扫一扫,分享给好友
1个回答
1. 电路图
2. 程序 主函数 #include #include #include #include void timer_isr()interrupt 1 //中断服务函数 { TL0 = (65536-2000) %256; //TL0重置函数 TH0 = (65536-2000)/256; //TH0重置函数 cp++; if(cp>=250) //0.5s { cp1++; cp = 0; flash = ~flash; //0.5s - 闪烁 if(cp1>=2) //1s { if(mode==0) //调整时,时间停止 sec++; cp1 = 0; if(sec>=60) //1min { min++; sec = 0; if(min>60) //1h { hour++; min = 0; if(hour>=24)hour = 0; } } } } P0 = 0xff; //消隐 switch(mode) { case 0:dis_play0();break; //正常 case 1:dis_play1();break; //调时 case 2:dis_play2();break; //调分 case 3:dis_play3();break; //调秒 case 4:dis_play4();break; //调闹时 case 5:dis_play5();break; //调闹分 } i++; if(i>=8)i = 0; } void timer0_init() //中断初始化函数 { TMOD = 0x01; //方式一 TL0 = (65536-2000)%256; //TL0 预置,65536十六进制低8位。 TH0 = (65536-2000)/256; //TH0 预置,65536十六进制高8位。 EA = 1; //CPU中断开放 ,总中断打开 ET0 = 1; //定时计数器T0的溢出终端控制位,T0中断打开 TR0 = 1; //定时计数器T0的启停控制位,启动T0 } void main() { timer0_init(); //timer0初始化,为中断做准备 while(1) { key(); if(hour == hour_n && min == min_n) //闹钟到时间,蜂鸣器响 { P3_2 = !P3_2; delay(50); } } } 定义 #define uchar unsigned char; #define uint unsigned int; ***it key_set = P2^0; ***it key_up = P2^1; ***it key_down = P2^2; ***it P3_0 = P3^0; ***it P3_2 = P3^2; //蜂鸣器 ***it P2_4 = P2^4; uchar sec = 45,min = 12,hour; uchar sec_t,min_t,hour_t; uchar min_n = 13,hour_n; uchar cp,cp1; uchar flash,mode,i; code uchar seven_seg[] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92, 0x82,0xf8,0x80,0x90}; 按键函数 void delay(unsigned int x) //延时函数 { while(x--); } void key() //按键函数 { P2_4 = 0; if(key_set==0) //如果调整按键按下 { delay(300); //消抖 if(key_set==0) //如果调整按键真的按下 { while(key_set==0); mode++; if(mode>=6)mode = 0; //mode=0,退出调整 hour_t = hour; min_t = min; sec_t = sec; } } if(key_up==0) //如果增加按键按下 { delay(300); //消抖 if(key_up==0) //如果增加按键真的按下 { while(key_up==0); if(mode==1)hour_t++;if(hour_t>24)hour_t = 23;hour = hour_t; if(mode==2)min_t++;if(min_t>60)min_t = 59;min=min_t; if(mode==3)sec_t++;if(sec_t>60)sec_t = 59;sec = sec_t; if(mode==4)hour_n++;if(hour_n>24)hour_n = 23; if(mode==5)min_n++;if(min_n>60)min_n = 59; } } if(key_down==0) //如果减小按键按下 { delay(300); //消抖 if(key_down==0) //如果减小按键真的按下 { while(key_down==0); if(mode==1)hour_t--;if(hour_t<0)hour_t = 0;hour = hour_t; if(mode==2)min_t--;if(min_t<0)min_t = 0;min=min_t; if(mode==3)sec_t--;if(sec_t<0)sec_t = 0;sec = sec_t; if(mode==4)hour_n--;if(hour_n<0)hour_n = 0; if(mode==5)min_n--;if(min_n<0)min_n = 0; } } } 显示函数 void display(unsigned char x1,x2) { P3_0 = 0; //锁存器关 P0 = x1; //输入位选 P3_0 = 1; //锁存器开 P3_0 = 0; //锁存器关 P0 = x2; //输入段选 } void dis_play0() //mode = 0 正常 显示 { switch(i) { case 0:display(0x01,seven_seg[sec%10]);break; //显示秒个位 case 1:display(0x02,seven_seg[sec/10]);break; //显示秒十位 case 2:display(0x04,0xbf|flash);break; //显示 - 闪烁 case 3:display(0x08,seven_seg[min%10]);break; //显示分个位 