新建的项目有很多功能的参考用法demo 红绿蓝色LED灯:
///----Chapter 5 GPIO Test Init ---------------------------------------------------------------------------------
GPIO_MODE_Init(GPIOA,PIN8,GPIO_MODE_OUTPUT); //GPIO 模式
GPIO_MODE_Init(GPIOA,PIN10,GPIO_MODE_OUTPUT); //GPIO 模式
GPIO_MODE_Init(GPIOA,PIN12,GPIO_MODE_OUTPUT); //GPIO 模式
demo UART:
///---- Chapter 15 UART Test Init -------------------------------------------------------------------------------
//uint8_t upack1[20] = {0,1,2,3,4,5,6,7,8,9};
//uint8_t upack2[20] = {0,1,2,3,4,5,6,7,8,9};
//uint8_t upack3[20] = {0,1,2,3,4,5,6,7,8,9};
//uint8_t upack4[20] = {10,1,2,3,4,5,6,7,8,9};
//UART_Init_case1(UART2);//非中断模式
//UART_Init_case1(UART3);//非中断模式
//UART_Init_case1(UART4);//非中断模式
UART_Init_IT_case1(UART1);//中断模式
//UART_Init_IT_case1(UART4);//中断模式
Interrupt_Enable(UART1_int_ID);//CLIC使能单个中断
UART1->CTRL |= 0x00000001U; //清除中断标志位,防止开机先进一次中断
//Interrupt_Enable(UART4_int_ID);//CLIC使能单个中断
SYS_Interrupt_Enable();//CLIC开总中断
//printf("uart init:rn");
串口控制a8
GPIO_Write(GPIOA,PIN8,GPIO_RESET);
10000ms a10
GPIO_Toggle(GPIOA,PIN10); //GPIO 翻转
- #include "headfile.h"
- void mp_receive_data(uint8_t *buf, uint16_t *len)
- uint8_t rxlen = UART1_RX_CNT;
- uint16_t i = 0;
- *len = 0; //默认为0
- Delay32M_ms(10); //等待40ms,连续超过10ms没有接收到一个数据,则认为接收结束
- if (rxlen == UART1_RX_CNT && rxlen) //接收到了数据,且接收完成了
- for (i = 0; i < rxlen; i++)
- buf[i] = uart_dev.rxbuf[i];
- *len = UART1_RX_CNT; //记录本次数据长度
- UART1_RX_CNT = 0; //清零
- uart_dev.frameok=1; //标记完成一帧数据接收
- // getData=0; //数据接收完成,标志位清零
- #define Max_Column 128
- uint8_t ReceiveBuff[RECV_LEN];
- int main(void)
- uint16_t rlen=0;
- uart_dev.rxlen=0;
- ///----System Init ---------------------------------------------------------------------------------------------
- CLIC_Init();//系统中断配置
- System_Clock_Init();//系统时钟初始化
- ///----Chapter 3 LowPower Test Init ---------------------------------------------------------------------------------
- //低功耗测功耗需要IO不能悬空
- //Delay32M_ms(5000);
- //LowPower_Config_case1();//所有IO设置为输入,下拉
- //LowPower_Config_case2();//所有IO设置为输入,上拉
- //使用外部中断唤醒
- //GPIO_EXIT_Init_case1(GPIOA, PIN2);//检测高电平
- //Interrupt_Level(EXIT2_int_ID, INT_LEVEL0);//CLIC设置中断抢占级别
- //Interrupt_Enable(EXIT2_int_ID);//CLIC使能EXIT中断
- //SYS_Interrupt_Enable();//CLIC开总中断
- //配置不同低功耗模式
- //System_Halt();//待机模式 halt1
- //System_Sleep();//睡眠模式 halt2
- //System_Powerdown();//掉电模式 powerdown1
- //System_DeepPwd();//掉电模式 powerdown2
- ///----Chapter 5 GPIO Test Init ---------------------------------------------------------------------------------
- GPIO_MODE_Init(GPIOA,PIN8,GPIO_MODE_OUTPUT); //GPIO 模式
- GPIO_MODE_Init(GPIOA,PIN10,GPIO_MODE_OUTPUT); //GPIO 模式
- GPIO_MODE_Init(GPIOA,PIN12,GPIO_MODE_OUTPUT); //GPIO 模式
- //GPIO_MODE_Init(GPIOA,PIN14,GPIO_MODE_OUTPUT); //GPIO 模式
- //GPIO_MODE_Init(GPIOA,PIN15,GPIO_MODE_OUTPUT); //GPIO 模式
- //GPIO_Write(GPIOA,PIN8,GPIO_SET); //GPIO 输出
- //GPIO_Write(GPIOA,PIN10,GPIO_SET); //GPIO 输出
- //GPIO_Write(GPIOA,PIN12,GPIO_SET); //GPIO 输出
