1.主题
Tina V85x 平台适配双目GC2053的操作步骤
GC2053数据手册:ov-GC2053datas
2.问题背景
Tina V85x 平台支持多目sensor场景。Tina V85x SDK默认配置一般都是单目sensor,比如SDK V1.0默认是单目GC2053。为方便用户适配双目或多目sensor,下面以V853 perf1方案+双目GC2053为例,介绍适配的操作步骤。
3.解决办法
一、双目GC2053适配
适配双目GC2053主要修改以下几处:
1、dts设备树
文件:device/config/chips/v853/configs/perf1/board.dts
修改:
- (1)修改csi/isp频率
为节省带宽,可将csi/isp频率由原来默认的300MHz降至200MHz。
vind0:vind@0 {
- vind0_clk = <300000000>;
+ vind0_clk = <200000000>;
status = "okay";
- (2)修改成离线模式
因双目场景下,ISP需分时复用,故只能支持离线模式,即work_mode改成1(离线)。具体可参考->
tdm0:tdm@0 {
- work_mode = <0>;
+ work_mode = <1>;
isp00:isp@0 {
- work_mode = <0>;
+ work_mode = <1>;
scaler00:scaler@0 {
- work_mode = <0>;
+ work_mode = <1>;
scaler10:scaler@4 {
- work_mode = <0>;
+ work_mode = <1>;
scaler20:scaler@8 {
- work_mode = <0>;
+ work_mode = <1>;
scaler30:scaler@12 {
- work_mode = <0>;
+ work_mode = <1>;
- (3)修改sensor配置
sensor0默认是gc2053,无需修改。但是需要修改sensor1的配置为gc2053。修改后,sensor0和sensor1的配置如下:
sensor0:sensor@0 {
device_type = "sensor0";
sensor0_mname = "gc2053_mipi";
sensor0_twi_cci_id = <1>;
sensor0_twi_addr = <0x6e>;
sensor0_mclk_id = <0>;
sensor0_pos = "rear";
sensor0_isp_used = <1>;
sensor0_fmt = <1>;
sensor0_stby_mode = <0>;
sensor0_vflip = <0>;
sensor0_hflip = <0>;
sensor0_iovdd-supply = <®_aldo2>;
sensor0_iovdd_vol = <1800000>;
sensor0_avdd-supply = <®_bldo2>;
sensor0_avdd_vol = <2800000>;
sensor0_dvdd-supply = <®_dldo2>;
sensor0_dvdd_vol = <1200000>;
sensor0_power_en = <>;
sensor0_reset = <&pio PA 18 1 0 1 0>;
sensor0_pwdn = <&pio PA 19 1 0 1 0>;
sensor0_sm_hs = <>;
sensor0_sm_vs = <>;
flash_handle = <&flash0>;
act_handle = <&actuator0>;
status = "okay";
sensor1:sensor@1 {
device_type = "sensor1";
sensor1_mname = "gc2053_mipi_2";
sensor1_twi_cci_id = <0>;
sensor1_twi_addr = <0x6e>;
sensor1_mclk_id = <1>;
sensor1_pos = "front";
sensor1_isp_used = <1>;
sensor1_fmt = <1>;
sensor1_stby_mode = <0>;
sensor1_vflip = <0>;
sensor1_hflip = <0>;
sensor1_iovdd-supply = <®_aldo2>;
sensor1_iovdd_vol = <1800000>;
sensor1_avdd-supply = <®_bldo2>;
sensor1_avdd_vol = <2800000>;
sensor1_dvdd-supply = <®_dldo2>;
sensor1_dvdd_vol = <1200000>;
sensor1_power_en = <>;
sensor1_reset = <&pio PA 20 1 0 1 0>;
sensor1_pwdn = <&pio PA 21 1 0 1 0>;
sensor1_sm_hs = <>;
sensor1_sm_vs = <>;
flash_handle = <>;
act_handle = <>;
status = "okay";
- (4)修改各video节点的配置
双目GC2053场景下,可支持的video节点分别为:
sensor0:video 0/4/8/12
sensor1:video 1/5/9/13
故只需修改以上8个video节点的配置即可。修改后的配置如下:
vinc00:vinc@0 {
vinc0_csi_sel = <0>;
vinc0_mipi_sel = <0>;
vinc0_isp_sel = <0>;
vinc0_isp_tx_ch = <0>;
vinc0_tdm_rx_sel = <0>;
vinc0_rear_sensor_sel = <0>;
vinc0_front_sensor_sel = <0>;
vinc0_sensor_list = <0>;
work_mode = <0x1>;
status = "okay";
vinc01:vinc@1 {
vinc1_csi_sel = <1>;
vinc1_mipi_sel = <1>;
vinc1_isp_sel = <1>;
vinc1_isp_tx_ch = <0>;
vinc1_tdm_rx_sel = <1>;
vinc1_rear_sensor_sel = <1>;
