1个回答
RK3288调试笔记 Android 7.7.7调试状态笔记 7811android
在路径中的路径为/apps/settings/配置信息1在路径中为包中的设备/应用程序/设置中的手机屏幕状态和xml文件中的电池状态和xml文件选项布局wangxd @build-server-100:~/work/dsy/rk3288-Android-7.0/packages/apps/Settings((465d84e.。.))$ git diff diff --git a/res/xml/device_info_status. xml b/res/xml/device_info_status.xml 旧模式 100644 新模式 100755 索引 a0b7590..ab23690 --- a/res/xml/device_info_status.xml +++ b/res/xml/device_info_status.xml @@ -17, 18 +17,20 @@ 《PreferenceScreen xmlns: android:》 - 《com.android.settings.CopyablePreference android: + 《!--《com.android.settings.CopyablePreference android: android: android: android: android:summary=“@string/device_info_not_available” android: /》 《com.android.settings.CopyablePreference android: android: android: android: android:summary=“@string/device_info_not_available” - android:/》 + android--》 《Preference android: android: android:》 2 在路径-/》/packages/apps/Settings/src/androidus/settings/device.javaStatus.javaStatus.javaStatus文件中的电池状态和电池信息:配置/设置/配置获取和获取后的相关事件 diff --git a/src/com/android/settings/deviceinfo/Status.java b/src/com/android/settings/deviceinfo/Status old mode 100644 新模式 100755 索引 1ba3978..6dfc671 --- a/src/com/android/settings/deviceinfo/Status.java +++ b/src/com/android/settings/deviceinfo/Status.java @@ -56,8 +56,8 @@ 导入 java.lang.ref.WeakReference; */ public class Status extends SettingsPreferenceFragment { - private static final String KEY_BATTERY_STATUS = “battery_status”; - 私有静态最终字符串 KEY_BATTERY_LEVEL = “battery_level”; + // 私有静态最终字符串 KEY_BATTERY_STATUS = “battery_status”; + // 私有静态最终字符串 KEY_BATTERY_LEVEL = “battery_level”; 私有静态最终字符串 KEY_IP_ADDRESS = “wifi_ip_address”; 私有静态最终字符串 KEY_BT_ADDRESS = “bt_address”; @@ -129,8 +129,8 @@ public class Status extends SettingsPreferenceFragment { public void onReceive(Context context, Intent intent) { String action = intent.getAction(); if (Intent.ACTION_BATTERY_CHANGED.equals(action)) { - mBatteryLevel.setSummary(Utils.getBatteryPercentage(intent)); - mBatteryStatus.setSummary(Utils.getBatteryStatus(getResources(), intent)); + // mBatteryLevel.setSummary(Utils.getBatteryPercentage(intent)); + // mBatteryStatus.setSummary(Utils.getBatteryStatus(getResources(), intent)); } } }; @@ -164,8 +164,8 @@ public class Status extends SettingsPreferenceFragment { mWifiManager = (WifiManager) getSystemService(WIFI_SERVICE); addPreferencesFromResource(R.xml.device_info_status); - mBatteryLevel = findPreference(KEY_BATTERY_LEVEL); - mBatteryStatus = findPreference(KEY_BATTERY_STATUS); + // mBatteryLevel = findPreference(KEY_BATTERY_LEVEL); + // mBatteryStatus = findPreference(KEY_BATTERY_STATUS); mBtAddress = findPreference(KEY_BT_ADDRESS); mWifiMacAddress = findPreference(KEY_WIFI_MAC_ADDRESS); mWimaxMacAddress = findPreference(KEY_WIMAX_MAC_ADDRESS); |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
492 浏览 1 评论
RK3568平台,进入烧录模式,部分电脑提示无法识别,无法烧录
3537 浏览 1 评论
【RK3568 Android11.0】如何在设置-显示-HDMI-分辨率设置中添加3840*2160的选项?
6178 浏览 1 评论
瑞芯微第二代8nm高性能AIOT平台 RK3576 详细介绍
1631 浏览 0 评论
6809 浏览 1 评论
GMT+8, 2024-4-27 17:02 , Processed in 0.517311 second(s), Total 67, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