- //GPIO_Write(GPIOA,PIN14,GPIO_RESET); //GPIO 输出
- //GPIO_Write(GPIOA,PIN15,GPIO_RESET); //GPIO 输出
- //GPIO_Toggle(GPIOA,PIN15); //GPIO 翻转
- //GPIO_MODE_Init(GPIOA,PIN15,GPIO_MODE_INTPUT); //GPIO 模式
- for(uint8_t i=0;i<10;i++)
- GPIO_Toggle(GPIOA,PIN8); //GPIO 翻转
- Delay32M_ms(100);
- ///---- Chapter 6 EXIT Test Init -------------------------------------------------------------------------------------
- //GPIO_EXIT_Init_case2(GPIOA, PIN2);//检测低电平
- //GPIO_EXIT_Init_case3(GPIOA, PIN2);//检测上升沿
- //GPIO_EXIT_Init_case4(GPIOA, PIN2);//检测下降沿
- //载波检测中断
- //CAW_Init();//载波检测
- //Interrupt_Enable(CAW_int_ID);//CLIC使能中断
- ///---- Chapter 7 RTC Test Init --------------------------------------------------------------------------------------
- //RTC_Init_case1();
- ///---- Chapter 8 IWDG Test Init -------------------------------------------------------------------------------------
- //IWDG_Init(9000); //配置看门狗计数值(时钟频率3K)
- //Delay32M_ms(1000);
- //IWDG_Start(); //启动看门狗
- //IWDG_Refresh(); //喂狗
- ///---- Chapter 9 timer Test Init ------------------------------------------------------------------------------------
- //GPIO_MODE_Init(GPIOB,PIN11,GPIO_MODE_OUTPUT); //GPIO 模式
- //GPIO_MODE_Init(GPIOA,PIN9,GPIO_MODE_OUTPUT);
- //GPIO_MODE_Init(GPIOA,PIN11,GPIO_MODE_OUTPUT);
- //GPIO_MODE_Init(GPIOA,PIN13,GPIO_MODE_OUTPUT);
- //外设配置
- //Timer1_UpCounting_Mode_Init();//向上计数
- //Timer1_6StepPWM_Mode_Init();//6stepPWM输出
- //Timer2_UpCounting_Mode_Init();//向上计数
- //Timer2_DownCounting_Mode_Init();//向下计数
- //Timer2_ExternalClock_Mode_Init();//外部时钟
- //Timer2_InputCapture_Mode_Init();//输入捕获
- //Timer2_PWM_InputCapture_Mode_Init();//PWM输入捕获
- //Timer2_Input_XOR_Mode_Init();//输入异或
- //Timer2_PWM_Mode_Init();//PWM输出
- //Timer2_6StepPWM_Mode_Init();//6stepPWM输出
- //设置中断优先级
- //Interrupt_Level(TIMER1_updata_int_ID, INT_LEVEL1);//CLIC设置中断抢占级别
- //使能外设中断
- //Interrupt_Enable(TIMER1_break_int_ID);//CLIC使能中断
- //Interrupt_Enable(TIMER1_updata_int_ID);//CLIC使能中断
- //Interrupt_Enable(TIMER1_capture_compare_int_ID);//CLIC使能中断
- //Interrupt_Enable(TIMER1_trigger_comm_int_ID);//CLIC使能中断
- //Interrupt_Enable(TIMER2_break_int_ID);//CLIC使能中断
- //Interrupt_Enable(TIMER2_updata_int_ID);//CLIC使能中断
- //Interrupt_Enable(TIMER2_capture_compare_int_ID);//CLIC使能中断
- //Interrupt_Enable(TIMER2_trigger_comm_int_ID);//CLIC使能中断
- //使能系统总中断
- ///---- Chapter 10 WUP Test Init -------------------------------------------------------------------------------------
- //GPIO_MODE_Init(GPIOA,PIN2,GPIO_MODE_OUTPUT);
- //GPIO_MODE_Init(GPIOA,PIN3,GPIO_MODE_OUTPUT);
- //WUP_Init_case1(9000);//设置中断周期,使能WUP中断
- //Interrupt_Enable(WUP_int_ID);//CLIC使能中断
- //配置不同低功耗模式
- ///---- Chapter 11 ADC Test Init -------------------------------------------------------------------------------------
- ///---- Chapter 12 I2C Test Init -------------------------------------------------------------------------------------
- //I2C_Init_case2();//ready中断模式
- //I2C_Init_case3();//error中断模式
- //I2C_Init_case4();//ready & error中断模式
