drivers'))
shutil.copyfile(os.path.join(library_path, 'Kconfig'), os.path.join(library_dir, 'Kconfig'))
但是复制library之后并没有更改Kconfig中Libraries/Kconfig目录,
导致使用scons — dist之后Libraries/Kconfig找不到,解决办法就是在后面加上
# change RTT_ROOT in Kconfig
if not os.path.isfile(os.path.join(dist_dir, 'Kconfig')):
return
with open(os.path.join(dist_dir, 'Kconfig'), 'r') as f:
data = f.readlines()
with open(os.path.join(dist_dir, 'Kconfig'), 'w') as f:
found = 0
for line in data:
if line.find('RTT_ROOT') != -1:
found = 1
if line.find('../Libraries') != -1 and found:
position = line.find('../Libraries')
line = line[0:position] + 'Libraries/Kconfig"\n'
found = 0
f.write(line)
问题2是我使用SDIO编译发现报错,原因是DFS未开启,修改bord/kconfig
menuconfig BSP_USING_SDIO
bool "Enable SDIO"
default n
select RT_USING_SDIO
select RT_USING_DFS
if BSP_USING_SDIO
config BSP_USING_SDIO1
bool "Enable SDIO1"
default n
endif
使用SDIO也会开启DFS
问题3只是因为工程默认使用JLINK,但是板载ATLING很方便,顺便改了
问题4是由于rtt升级了rtc框架导致原有驱动无法编译,
static time_t get_rtc_timestamp(void)
#ifdef SOC_SERIES_AT32F415
struct tm tm_new;
ERTC_TimeType ERTC_TimeStruct;
ERTC_DateType ERTC_DateStruct;
ERTC_GetTimeValue(ERTC_Format_BIN, &ERTC_TimeStruct);
ERTC_GetDateValue(ERTC_Format_BIN, &ERTC_DateStruct);
tm_new.tm_sec = ERTC_TimeStruct.ERTC_Seconds;
tm_new.tm_min = ERTC_TimeStruct.ERTC_Minutes;
tm_new.tm_hour = ERTC_TimeStruct.ERTC_Hours;
tm_new.tm_mday = ERTC_DateStruct.ERTC_Date;
tm_new.tm_mon = ERTC_DateStruct.ERTC_Month - 1;
tm_new.tm_year = ERTC_DateStruct.ERTC_Year + 100;
LOG_D("get rtc time.");
return timegm(&tm_new);
#else
return RTC_GetCounter();
#endif
static rt_err_t set_rtc_time_stamp(time_t time_stamp)
ERTC_TimeType ERTC_TimeStructure;
ERTC_DateType ERTC_DateStructure;
struct tm p_tm;
p_tm = gmtime(&time_stamp);
if (p_tm->tm_year < 100)
return -RT_ERROR;
ERTC_TimeStructure.ERTC_Seconds = p_tm->tm_sec ;
ERTC_TimeStructure.ERTC_Minutes = p_tm->tm_min ;
ERTC_TimeStructure.ERTC_Hours = p_tm->tm_hour;
ERTC_DateStructure.ERTC_Date = p_tm->tm_mday;
ERTC_DateStructure.ERTC_Month = p_tm->tm_mon + 1 ;
ERTC_DateStructure.ERTC_Year = p_tm->tm_year - 100;
ERTC_DateStructure.ERTC_WeekDay = p_tm->tm_wday + 1;
if (ERTC_SetTimeValue(ERTC_Format_BIN, &ERTC_TimeStructure) != SUCCESS)
return -RT_ERROR;
if (ERTC_SetDateValue(ERTC_Format_BIN, &ERTC_DateStructure) != SUCCESS)
return -RT_ERROR;
#else
/ Set the RTC counter value /
RTC_SetCounter(time_stamp);
/ Wait until last write operation on RTC registers has finished /
RTC_WaitForLastTask();
#endif / SOC_SERIES_AT32F415 /
LOG_D("set rtc time.");
ERTC_WriteBackupRegister(ERTC_BKP_DT0, BKUP_REG_DATA);