vinc1_front_sensor_sel = <1>;
vinc1_sensor_list = <0>;
status = "okay";
vinc10:vinc@4 {
vinc4_csi_sel = <0>;
vinc4_mipi_sel = <0>;
vinc4_isp_sel = <0>;
vinc4_isp_tx_ch = <0>;
vinc4_tdm_rx_sel = <0>;
vinc4_rear_sensor_sel = <0>;
vinc4_front_sensor_sel = <0>;
vinc4_sensor_list = <0>;
work_mode = <0x1>;
status = "okay";
vinc11:vinc@5 {
vinc5_csi_sel = <1>;
vinc5_mipi_sel = <1>;
vinc5_isp_sel = <1>;
vinc5_isp_tx_ch = <0>;
vinc5_tdm_rx_sel = <1>;
vinc5_rear_sensor_sel = <1>;
vinc5_front_sensor_sel = <1>;
vinc5_sensor_list = <0>;
status = "okay";
vinc20:vinc@8 {
vinc8_csi_sel = <0>;
vinc8_mipi_sel = <0x0>;
vinc8_isp_sel = <0>;
vinc8_isp_tx_ch = <0>;
vinc8_tdm_rx_sel = <0>;
vinc8_rear_sensor_sel = <0>;
vinc8_front_sensor_sel = <0>;
vinc8_sensor_list = <0>;
work_mode = <0x1>;
status = "okay";
vinc21:vinc@9 {
vinc9_csi_sel = <0>;
vinc9_mipi_sel = <0x0>;
vinc9_isp_sel = <0>;
vinc9_isp_tx_ch = <0>;
vinc9_tdm_rx_sel = <0>;
vinc9_rear_sensor_sel = <0>;
vinc9_front_sensor_sel = <0>;
vinc9_sensor_list = <0>;
work_mode = <0x1>;
status = "okay";
vinc30:vinc@12 {
vinc12_csi_sel = <0>;
vinc12_mipi_sel = <0x0>;
vinc12_isp_sel = <0>;
vinc12_isp_tx_ch = <0>;
vinc12_tdm_rx_sel = <0>;
vinc12_rear_sensor_sel = <0>;
vinc12_front_sensor_sel = <0>;
vinc12_sensor_list = <0>;
work_mode = <0x1>;
status = "okay";
vinc31:vinc@13 {
vinc13_csi_sel = <1>;
vinc13_mipi_sel = <1>;
vinc13_isp_sel = <1>;
vinc13_isp_tx_ch = <0>;
vinc13_tdm_rx_sel = <1>;
vinc13_rear_sensor_sel = <1>;
vinc13_front_sensor_sel = <1>;
vinc13_sensor_list = <0>;
status = "okay";
2、内核配置
双mipi sensor场景下,ISP分时复用,需要使用TDM,故需打开TDM。
文件:device/config/chips/v853/configs/perf1/linux/config-4.9
修改:打开TDM配置
CONFIG_SUPPORT_ISP_TDM=y
CONFIG_TDM_LBC_EN=y
3、mpp middleware
首先,确保mpp配置中选中了gc2053 sensor。检查方法:
make menuconfig,依次进入配置项:
Allwinner
eyesee-mpp
[*] select sensor
[*] use sensor gc2053
然后,在ISP效果文件中,为第二个sensor添加效果文件配置。
位置:external/eyesee-mpp/middleware/sun8iw21/media/LIBRARY/libisp/isp_cfg/isp_ini_parse.c
修改:将原来的两组gc2053_mipi配置分别拷贝一份,然后修改名字为gc2053_mipi_2即可,其他参数不用修改。
struct isp_cfg_array cfg_arr[] = {
#ifdef SENSOR_GC2053
{"gc2053_mipi", "gc2053_mipi_isp600_20220511_164617_vlc4_day", 1920, 1088, 20, 0, 0, &gc2053_mipi_v853_isp_cfg},
{"gc2053_mipi", "gc2053_mipi_isp600_20220415_144837_ir", 1920, 1088, 20, 0, 1, &gc2053_mipi_ir_isp_cfg},
{"gc2053_mipi_2", "gc2053_mipi_isp600_20220511_164617_vlc4_day", 1920, 1088, 20, 0, 0, &gc2053_mipi_v853_isp_cfg},
{"gc2053_mipi_2", "gc2053_mipi_isp600_20220415_144837_ir", 1920, 1088, 20, 0, 1, &gc2053_mipi_ir_isp_cfg},
#endif
按以上步骤修改完成后,需重新编译mpp和固件,命令如下:
cleanmpp && mkmpp && mp
二、双目GC2053验证
支持验证双目GC2053的mpp sample有:
sample_rtsp(支持双目采集+编码+RTSP)、sample_smartIPC_demo(支持双目采集+编码+RTSP+人形检测)、sample_smartPreview_demo(支持双目采集+预览)
如果不需要RTSP功能,注释掉代码中的宏 #define SUPPORT_RTSP_TEST 即可。
有关mpp sample的使用方法,请参考https://bbs.aw-ol.com/topic/1906/
