扫一扫,分享给好友
求高手加q2293859733,求助!!!非常着急... ad9850函数信号发生器#include #define uchar unsigned char #define uint unsigned int ***it LCD_RS = P1^0; ***it LCD_RW = P1^1; ***it LCD_E = P1^2; #define LCD_DATA P0 //液晶1602管脚设置 ***it w_clk = P1^3; // ad9850 w_clk; ***it fq_ud = P1^4; //ad9850 fqud; ***it reset = P1^5; //ad9850 reset ***it s01=P1^6; ***it s02=P1^7 ; //波形转换使能 unsigned char code Lcdtab1[]= {"Freq: Hz"}; unsigned char code Lcdtab2[]= {"AD9850 Sine -->"}; unsigned char code Lcdtab3[]= {"AD9850 Tria -->"}; unsigned char code Lcdtab4[]= {"AD9850 Squa -->"}; unsigned char code Lcdtab5[]= {"CXL Grad design"}; unsigned char code Lcdtab6[]= {"DDS WELCOME !!!"}; unsigned char code Lcdtab7[]= {"AD9850 GND -->"};//1602预读字体 double Con_Word_1 = 0x00; double Con_Word_2 = 0x00; long uint ConTrol_Word = 0x00;//根据设置的频率换算成将要送入AD9850中的整数量; long uint Frequency_Out; uchar a,b,c,d,e,f,g,h,wav; uchar AnJianCiShuBiangLiang = 0x00; long uint SheZhiZhongYaoXianShiDeShuJu = 0x00; uchar dingshiqilideshijianbianliang = 0x00;(定时器的时间变量) uchar lianjiabiaozhi = 0x00;lianjianbiaozhi = 0x00; long uint Out_Signal_Max = 30000000;//设置子程序中的上限值,设30MHz uint Light_Bian_Liang = 0x00; ***it P3_3 = P3^3; ***it P3_4 = P3^4; ***it P3_5 = P3^5; ***it P3_6 = P3^6; ***it P3_7 = P3^7;//矩阵键盘设置 uchar j = 0,dat = 0; uchar keyzhi = 0x00; void lcd_init(void); void display_string(unsigned char x,unsigned char y,unsigned char *s); Qu_Chu_Shu_Ma_Ge_Wei(); void time0(void)interrupt 1 using 1 //Interruption { EA=0; dingshiqilideshijianbianliang++; TH0=0xa6; //shi de sha ping TL0=0x66; ET0 =1 ; TR0 = 1; EA=1; } void delay(long unsigned int h) { while(h--); //0.01MS } void WriteDataLcd(unsigned char wdata) { LCD_RS=1; LCD_RW=0; LCD_E=0; LCD_E=1; LCD_DATA=wdata; delay(100); //短暂延时,代替检测忙状态 LCD_E=0; //LCD_RW = 1; //LCD_E=1; } void WriteCommandLcd(unsigned char wdata) { LCD_RS=0; LCD_RW=0; LCD_E=0; LCD_E=1; LCD_DATA=wdata; delay(100); //短暂延时,代替检测忙状态 LCD_E=0; } //LCD初始化 void lcd_init(void) { LCD_DATA = 0; delay(1000); WriteCommandLcd(0x38); delay(500); WriteCommandLcd(0x38); //显示模式设置 delay(500); WriteCommandLcd(0x38); //显示模式设置 delay(500); WriteCommandLcd(0x01); //关闭显示 WriteCommandLcd(0x38); //显示清屏 WriteCommandLcd(0x0c); //显示光标移动设置 WriteCommandLcd(0x06); //显示开及光标移动设置 //WriteCommandLcd(0x0f); //WriteCommandLcd(0x80); //WriteDataLcd(0x30); //WriteDataLcd(0x31); //WriteDataLcd(0x32); //WriteDataLcd(0x33); } void display_xy(unsigned char x,unsigned char y) { if(y==0x01) { x = x + 0x40 + 0x80; } else { x = x+0x80; } WriteCommandLcd(x); } void display_char(unsigned char x,unsigned char y,unsigned char dat) { display_xy(x,y); WriteDataLcd(dat); } void display_string(unsigned char x,unsigned char y,unsigned char *s) (这段是不是申明?