#else
BKP_WriteBackupReg(BKP_DT1, BKUP_REG_DATA);
#endif
return RT_EOK;
static rt_err_t rt_rtc_config(void)
#if defined (SOC_SERIES_AT32F415)
ERTC_InitType ERTC_InitStructure;
#endif
/ Allow access to BKP Domain /
PWR_BackupAccessCtrl(ENABLE);
#ifdef BSP_RTC_USING_LSI
RCC_ERTCCLKConfig(RCC_ERTCCLKSelection_LSI);
RCC_ERTCCLKCmd(ENABLE);
#else
RCC_ERTCCLKConfig(RCC_ERTCCLKSelection_LSE);
#endif / BSP_RTC_USING_LSI /
/ Wait for ERTC APB registers synchronisation /
ERTC_WaitForSynchro();
#else
RCC_RTCCLKConfig(RCC_RTCCLKSelection_LSI);
RCC_RTCCLKCmd(ENABLE);
#else
RCC_RTCCLKConfig(RCC_RTCCLKSelection_LSE);
/ Wait for RTC registers synchronization /
if (ERTC_ReadBackupRegister(BKP_DT1)!= BKUP_REG_DATA)
#else
if (BKP_ReadBackupReg(BKP_DT1) != BKUP_REG_DATA)
#endif
LOG_I("RTC hasn't been configured, please use command to config.");
/ Configure the ERTC data register and ERTC prescaler /
ERTC_InitStructure.ERTC_AsynchPrediv = 0x7F;
ERTC_InitStructure.ERTC_SynchPrediv = 0xFF;
ERTC_InitStructure.ERTC_HourFormat = ERTC_HourFormat_24;
ERTC_Init(&ERTC_InitStructure);
#else
/ Set RTC prescaler: set RTC period to 1sec /
RTC_SetDIV(32767);
#endif
return RT_EOK;
static rt_err_t at32_rtc_init(void)
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_PWR, ENABLE);
#else
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_PWR | RCC_APB1PERIPH_BKP, ENABLE);
#endif
RCC_LSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_LSISTBL) == RESET);
#else
RCC_LSEConfig(RCC_LSE_ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_LSESTBL) == RESET);
#endif / BSP_RTC_USING_LSI */
if (rt_rtc_config() != RT_EOK)
LOG_E("rtc init failed.");
return -RT_ERROR;
return RT_EOK;
static rt_err_t at32_rtc_get_secs(void *args)
*(rt_uint32_t *)args = get_rtc_timestamp();
LOG_D("RTC: get rtc_time %x\n", *(rt_uint32_t *)args);
return RT_EOK;
static rt_err_t at32_rtc_set_secs(void args)
rt_err_t result = RT_EOK;
if (set_rtc_time_stamp((rt_uint32_t *)args))
result = -RT_ERROR;
LOG_D("RTC: set rtc_time %x\n", *(rt_uint32_t *)args);
return result;
static const struct rt_rtc_ops at32_rtc_ops =
at32_rtc_init,
at32_rtc_get_secs,
at32_rtc_set_secs,
RT_NULL,
RT_NULL,
RT_NULL,
RT_NULL,
static rt_rtc_dev_t at32_rtc_dev;
int rt_hw_rtc_init(void)
rt_err_t result;
at32_rtc_dev.ops = &at32_rtc_ops;
result = rt_hw_rtc_register(&at32_rtc_dev, "rtc", RT_DEVICE_FLAG_RDWR,RT_NULL);
if (result != RT_EOK)
LOG_E("rtc register err code: %d", result);
return result;
LOG_D("rtc init success");
return RT_EOK;
INIT_DEVICE_EXPORT(rt_hw_rtc_init);
按照2.0做一下修改即可,使用文档RTCdemo测试
可以看到状态正常。
原作者:打盹的消防车