- //Interrupt_Enable(I2C_ready_int_ID);//CLIC使能i2c_ready中断
- //Interrupt_Enable(I2C_error_int_ID);//CLIC使能i2c_error中断
- ///---- Chapter 13 SPI1 Test Init ------------------------------------------------------------------------------------
- //uint8_t sTxpack[10] = {0,1,2,3,4,5,6,7,8,9};
- //uint8_t sRxpack[10] = {0,1,2,3,4,5,6,7,8,9};
- //uint8_t REG_Data;
- //SPI1 Init Test
- //SPI_Init_case1(SPI1);//非中断模式
- //SPI1_CSN_Init_case1();//CFG: CE-GPIO7,CSN-GPIO8
- //SPI_Init_case2(SPI1);//中断模式
- //Interrupt_Enable(SPI1_int_ID);//CLIC使能单个中断
- //SPI2 Init Test
- //SPI_Init_case1(SPI2);//非中断模式
- //SPI2_CSN_Init_case1();//CFG: CE-GPIO7,CSN-GPIO8
- //SPI_Init_case2(SPI2);//中断模式
- //Interrupt_Enable(SPI2_int_ID);//CLIC使能单个中断
- ///---- Chapter 15 UART Test Init -------------------------------------------------------------------------------
- //uint8_t upack1[20] = {0,1,2,3,4,5,6,7,8,9};
- //uint8_t upack2[20] = {0,1,2,3,4,5,6,7,8,9};
- //uint8_t upack3[20] = {0,1,2,3,4,5,6,7,8,9};
- //uint8_t upack4[20] = {10,1,2,3,4,5,6,7,8,9};
- //UART_Init_case1(UART2);//非中断模式
- //UART_Init_case1(UART3);//非中断模式
- //UART_Init_case1(UART4);//非中断模式
- UART_Init_IT_case1(UART1);//中断模式
- //UART_Init_IT_case1(UART4);//中断模式
- Interrupt_Enable(UART1_int_ID);//CLIC使能单个中断
- UART1->CTRL |= 0x00000001U; //清除中断标志位,防止开机先进一次中断
- //Interrupt_Enable(UART4_int_ID);//CLIC使能单个中断
- SYS_Interrupt_Enable();//CLIC开总中断
- //printf("uart init:rn");
- ///---- Chapter 16 LV Test Init --------------------------------------------------------------------------------------
- //LV_Init_case1(12);//设置低压报警阈值
- //LV_Interrupt_Enable();//使能低压报警中断
- //Interrupt_Enable(LV_int_ID);//CLIC使能单个中断
- ///---- Chapter 17 RANDGEN Test Init ---------------------------------------------------------------------------------
- //uint32_t rand_data;
- ///---- Chapter 18 compare Test Init ---------------------------------------------------------------------------------
- //COPM1_Init();//COPM1
- //Interrupt_Enable(COMP1_int_ID);//CLIC使能单个中断
- //COPM2_Init();//COPM2
- //Interrupt_Enable(COMP2_int_ID);//CLIC使能单个中断
- //COPM3_Init();//COPM3
- //Interrupt_Enable(COMP3_int_ID);//CLIC使能单个中断
- ///---- Chapter 22 flash Test Init ----------------------------------------------------------------------------------
- //NVR_RW_Test();//NVR read and write test
- //Flash_RW_Test();
- ///---- 系统总中断控制 -------------------------------------------------------------------------------------------------
- //SYS_Interrupt_Disable();//CLIC关总中断
- adc_pack[0]=read_csr(mcycle);
- adc_pack[1]=read_csr(mcycle);
- ee_printf("nHello CSM32RV20:n");
- ee_printf("mcycle:%d n",read_csr(mcycle));//比如mcycle这一CSR用于处理器运行的时钟周期计数
- ee_printf("read_csr(mcycle):%d n",adc_pack[1]-adc_pack[0]);//比如mcycle这一CSR用于处理器运行的时钟周期计数
- ee_printf("CMU->OSC_SR:%x n",CMU->OSC_SR );
- if(CMU->OSC_SR==210 ) ee_printf("CMU->OSC_SR:210,OSC 时钟已稳定,RCOSC 时钟已稳定,:OSC 在为 MCU 提供时钟;OSC 在为外设提供时钟; n" );
- //printf("Hello CSM32RV20:rn");
- ee_printf("请输入:on 或者off (开灯/关灯)rn");
