最初购买了一个15V10A的开关电源。
驱动板说明书上写的最大10A。接到驱动板上,把板子给烧了。询问技术人员后说,是一个双端输出这样每个腿就是5A了。 开关电源上不是也有+-15V吗? 所以现在不知道应该购买哪种电源? 驱动板技术人员发的邮件: A ‘leg’ refers to a hot conductor in an electrical system. Our system contains two ‘hot legs’(sometimes also called the positive and negative rails). The power input should be DC, as you want a steady supply of power to the servo amplifiers. However, galvos, by their nature, are sinusoidal systems so the power outputs going to the motor from the amplifier is alternating. The servos themselves have two generously sized capacitors that provide instantaneous current to the output drives when needed. This reduces the overall power supply demands, which is why you do not need a power supply that outputs 10A. Typically, a supply of 3A – 5A is more than sufficient to run these galvanometers. Again, the customer will have to keep in mind that this is a dual-output supply so it is 3-5A per channel (or leg, or rail, whatever the vendor wants to call it). If your customer was using a linear supply and it was 10A, they put 10A across one leg of the system and likely cooked it. 驱动板要求: 接线图 电源参数: |
2个回答
看看有没有大神来帮忙看看
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1352 浏览 2 评论
24v开关电源指示灯有规律的一暗一暗,输出电压在20到22v之间跳变怎么查找?
1129 浏览 4 评论
电源接线检测仪LED1、2电路的二极管是反接的,灯为什么会亮?
8005 浏览 2 评论
4725 浏览 1 评论
各位大神,求电路图,用MC34063设计出一个升降压DC-DC,输出900mA左右
5321 浏览 0 评论
GMT+8, 2024-9-10 08:53 , Processed in 0.620205 second(s), Total 77, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
