官方提供的是AT命令格式,但是我原来想象的还是用模块本身获取数据然后上传给AP,这次仔细阅读了官方的源代码,at代码在PS目录下面,的at目录下面,主要有at_boot.c、at_factory.c、at_wiota.c、at_wiota.h、at_wiota_atuto_manager.c、ati_prs.h文件。
在at_factory.c下面给出了示例,可以学习如何操作:
enum factory_can_write_read_type
FACTORY_CAN_WRITE = 0,
FACTORY_CAN_READ,
enum factory_command_type
FACTORY_WIOTA = 0,
FACTORY_GPIO,
FACTORY_I2C,
FACTORY_AD,
FACTORY_DA,
FACTORY_UART1,
FACTORY_PWM,
FACTORY_CAN,
static rt_err_t write_reg(struct rt_i2c_bus_device *bus, rt_uint8_t reg, rt_uint8_t *data)
rt_uint8_t buf[8];
struct rt_i2c_msg msgs;
rt_uint32_t buf_size = 1;
buf[0] = reg;
if (data != RT_NULL)
buf[1] = data[0];
buf[2] = data[1];
buf[3] = data[2];
buf[4] = data[3];
buf_size = 5;
msgs.addr = AT24C02_ADDR;
msgs.flags = RT_I2C_WR;
msgs.buf = buf;
msgs.len = buf_size;
if (rt_i2c_transfer(bus, &msgs, 1) == 1)
return RT_EOK;
else
return -RT_ERROR;
static rt_err_t read_regs(struct rt_i2c_bus_device *bus, rt_uint8_t len, rt_uint8_t *buf)
msgs.flags = RT_I2C_RD;
msgs.buf = buf;
msgs.len = len;
return RT_EOK;
else
return -RT_ERROR;
static int at_test_i2c(void)
rt_device_t dev;
unsigned char set_data[4] = {1,2,3,4};
unsigned char get_data[4] = {0};
int num = 0;
dev = rt_device_find(AHT10_I2C_BUS_NAME);
if(RT_NULL == dev)
rt_kprintf("rt_device_find i2c fail
return 1;
if(RT_EOK != write_reg((struct rt_i2c_bus_device*)dev, 0, set_data))
rt_kprintf("write_reg i2c fail
return 2;
if(RT_EOK != read_regs((struct rt_i2c_bus_device*)dev, 4, get_data))
rt_kprintf("read_regs i2c fail
return 3;
for(num = 0; num < 4; num++)
if (set_data[num] != get_data[num])
rt_kprintf("i2c data match fail. num=%d, %d!= %d
", num, set_data[num], get_data[num]);
return 4;
return 0;
static int at_test_ad(unsigned int channel)
rt_adc_device_t adc_dev;
rt_uint32_t value;
adc_dev = (rt_adc_device_t)rt_device_find(ADC_DEV_NAME);
if (RT_NULL == adc_dev)
rt_kprintf("ad find %s fail
", ADC_DEV_NAME);
return -1;
rt_adc_enable(adc_dev, channel);
value = rt_adc_read(adc_dev, channel);
rt_adc_disable(adc_dev, channel);
return value;
static int at_test_da(unsigned int channel, unsigned int value)
rt_dac_device_t dac_dev;
dac_dev = (rt_dac_device_t)rt_device_find(DAC_DEV_NAME);
if (RT_NULL == dac_dev)
rt_kprintf("da find fail
return -1;
rt_dac_enable(dac_dev, channel);
rt_dac_write(dac_dev, channel, value);
return 0;
static int at_factory_test_uart1(void)
static rt_device_t serial;
unsigned char send_data[4] = {"1234"};
unsigned char recv_data[4] = {0};
serial = rt_device_find(UART1_DEV_NMAE);
if (serial)
return 1;
if ( RT_EOK != rt_device_open(serial, RT_DEVICE_OFLAG_RDWR))
rt_kprintf("uart open fail
return 2;
rt_device_write(serial, 0, send_data, sizeof(send_data)/sizeof(unsigned char));
if(rt_device_read(serial, 0, recv_data, sizeof(recv_data)/sizeof(unsigned char)) < 1)
rt_kprintf("uart read fail
return 3;
rt_device_close(serial);
return strcmp((const char *)send_data, (const char *)recv_data);
static int at_factory_test_pwm(int channel, unsigned int period)
struct rt_device_pwm *pwm_dev;
pwm_dev = (struct rt_device_pwm *)rt_device_find(PWM_DEV_NAME);
if (RT_NULL == pwm_dev)
return 1;
rt_pwm_set(pwm_dev, channel, period, 0);
rt_pwm_enable(pwm_dev, channel);
rt_pwm_disable(pwm_dev,channel);
return 0;
static int at_factory_test_can(int type, void *data)
static rt_device_t can_dev;
struct rt_can_msg msg = {0};
rt_err_t res;
rt_size_t size;
can_dev = rt_device_find(CAN_DEV_NAME);
if (RT_NULL == can_dev)
rt_kprintf("find %s failed!