- uint32_t rt_tick1 = rt_tick_get();
- uint32_t rt_tick2 = rt_tick_get();
- Delay32M_ms(1000);
- // OLED_Light();
- // OLED_DrawBMP(0,0,128,8,BAD_APPLE);
- while(1)
- mp_receive_data(ReceiveBuff, &rlen);
- if(uart_dev.frameok==1) //如果接收到数据
- ee_printf("收到数据:");
- Uart_Send(UART1,(uint8_t *)ReceiveBuff,rlen);
- ee_printf("rn");
- uint8_t aton= (uint8_t)ReceiveBuff[0];
- uint32_t data=0;
- switch (aton) {
- case 111://"o"
- if(1==rlen) break;
- if(ReceiveBuff[1]=='n')
- GPIO_Write(GPIOA,PIN8,GPIO_RESET);
- ee_printf("灯开了!rn");
- else if((ReceiveBuff[1]=='f')&&(ReceiveBuff[2]=='f'))
- GPIO_Write(GPIOA,PIN8,GPIO_SET);
- ee_printf("关灯了!rn");
- else
- break;
- default:
- break;
- uart_dev.frameok=0;
- uart_dev.rxlen=0;
- if( rt_tick_get()%1000==0) ee_printf("time is %u s n",rt_tick_get()/1000);
- if(!( rt_tick_get()- rt_tick1< 10000)){
- rt_tick1 = rt_tick_get() ;
- GPIO_Toggle(GPIOB,PIN8);
- GPIO_Toggle(GPIOA,PIN10); //GPIO 翻转
- // ee_printf("mcycle:%u n",read_csr(mcycle));
- ee_printf("rt_tick_get:%u n", rt_tick_get());
- ee_printf("RTC_MTIME->mtime:%lu ",RTC_MTIME->mtime);
- // ee_printf("type?RTC_MTIME->mtime:%lu n",type(RTC_MTIME->mtime));
- ee_printf("RTC_MTIME->mtime0-7B:");
- for (uint8_t i = 0; i < 8; i++)
- ee_printf("%x ",_REG8(0x0200bff8UL,i));
- ee_printf("nRTC_MTIME->mtime:%u n",_REG32(0x0200bff8UL,4));
- ee_printf("RTC_MTIMECMP->mtimecmp:%lu n",RTC_MTIMECMP->mtimecmp);
- // ee_printf("type?RTC_MTIME->mtime:%lu n",type(RTC_MTIMECMP->mtimecmp));
- ee_printf("->?RTC_MTIME->mtime:%p n",RTC_MTIMECMP->mtimecmp);
- ee_printf("RTC_MTIMECMP->mtimecmp0-7B:");
- ee_printf("%x ",_REG8(0x02004000UL,i));
- ee_printf(" n");
- // Delay32M_ms(500);
- //Delay16M_ms(500);
- //Delay16M_us(500000);
- //printf("main:rn");
- ///---- Chapter 6 EXIT test ---------------------------------------------------------------------------------
- //delay16M_ms(500);
- ///---- Chapter 8 IWDG test ---------------------------------------------------------------------------------
- //IWDG_Refresh();
- ///---- Chapter 9 Timer test --------------------------------------------------------------------------------
- //---- soft break --------------------------------------------------------------------------------------
- //delay16M_ms(100);
- //TIMER2->BDTR |= 1 <<15;//BDTR[15]-MOE-主输出使能:0-关闭,1-使能
- //TIMER2->EGR |= 1 <<7;//EGR[7]-BG-产生刹车事件
- //---- soft COM ----------------------------------------------------------------------------------------
- //TIMER2->EGR = 1 <<5;//EGR[5]-COMG-捕获/比较事件,产生控制更新
- //---- generate oxr ------------------------------------------------------------------------------------
- Delay16M_ms(10);//1
- GPIO_Write(GPIOA,PIN9,GPIO_SET);
- GPIO_Write(GPIOA,PIN11,GPIO_RESET);
- GPIO_Write(GPIOA,PIN13,GPIO_SET);
- Delay16M_ms(10);//2
- GPIO_Write(GPIOA,PIN13,GPIO_RESET);
- Delay16M_ms(10);//3
- GPIO_Write(GPIOA,PIN11,GPIO_SET);
- Delay16M_ms(10);//4
- GPIO_Write(GPIOA,PIN9,GPIO_RESET);
- Delay16M_ms(10);//5
- Delay16M_ms(10);//6
