CS5261
USB Type-C to HDMI2.0b 4k@30Hz Converter 高度集成单芯片,适用于多个细分市场和显示器应用,如适配器、对接站等。 The Capstone CS5261 is a high-performance Type-C/DP1.4 to HDMI2.0b converter, designed to connect a USB Type-C source or a DP1.4 source to an HDMI2.0b sink. The CS5261 integrates a DP1.4 compliant receiver, an HDMI2.0b compliant transmitter. Also, two CC controllers are included for CC communication to implement DP Alt Mode and power delivery (5V Slow charging) function, one for upstream Type-C port and another for downstream port. The DP interface comprises 2 main lanes, AUX channel, and HPD signal. The receiver supports maximum 5.4Gbps (HBR2) data rate per lane. The DP receiver incorporates HDCP1.4 content protection scheme with embedded key for secure transmission of digital audio-video content. The HDMI interface includes 4 TMDS clock/data pairs, DDC, and HPD signal. The HDMI transmitter is capable of supporting up to 3Gpbs data rate, quite adequate for handling video resolutions up to FHD 1080p 120Hz and UHD 4k 30Hz formats. The HDMI transmitter incorporates HDCP engines which support HDCP1.4. With the inclusion of HDCP, the CS5261 allows secure transmission of protected content. Embedded key is available that provides the highest level of HDCP key security. The CS5261 is a highly integrated single chip suitable for multiple market segments and display applications, such as the dongle, docking station etc. |
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
1933 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
730 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1240 浏览 0 评论
2846 浏览 3 评论
1312 浏览 1 评论
GMT+8, 2024-11-25 08:29 , Processed in 0.575332 second(s), Total 38, Slave 29 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
