1个回答
盛群半导体(Holtek)公司的HT98R068是双向无线电应用专用SOC MCU。在音讯处理功能方面, 包括预加重/去加重,压扩,可程序扰频设定,DTMF 编译码,可程序选择码编译码 及亚音频之CTCSS/DCS编解码。在MCU资源方面, 16kx16 ROM、1K Bytes RAM、34 I/O、内建有8个通道的12位ADC,4个通道的8位DAC,休眠快速唤醒、高低双频系统操作切换、串行传输接口SPI与RTC等功能,可减少外围零件、缩小PCB 尺寸及降低成本。主要是用于模拟无线电对讲机产品如 FRS, MURS, GMRS等市场。本文介绍了HT98R068主要特性和典型应用电路图。
The device is an ASSP MCU for analog two way radio applications such as FRS. This device contains an 8-bit MCU, Audio Processor, ADC, DAC as well as an Operational Amplifier for peripheral interfaces. Additionally there are external interrupt functions and 16K of OTP Program Memory and 1K of SRAM Data Memory for general MCU control application. The Internal Audio Processor supports various programmable functions. These functions include CTCSS/DCSS encoding/decoding, DTMF encoding/decoding, scramble/descramble, VOX, compandor and so on. By connecting to a suitable RF module, the device provides a cost effective and flexible audio RF solution. Applications should include products in the Leisure Radio application area such as General Mobile Radios, Personal Mobile Radios, Multiple User Radios etc. HT98R068主要特性: ●●Operating voltage: 3V~5V ●●Up to 0.25μs instruction cycle with 16MHz system clock ●●OTP Program Memory:16K x 16 ●●Data Memory: 1K x8 ●●Up to 34 bidirectional I/O lines ●●Ocillator type: external 32768Hz crystal -- LXT ●●Internal PLL to generate the system clock ––Input reference clock : 32768Hz ––Output: 2.048MHz x4/x5/x6/x8 (optional) ●●Four operational modes: Normal, Slow, Idle, Sleep ●●Watchdog Timer function with WDT oscillator ●●Real Time Clock function ●●8 channel 12-bit A/D converter ●●4 channel 8-bit D/A converter ●●All instructions executed in one or two instruction cycles ●●Table read instructions ●●63 powerful instructions ●●Up to 10-level subroutine nesting ●●Bit manipulation instruction ●●Low voltage reset function ●●Low voltage detect function ●●SPI interface for external MCU control ●●Two 8-bit and signal 16-bit programmable Timer/Event Counter with overflow interrupt and prescaler ●●Programmable Frequency Divider -- PFD ●●PGA : 5bit Operational Amplifier Gain setup ●●Sub-tone processor ––CTCSS/DCS encode/decode ●●In-band-Tone processor ––DTMF encoder/decode ––Selective call encoder/decoder ––User defined tone encoder/decoder ●●Audio processor ––Pre-emphasis/De-emphasis ––Scrambler ––Compandor ––VOX ●●Package types: 48/64-pin LQFP 201106021001346.gif 图1。HT98R068方框图 20110602100135328.gif 图2。HT98R068典型应用电路图 [localimg=180,130]3[/localimg] [localimg=180,138]4[/localimg] [localimg=180,128]5[/localimg] 详情请见: http://datasheets.maxim-ic.com/en/ds/78M6612-EVM-1.pdf[ |
只有小组成员才能发言,加入小组>>
如何使用STM32+nrf24l01架构把有线USB设备无线化?
2487 浏览 7 评论
请问能利用51单片机和nRF24L01模块实现实时语音无线传输吗?
2268 浏览 5 评论
3063 浏览 3 评论
2732 浏览 8 评论
为什么ucosii上移植lwip后系统进入了HardFault_Handler?
2694 浏览 4 评论
请教各位大咖:有没有接收频率32M左右的芯片推荐的?先感谢啦!
496浏览 1评论
755浏览 0评论
841浏览 0评论
533浏览 0评论
339浏览 0评论
GMT+8, 2024-9-30 03:10 , Processed in 0.949466 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
