测试代码:
int hello(int k) { return -k; } int main(void) { int i,k; i = 10; k = -(-(-(-i))); hello(k); while(1){ hello(i); } } 编译器:uVsion V4.10 RealView MDK-ARM 优化级别:0 9: int main(void) 10: { 11: int i,k; 12: 13: 14: i = 10; 0x080001AA 220A MOVS r2,#0x0A 15: k = -(-(-(-i))); 0x080001AC 4250 RSBS r0,r2,#0 0x080001AE 4240 RSBS r0,r0,#0 0x080001B0 4240 RSBS r0,r0,#0 0x080001B2 4243 RSBS r3,r0,#0 16: hello(k); 17: 0x080001B4 4618 MOV r0,r3 0x080001B6 F7FFFFF5 BL.W hello (0x080001A4) 18: while(1){ 0x080001BA E002 B 0x080001C2 19: hello(i); 0x080001BC 4610 MOV r0,r2 0x080001BE F7FFFFF1 BL.W hello (0x080001A4) 0x080001C2 E7FB B 0x080001BC 编译结果看出,RealView MDK-ARM 优化级别为0时,丫还真的完全按部就班。 优化级别:1 9: int main(void) 10: { 11: int i,k; 12: 13: 14: i = 10; 15: k = -(-(-(-i))); 0x080001A8 210A MOVS r1,#0x0A 16: hello(k); 17: 18: while(1){ 0x080001AA 4608 MOV r0,r1 0x080001AC F7FFFFFA BL.W hello (0x080001A4) 19: hello(i); 0x080001B0 4608 MOV r0,r1 0x080001B2 F7FFFFF7 BL.W hello (0x080001A4) 18: while(1){ 0x080001B6 E7FB B 0x080001B0 这会聪明多了,知道“k = -(-(-(-i)));”等价于“k = i;”,而且还知道对于整个程序,k = -(-(-(-i))); 根本就是一句废话。 优化级别:2 9: int main(void) 10: { 11: int i,k; 12: 13: 14: i = 10; 15: k = -(-(-(-i))); 16: hello(k); 17: 18: while(1){ 0x080001A8 E7FE B main (0x080001A8) 不用往下测了,这已经是最优化的了,都直接编译成死循环了,啥也不干。 编译器:IAR Embedded Workbench IDE EWARM V5.20 优化级别:None main: 0000013C E92D4038 STMDB SP!, {R3,R4,R5,LR} i = 10; 00000140 E3A0000A MOV R0, #0xA 00000144 E1B04000 MOVS R4, R0 k = -(-(-(-i))); 00000148 E1B05004 MOVS R5, R4 hello(k); 0000014C E1B00005 MOVS R0, R5 00000150 EBFFFFF7 BL hello ; 0x134 hello(i); ??main_0: 00000154 E1B00004 MOVS R0, R4 00000158 EBFFFFF5 BL hello ; 0x134 0000015C EAFFFFFC B ??main_0 ; 0x154 IAR不认可废话,使用冗余指令时可要注意了。 优化级别:Low main: 00000164 E92D4010 STMDB SP!, {R4,LR} i = 10; 00000168 E3A0400A MOV R4, #0xA hello(k); 0000016C E1B00004 MOVS R0, R4 00000170 EBFFFFF9 BL hello ; 0x15C hello(i); ??main_0: 00000174 E1B00004 MOVS R0, R4 00000178 EBFFFFF7 BL hello ; 0x15C 0000017C EAFFFFFC B ??main_0 ; 0x174 好像没什么实际性的提高,只是优化了 k = -(-(-(-i))); 直接用 i 代替 k . 优化级别:Medium main: 00000198 E92D5000 STMDB SP!, {R12,LR} hello(k); 0000019C E3A0000A MOV R0, #0xA 000001A0 EBFFFFFA BL hello ; 0x190 hello(i); ??main_0: 000001A4 E3A0000A MOV R0, #0xA 000001A8 EBFFFFF8 BL hello ; 0x190 000001AC EAFFFFFC B ??main_0 ; 0x1A4 这个,这个,不说了。和Low级别有区别吗?仅仅少用了一个R4。 编译器:IAR Embedded Workbench IDE EW78K V4.60 PS:这个是8位机,处理器为NEC 78K0 - uPD78F0485 优化级别:None main: 02C5 B3 PUSH BC 02C6 B5 PUSH DE i = 10; 02C7 140A00 MOVW DE, #0x000A k = -(-(-(-i))); 02CA C4 MOVW AX, DE hello(k); 02CB 9ABD02 CALL hello ; (0x02BD) hello(i); 02CE C4 MOVW AX, DE 02CF 9ABD02 CALL hello ; (0x02BD) 02D2 FAFA BR 0x02CE 秉承IAR的一贯作风:不说废话。 优化级别:Low main: 02C5 B5 PUSH DE i = 10; 02C6 140A00 MOVW DE, #0x000A k = -(-(-(-i))); 02C9 C4 MOVW AX, DE hello(k); 02CA 9ABD02 CALL hello ; (0x02BD) hello(i); 02CD C4 MOVW AX, DE 02CE 9ABD02 CALL hello ; (0x02BD) 02D1 FAFA BR 0x02CD 没啥优化,只是堆栈少用了2字节。 优化级别:Medium main: 02C5 100A00 MOVW AX, #0x000A 02C8 9ABD02 CALL hello ; (0x02BD) hello(i); 02CB 100A00 MOVW AX, #0x000A 02CE 9ABD02 CALL hello ; (0x02BD) 02D1 FAF8 BR 0x02CB 再少2字节堆栈,看来8位机优化时优先对资源作优化。 结论: 还是 uVsion 比较听话,要她老实时,丫绝无怨言,按部就班,踏踏实实。而一旦让她表现时,她的疯狂总会给你意想不到的刺激。加了优化时调试程序可要注意了,这个编译器只要你给了她权利,她可是很喜欢多管闲事的。 而相比之下,IAR可要自主一点,她有自己的想法,不管你是否愿意。 |
相关推荐 |
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
140 浏览 0 评论
483 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
815 浏览 0 评论
1346 浏览 2 评论
804 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16904 浏览 31 评论
/9
GMT+8, 2025-12-2 19:35 , Processed in 0.693581 second(s), Total 34, Slave 27 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1563