- ///---- Chapter 11 ADC test ---------------------------------------------------------------------------------
- ///---- Chapter 12 I2C test ---------------------------------------------------------------------------------
- //I2C_Write(0x2d,0x55);//适用于非中断模式
- //i2c_data = I2C_Read(0x2d);//适用于非中断模式
- //printf("data:%xrn",i2c_data);
- //I2C_Write(0x2d,0xaa);//适用于非中断模式
- //I2C_Write_IT(0x2d,0x55);//适用于中断模式
- ///---- Chapter 13 SPI test --------------------------------------------------------------------------------
- //SPI1 Test
- //SPI_Transceive(SPI1,sTxpack,sRxpack,10);//非中断模式
- //SPI1_RW_reg(WRITE_REG+0x05,0x53);//读写Si24R1寄存器
- //REG_Data = SPI1_RW_reg(READ_REG+0x05,0);//读写Si24R1寄存器
- //printf("rnREG5:%02x",REG_Data);
- //SPI2 Test
- //SPI_Transceive(SPI2,sTxpack,sRxpack,10);//非中断模式
- //SPI2_RW_reg(WRITE_REG+0x05,0x53);//读写Si24R1寄存器
- //REG_Data = SPI2_RW_reg(READ_REG+0x05,0);//读写Si24R1寄存器
- ///---- Chapter 15 UART Test ------------------------------------------------------------------------------------
- //---- 非中断模式数据回环测试 -------------------------------------------------------------------------------------
- //Uart_Reveive(UART1,upack1,10);//适用于非中断发送模式
- //Uart_Send(UART1,upack1,10);//适用于非中断发送模式
- //Uart_Reveive(UART2,upack2,10);//适用于非中断发送模式
- //Uart_Send(UART2,upack2,10);//适用于非中断发送模式
- //Uart_Reveive(UART3,upack3,10);//适用于非中断发送模式
- //Uart_Send(UART3,upack3,10);//适用于非中断发送模式
- //Uart_Reveive(UART4,upack4,10);//适用于非中断发送模式
- //Uart_Send(UART4,upack4,10);//适用于非中断发送模式
- //---- 中断模式数据回环测试 --------------------------------------------------------------------------------------
- //UART1_putbuf(UART1_getbuf());
- //---- printf测试 ----------------------------------------------------------------------------------------
- //printf("Hellow-01234568789abcdefghijklmnopqrstuvwxyzrn");
- ///---- Chapter 17 RANDGEN test -----------------------------------------------------------------------------
- //rand_data = RAND_Get();//生成随机数
- //printf("rand:0x%08x,%urn",rand_data,rand_data);
- ///---- Chapter 18 COMPARE test -----------------------------------------------------------------------------
- //if(COMP1->irq&0x1)
- //COMP1->irq = 1;
- //delay16M_ms(10);
- return 0;
复制代码
com:
Hello CSM32RV20:
mcycle:112549883
read_csr(mcycle):2
CMU->OSC_SR:d2
收到数据:
rt_tick_get:11529
RTC_MTIME->mtime:36899472 RTC_MTIME->mtime0-7B:4a 4c 33 2 0 0 0 0
RTC_MTIME->mtime:0
RTC_MTIMECMP->mtimecmp:36934400
->?RTC_MTIME->mtime:0233b880
RTC_MTIMECMP->mtimecmp0-7B:0 3 34 2 0 0 0 0
val:6700 avr:14062513 981.4mV 2108.0mV
time:0 day 0 hour' 0:16
rt_tick_get:21537
RTC_MTIME->mtime:68926545 RTC_MTIME->mtime0-7B:c fd 1c 4 0 0 0 0
RTC_MTIME->mtime:0
RTC_MTIMECMP->mtimecmp:68960000
->?RTC_MTIME->mtime:041c6480
RTC_MTIMECMP->mtimecmp0-7B:0 af 1c 4 0 0 0 0
收到数据:on
灯开了!
rt_tick_get:61655
RTC_MTIME->mtime:197302775 RTC_MTIME->mtime0-7B:c8 dd c2 b 0 0 0 0
RTC_MTIME->mtime:0
RTC_MTIMECMP->mtimecmp:197337600
->?RTC_MTIME->mtime:0bc34780
RTC_MTIMECMP->mtimecmp0-7B:0 92 c3 b 0 0 0 0
time is 63 s
收到数据:off
关灯了!
