2048
前言开发板具备Python运行环境,这对于一些轻量开发可以直接在开发板上进行脚本开发,这就十分方便。 python --version 可以看到版本是2.7.16。 [root@EASY-EAI-NANO:/]# python --version Python 2.7.16
过程直接SSH或者串口登录, 导入2048.py或者 直接vi编辑
- # -*- coding:UTF-8 -*-
- #!/usr/bin/python2
- import random
- import os, sys
- v = [[0, 0, 0, 0],
- [0, 0, 0, 0],
- [0, 0, 0, 0],
- [0, 0, 0, 0]]
- def display(v, score):
- print ("%4d %4d %4d %4d" % (v[0][0], v[0][1], v[0][2], v[0][3]))
- print ("%4d %4d %4d %4d" % (v[1][0], v[1][1], v[1][2], v[1][3]))
- print ("%4d %4d %4d %4d" % (v[2][0], v[2][1], v[2][2], v[2][3]))
- print ("%4d %4d %4d %4d" % (v[3][0], v[3][1], v[3][2], v[3][3]))
- print ("Total score: %d" % score)
- def init(v):
- for i in range(4):
- v[i] = [random.choice([0, 0, 0, 2, 2, 4]) for x in range(4)]
- def align(vList, direction):
- for i in range(vList.count(0)):
- vList.remove(0)
- zeros = [0 for x in range(4 - len(vList))]
- if direction == 'left':
- vList.extend(zeros)
- else:
- vList[:0] = zeros
- def addSame(vList, direction):
- score = 0
- for i in [0, 1, 2]:
- align(vList, direction)
- if vList[i] == vList[i+1] != 0:
- vList[i] *= 2
- vList[i+1] = 0
- score += vList[i]
- return {'bool':True, 'score':score}
- else:
- for i in [3, 2, 1]:
- if vList[i] == vList[i-1] != 0:
- vList[i] *= 2
- vList[i-1] = 0
- score += vList[i]
- return {'bool':False, 'score':score}
- def handle(vList, direction):
- totalScore = 0
- result = addSame(vList, direction)
- while result['bool'] == True:
- totalScore += result['score']
- return totalScore
- def operation(v):
- totalScore = 0
- gameOver = False
- direction = 'left'
- op = raw_input ('operator:')
- if op in ['a','A']:
- for row in range(4):
- totalScore += handle(v[row], direction)
- elif op in ['d','D']:
- direction = 'right'
- elif op in ['w', 'W']:
- for col in range(4):
- vList = [v[row][col] for row in range(4)]
- totalScore += handle(vList, direction)
- v[row][col] = vList[row]
- elif op in ['s', 'S']:
- else:
- print ("Invalid raw_input ,please enter a charactor in [W,S,A,D] or the lower")
- gameOver = True
- return {'gameOver':gameOver,'score':totalScore}
- N = 0
- for q in v:
- N += q.count(0)
- if N == 0:
- gameOver = True
- return {'gameover':gameOver,'score':totalScore}
- num = random.choice([2,2,2,4])
- k = random.randrange(1, N+1)
- n = 0
- for j in range(4):
- if v[i][j] == 0:
- n += 1
- if n == k:
- v[i][j] = num
- break
- return {'gameOver':gameOver, 'score':totalScore}
- init(v)
- score = 0
- print ("raw_input :W(Up) S(Down) A(Left) D(Right), press .")
- while True:
- os.system("clear")
- display(v, score)
- result = operation(v)
- print (result)
- if result['gameOver'] == True:
- print ("Game Over, You failed!")
- print ("Your total score %d" % (score))
- sys.exit(1)
- else:
- score += result['score']
- if score >= 2048:
- print ("Game Over, You Win!!!")
- print ("Your total score: %d" % (score))
- sys.exit(0)
复制代码
添加可执行权限 chmod +x 2048.py 运行 python 2048.py 分别用wsad控制上下左右移动
总结开发板提供了Python环境,直接开发板上进行Python开发十分便捷,这对一些轻量开发场景时非常方便。
