51proteus仿真:I2c总线和EEPROM2404的读写
仿真电路图:
仿真程序:
#include
#include #define uchar unsigned char
#define uint unsigned int ***it SCL=P1^0;
***it SDA=P1^1; void delay(void)
_nop_();
_nop_();
_nop_();
_nop_(); } void Initi2C(void)
SDA = 1;
SCL = 1;
} void I2CStart(void)
SDA=1;
delay();
SCL=1;
delay();
SDA=0;
delay();
SCL=0;
} void I2CStop(void)
SCL=0;
delay();
SDA=0;
delay();
SCL=1;
delay();
SDA=1;
delay();
void I2CSend(uchar byte)
uchar mask;
uchar i,j;
mask=0x80; for(i=0;i<8;i++)
SCL=0;
delay();
if((mask & byte)==0)
SDA=0;
else
SDA=1;
mask>>=1;
delay();
SCL=1;
delay(); }
SCL=0;
SDA=1;
delay();
SCL=1;
j=SDA;
delay();
SCL=0;
} void write_eeprom(uchar addr, uchar databyte)
I2CStart();
I2CSend(0xa0);
I2CSend(addr);
I2CSend(databyte);
I2CStop();
} uchar I2CRead(void)
uchar byte;
uchar i; byte = 0;
for(i = 0; i < 8; i++)
SCL = 0;
SDA = 1;
delay();
SCL = 1;
delay();
byte <<= 1;
if(SDA == 1)
byte |= 0x01;
delay();
SCL = 0;
SDA = 1;
delay();
SCL = 1;
delay();
SCL = 0;
return byte; } uchar read_eeprom(uchar addr)
uchar databyte; I2CStart();
I2CSend(0xa0);
I2CSend(addr);
I2CStart();
I2CSend(0xa1);
databyte = I2CRead();
I2CStop(); return databyte;
main()
uchar addr=0x00,databyte=0xaa;
uchar c=0;
uint i;
InitI2C(); while(1)
{ write_eeprom(addr,databyte);
for(i = 0; i < 1000; i++)
delay();
} c = read_eeprom(addr); P2=c;