*s是什么意思?while(*s)用法) { display_xy(x,y); while(*s) { WriteDataLcd(*s); s++; } } Qu_Chu_Shu_Ma_Ge_Wei() { a = Frequency_Out % 10; b = (Frequency_Out % 100)/10; c = (Frequency_Out % 1000)/100; d = (Frequency_Out % 10000)/1000; e = (Frequency_Out % 100000)/10000; f = (Frequency_Out % 1000000)/100000; g = (Frequency_Out % 10000000)/1000000; h = (Frequency_Out % 100000000)/10000000; } scan_KEY(void) //The subprogram is used to scan key { uchar key = 0; key = P3; //Eliminate themost high bit and low three bits key = key & 0xf8; switch(key) { case 0xb0: keyzhi = 3 ;break; case 0xa8: keyzhi = 2 ;break; case 0x98: keyzhi = 1 ;break; case 0x70: keyzhi = 6 ;break; case 0x68: keyzhi = 5 ;break; case 0x58: keyzhi = 4 ;break; default: keyzhi=0; } return(keyzhi); } keychuli() { P3_3 = 0x01;P3_4 = 0x01;P3_5 = 0x01; P3_6 = 0x00;P3_7 = 0x00; delay(100); if((P3_3&P3_4&P3_5) == 0x00) { //delay(1000); if((P3_3&P3_4&P3_5) == 0x00) { P3_6 = 0x00;P3_7 = 0x01; dat = scan_KEY(); if(dat == 0x00) { P3_6 = 0x01;P3_7 = 0x00; dat = scan_KEY(); } } else { dat = 0x00; goto down;//无键按下 } } down:return(dat); } display_data() { Qu_Chu_Shu_Ma_Ge_Wei(); display_string(0,0,Lcdtab1); //显示第一行,从第2个位置开始 WriteCommandLcd(0x85);//显示数值的话,用其真实的地址,如0x83等, WriteDataLcd(0x30+h); WriteDataLcd(0x30+g); WriteDataLcd(0x30+f); WriteDataLcd(0x30+e); WriteDataLcd(0x30+d); WriteDataLcd(0x30+c); WriteDataLcd(0x30+b); WriteDataLcd(0x30+a); } Calculate_Control_Word(long uint Frequency_Out) { //Con_Word_1 = Frequency_Out * 85; //Con_Word_2 = Frequency_Out * 0.88526071724; Con_Word_1 = Frequency_Out * 34; Con_Word_2 = Frequency_Out * 0.3537898195;//125M晶振 Con_Word_2 = Con_Word_2 + 0.5; Con_Word_1 = Con_Word_1 + Con_Word_2; //根据设定的频率以浮点形式计算控制字 ConTrol_Word = Con_Word_1 / 1;//将控制字换算成整数形式 } Send_Control_Word(long uint ConTrol_Word) { long uint ConTrol_Word_Temporary ; uchar data_word ; w_clk = 0x00; //根据时序图 fq_ud = 0x00; //根据时序图 data_word = 0x00; //相位、掉电等相关控制字 P0 = data_word; w_clk=1; delay(50); w_clk=0; ConTrol_Word_Temporary = ConTrol_Word; ConTrol_Word = ConTrol_Word >> 24; data_word = ConTrol_Word % 256;//取出W1,频率控制字中的最高字节; P0 = data_word;//AD9850并口接P0; w_clk=1; delay(50); w_clk=0; ConTrol_Word = ConTrol_Word_Temporary; ConTrol_Word = ConTrol_Word >> 16; data_word = ConTrol_Word % 256;//取出W2,频率控制字中的次高字节; P0 = data_word; w_clk=1; delay(50); w_clk=0; ConTrol_Word = ConTrol_Word_Temporary; ConTrol_Word = ConTrol_Word >> 8; data_word = ConTrol_Word % 256;//取出W3,频率控制字中的第三字节; P0 = data_word; w_clk=1; delay(50); w_clk=0; ConTrol_Word = ConTrol_Word_Temporary; data_word = ConTrol_Word % 256;//取出W4,频率控制字中的最后一个字节; P0= data_word; w_clk=1; delay(50); w_clk=0; //根据时序图 fq_ud=1; //根据时序图 } main() { unsigned char i = 0x00; long uint shiyanshuju = 0x00; reset = 1; //复位AD9850; delay(10000); reset = 0; //AD9850恢复工作模式; lcd_init(); TMOD=0x01; //用来实现时间设置 TH0=0xa6; TL0=0x66; ET0 = 1; TR0 = 1; EA = 0x00; Frequency_Out =1000;//开机默认的频率输出值; Calculate_Control_Word(Frequency_Out);//根据设置的频率换算成将要送入AD9850中的整数值; Send_Control_Word(ConTrol_Word); //向AD9850送出频率控制字; display_data(); display_string(0,1,Lcdtab6); AnJianCiShuBiangLiang = 0x00; //WriteCommandLcd(0xc5); //WriteDataLcd(0x30+(Step_Data/1000)); //WriteDataLcd(0x30+(Step_Data/100)%10); //WriteDataLcd(0x30+(Step_Data/10)%10); //WriteDataLcd(0x30+(Step_Data%10)); //display_string(9,1,"Hz"); while(1) { if(dingshiqilideshijianbianliang == 10) { WriteCommandLcd(0x85+AnJianCiShuBiangLiang);//显示数值的话,用其真实的地址,如0x83等,拼音是定时器计数器的时间变量 WriteDataLcd(0x20); //空格 dingshiqilideshijianbianliang = 11; } if(dingshiqilideshijianbianliang == 20) { WriteCommandLcd(0x85+AnJianCiShuBiangLiang);//显示数值的话,用其真实的地址,如0x83等, WriteDataLcd(0x30+shiyanshuju); dingshiqilideshijianbianliang = 0x00; } keychuli(); //键盘配置; if(dat == 0x02) { dat = 0x00;delay(5000); //升频键; if(AnJianCiShuBiangLiang == 7) { if((Frequency_Out+1) <= 30000000) { Frequency_Out = Frequency_Out+1; } } if(AnJianCiShuBiangLiang == 6) { if((Frequency_Out+10) <= 30000000) { Frequency_Out = Frequency_Out+10; } } if(AnJianCiShuBiangLiang == 5) { if((Frequency_Out+100) <= 30000000) { Frequency_Out = Frequency_Out+100; } } if(AnJianCiShuBiangLiang == 4) { if((Frequency_Out+1000) <= 30000000) { Frequency_Out = Frequency_Out+1000; } } if(AnJianCiShuBiangLiang == 3) { if((Frequency_Out+10000) <= 30000000) { Frequency_Out = Frequency_Out+10000; } } if(AnJianCiShuBiangLiang == 2) { if((Frequency_Out+100000) <= 30000000) { Frequency_Out = Frequency_Out+100000; } } if(AnJianCiShuBiangLiang == 1) { if((Frequency_Out+1000000) <= 30000000) { Frequency_Out = Frequency_Out+1000000; } } if(AnJianCiShuBiangLiang == 0) { if((Frequency_Out+10000000) <= 30000000) { Frequency_Out = Frequency_Out+10000000; } } display_data();//刷新显示;; if(AnJianCiShuBiangLiang == 7) { shiyanshuju = a; } if(AnJianCiShuBiangLiang == 6) { shiyanshuju = b; } if(AnJianCiShuBiangLiang == 5) { shiyanshuju = c; } if(AnJianCiShuBiangLiang == 4) { shiyanshuju = d; } if(AnJianCiShuBiangLiang == 3) { shiyanshuju = e; } if(AnJianCiShuBiangLiang == 2) { shiyanshuju = f; } if(AnJianCiShuBiangLiang == 1) { shiyanshuju = g; } if(AnJianCiShuBiangLiang == 0) { shiyanshuju = h; } dingshiqilideshijianbianliang = 18; } if(dat == 0x05) { dat = 0x00;delay(5000); //降频键; if(AnJianCiShuBiangLiang == 7) { if(Frequency_Out >= 1) { Frequency_Out = Frequency_Out-1; } } if(AnJianCiShuBiangLiang == 6) { if(Frequency_Out >= 10) { Frequency_Out = Frequency_Out-10; } } if(AnJianCiShuBiangLiang == 5) { if(Frequency_Out >= 100) { Frequency_Out = Frequency_Out-100; } } if(AnJianCiShuBiangLiang == 4) { if(Frequency_Out >= 1000) { Frequency_Out = Frequency_Out-1000; } } if(AnJianCiShuBiangLiang == 3) { if(Frequency_Out >= 10000) { Frequency_Out = Frequency_Out-10000; } } if(AnJianCiShuBiangLiang == 2) { if(Frequency_Out >= 100000) { Frequency_Out = Frequency_Out-100000; } } if(AnJianCiShuBiangLiang == 1) { if(Frequency_Out >= 1000000) { Frequency_Out = Frequency_Out-1000000; } } if(AnJianCiShuBiangLiang == 0) { if(Frequency_Out >= 10000000 & Frequency_Out <= 30000000) { Frequency_Out = Frequency_Out - 10000000; } } display_data();//刷新显示;; if(AnJianCiShuBiangLiang == 7) { shiyanshuju = a; } if(AnJianCiShuBiangLiang == 6) { shiyanshuju = b; } if(AnJianCiShuBiangLiang == 5) { shiyanshuju = c; } if(AnJianCiShuBiangLiang == 4) { shiyanshuju = d; } if(AnJianCiShuBiangLiang == 3) { shiyanshuju = e; } if(AnJianCiShuBiangLiang == 2) { shiyanshuju = f; } if(AnJianCiShuBiangLiang == 1) { shiyanshuju = g; } if(AnJianCiShuBiangLiang == 0) { shiyanshuju = h; } dingshiqilideshijianbianliang = 18; } if(dat == 0x03) { dat = 0x00;delay(5000); //光标左移键; EA = 0x01; if(AnJianCiShuBiangLiang == 0x00) { AnJianCiShuBiangLiang = 0x07; } else { AnJianCiShuBiangLiang--; } display_data();//刷新显示;; display_string(0,1,Lcdtab5); if(AnJianCiShuBiangLiang == 7) { shiyanshuju = a; } if(AnJianCiShuBiangLiang == 6) { shiyanshuju = b; } if(AnJianCiShuBiangLiang == 5) { shiyanshuju = c; } if(AnJianCiShuBiangLiang == 4) { shiyanshuju = d; } if(AnJianCiShuBiangLiang == 3) { shiyanshuju = e; } if(AnJianCiShuBiangLiang == 2) { shiyanshuju = f; } if(AnJianCiShuBiangLiang == 1) { shiyanshuju = g; } if(AnJianCiShuBiangLiang == 0) { shiyanshuju = h; } dingshiqilideshijianbianliang = 18; } if(dat == 0x01) { dat = 0x00;delay(5000); //光标右移键; EA = 0x01; if(AnJianCiShuBiangLiang == 0x07) { AnJianCiShuBiangLiang = 0x00; } else { AnJianCiShuBiangLiang++; } display_data();//刷新显示; display_string(0,1,Lcdtab5); if(AnJianCiShuBiangLiang == 7) { shiyanshuju = a; } if(AnJianCiShuBiangLiang == 6) { shiyanshuju = b; } if(AnJianCiShuBiangLiang == 5) { shiyanshuju = c; } if(AnJianCiShuBiangLiang == 4) { shiyanshuju = d; } if(AnJianCiShuBiangLiang == 3) { shiyanshuju = e; } if(AnJianCiShuBiangLiang == 2) { shiyanshuju = f; } if(AnJianCiShuBiangLiang == 1) { shiyanshuju = g; } if(AnJianCiShuBiangLiang == 0) { shiyanshuju = h; } dingshiqilideshijianbianliang = 18; } if(dat == 0x04) { dat = 0x00;delay(1000); //确定、输出波形选择键; EA = 0x00; s01=0x00;s02=0x00; display_data();//刷新显示; Calculate_Control_Word(Frequency_Out);//根据设置的频率换算成将要送入AD9850中的整数值; Send_Control_Word(ConTrol_Word); //向AD9850送出频率控制字; AnJianCiShuBiangLiang = 0x00; { switch(wav) { case 0: //波形选择; { s01=0; s02=1; display_string(0,1,Lcdta
2个回答
呃,我也是做这个,可是我还没写程序。。你厉害噢~~
额 void display_string(unsigned char x,unsigned char y,unsigned char *s) (这段是不是申明?*s是什么意思?while(*s)用法) { display_xy(x,y); while(*s) { WriteDataLcd(*s); s++; } } 就这段程序的 函数命名分析可知 这段代码的作用是 LCD输出一个字符串 这里的 *s是一个指针 指向待输出的字符串数组的首地址 while(*s)的意思是 当 *s指向的数据返回 0 时证明已经到了数据的尽头,即显示完毕。因为循环体内有s++;这句用来指向下一个数据 我自己的个人习惯是 while( s[i]!=' |