case 4:display(0x10,seven_seg[min/10]);break; //显示分十位 case 5:display(0x20,0xbf|flash);break; //显示 - 闪烁 case 6:display(0x40,seven_seg[hour%10]);break; //显示时个位 case 7:display(0x80,seven_seg[hour/10]);break; //显示时十位 } } void dis_play1() //mode = 1 调时 { switch(i) { case 0:display(0x01,seven_seg[sec_t%10]);break; //显示调秒个位 case 1:display(0x02,seven_seg[sec_t/10]);break; //显示调秒十位 case 2:display(0x04,0xbf);break; //显示 - case 3:display(0x08,seven_seg[min_t%10]);break; //显示调分个位 case 4:display(0x10,seven_seg[min_t/10]);break; //显示调分十位 case 5:display(0x20,0xbf);break; //显示 - case 6:display(0x40,seven_seg[hour_t%10]|flash);break; //显示调时个位 闪烁 case 7:display(0x80,seven_seg[hour_t/10]|flash);break; //显示调时十位 闪烁 } } void dis_play2() //mode = 2 调分 { switch(i) { case 0:display(0x01,seven_seg[sec_t%10]);break; //显示调秒个位 case 1:display(0x02,seven_seg[sec_t/10]);break; //显示调秒十位 case 2:display(0x04,0xbf);break; //显示 - case 3:display(0x08,seven_seg[min_t%10]|flash);break; //显示调分个位 闪烁 case 4:display(0x10,seven_seg[min_t/10]|flash);break; //显示调分十位 闪烁 case 5:display(0x20,0xbf);break; //显示 - case 6:display(0x40,seven_seg[hour_t%10]);break; //显示调时个位 case 7:display(0x80,seven_seg[hour_t/10]);break; //显示调时十位 } } void dis_play3() //mode = 3 调秒 { switch(i) { case 0:display(0x01,seven_seg[sec_t%10]|flash);break; //显示调秒个位 闪烁 case 1:display(0x02,seven_seg[sec_t/10]|flash);break; //显示调秒十位 闪烁 case 2:display(0x04,0xbf);break; //显示 - case 3:display(0x08,seven_seg[min_t%10]);break; //显示调分个位 case 4:display(0x10,seven_seg[min_t/10]);break; //显示调分十位 case 5:display(0x20,0xbf);break; //显示 - case 6:display(0x40,seven_seg[hour_t%10]);break; //显示调时个位 case 7:display(0x80,seven_seg[hour_t/10]);break; //显示调时十位 } } void dis_play4() //mode = 4 调闹时 { switch(i) { case 0:display(0x01,0xbf);break; //显示 - case 1:display(0x02,0xbf);break; //显示 - case 2:display(0x04,0xbf);break; //显示 - case 3:display(0x08,seven_seg[min_n%10]);break; //显示闹分个位 case 4:display(0x10,seven_seg[min_n/10]);break; //显示闹分十位 case 5:display(0x20,0xbf);break; //显示 - case 6:display(0x40,seven_seg[hour_n%10]|flash);break; //显示闹时个位 闪烁 case 7:display(0x80,seven_seg[hour_n/10]|flash);break; //显示闹时十位 闪烁 } } void dis_play5() //mode = 5 调闹分 { switch(i) { case 0:display(0x01,0xbf);break; //显示 - case 1:display(0x02,0xbf);break; //显示 - case 2:display(0x04,0xbf);break; //显示 - case 3:display(0x08,seven_seg[min_n%10]|flash);break; //显示闹分个位 闪烁 case 4:display(0x10,seven_seg[min_n/10]|flash);break; //显示闹分十位 闪烁 case 5:display(0x20,0xbf);break; //显示 - case 6:display(0x40,seven_seg[hour_n%10]);break; //显示闹时个位 case 7:display(0x80,seven_seg[hour_n/10]);break; //显示闹时十位 } } |
只有小组成员才能发言,加入小组>>
2423 浏览 0 评论
973浏览 2评论
599浏览 1评论
361浏览 0评论
GMT+8, 2024-10-1 18:35 , Processed in 1.155334 second(s), Total 48, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