", CAN_DEV_NAME);
return 1;
res = rt_device_open(can_dev, RT_DEVICE_FLAG_INT_TX | RT_DEVICE_FLAG_INT_RX);
if(res != RT_EOK)
rt_kprintf("open %s failed!
", CAN_DEV_NAME);
return 2;
if (type == FACTORY_CAN_WRITE)
msg.id = 0x78;
msg.ide = RT_CAN_STDID;
msg.rtr = RT_CAN_DTR;
msg.len = 8;
msg.data[0] = 0x00;
msg.data[1] = 0x11;
msg.data[2] = 0x22;
msg.data[3] = 0x33;
msg.data[4] = 0x44;
msg.data[5] = 0x55;
msg.data[6] = 0x66;
msg.data[7] = 0x77;
size = rt_device_write(can_dev, 0, &msg, sizeof(msg.data));
if (size == 0)
return 2;
else if (type == FACTORY_CAN_READ)
int len = 0;
rt_device_read(can_dev, 0, data, 8);
rt_kprintf("recv data:");
for(len = 0; len < 8; len++)
rt_kprintf("%x", *((int*)(data+len)));
rt_kprintf("
return 0;
static at_result_t at_factory_setup(const char* args)
int type = 0, data = 0, data1 = 0;
args = parse ((char*)(++args),"ddd", &type, &data, &data1);
if (!args)
return AT_RESULT_PARSE_FAILE;
rt_kprintf("type = %d,data=%d,data1 = %d
", type, data, data1);
switch(type)
case FACTORY_WIOTA:
if(!factory_msg_handler(data,data1)) {
return AT_RESULT_FAILE;
break;
case FACTORY_GPIO:
rt_base_t pin = data;
rt_base_t value = data1 & 0x1;
rt_pin_write( pin, value);
break;
case FACTORY_I2C:
if (at_test_i2c())
break;
case FACTORY_AD:
unsigned int ch = data;
int result = at_test_ad(ch);
if (result < 0)
return AT_RESULT_NULL;
switch(ch)
case ADC_CONFIG_CHANNEL_TEMP_B:
float val = 0.00;
val = (float)((float)1.42/4.0 + (result - 2048)* (float)1.42/2048.0/8.0);
at_server_printfln("+FACTORY=%d,0.%d", type, val*100.0);
break;
default:
at_server_printfln("+FACTORY=%d,%d", type, result);
break;
break;
case FACTORY_DA:
unsigned int val = data1;
if(at_test_da(ch, val) < 0)
break;
case FACTORY_UART1:
if(at_factory_test_uart1())
break;
case FACTORY_PWM:
int channel = data;
unsigned int period = data1;
if (at_factory_test_pwm( channel, period))
break;
case FACTORY_CAN:
char recv[8] = {0};
if (at_factory_test_can(data, recv))
if (data == FACTORY_CAN_READ)
at_server_printf("+FACTORY=%d,", type);
at_send_data(recv, sizeof(recv)/sizeof(recv[0]));
break;
default:
return AT_RESULT_REPETITIVE_FAILE;
return AT_RESULT_OK;
AT_CMD_EXPORT("AT+FACTORY", "=,,", RT_NULL, RT_NULL, at_factory_setup, RT_NULL);
