TI公司的CC2541是2.4GHz蓝牙低功耗系统级芯片(SoC),支持250kbps, 500kbps, 1Mbps和2Mbps数据速率,具有极好的连接预算,应用时不外接前端,输出功率可编程到0dBm, 1Mbps时的接收灵敏度为-94dBm,主要用在2.4GHz蓝牙低功耗系统,个人2.4GHz系统,人机接口如键盘,鼠标和遥控等,体育和休闲设备,手机附件和消费类电子。本文介绍了CC2541主要特性,方框图, 应用电路图和CC2541评估模块主要特性,电路图和材料清单以及采用TPS62370的CC2541EM电源电路图和材料清单。
The CC2541 is a power-optimized true system-on-chip (SoC) solution for both low energy and proprietary 2.4-GHz applications. It enables robust network nodes to be built with low total bill-of-material costs. The CC2541 combines the excellent performance of a leading RF transceiver with an industry-standard enhanced 8051 MCU, in-system programmable flash memory, 8-KB RAM, and many other powerful supporting features and peripherals. The CC2541 is highly suited for systems where ultralow power consumption is required. This is specified by various operating modes. Short transition times between operating modes further enable low power consumption. The CC2541 is pin-compatible with the CC2540 in the 6-mm × 6-mm QFN40 package, if the USB is not used on the CC2540 and the I2C/extra I/O is not used on the CC2541. CC2541主要特性: 20120228112739245.gif 20120228112739859.gif CC2541 WITH TPS62730 • TPS62730 is a 2-MHz Step-Down Converter With Bypass Mode • Extends Battery Lifetime by up to 20% • Reduced Current in All Active Modes • 30-nA Bypass Mode Current to Support • RF Performance Unchanged • Small Package Allows for Small Solution Size • CC2541 Controllable CC2541应用: • 2.4-GHz Bluetooth low energy Systems • Proprietary 2.4-GHz Systems • Human-Interface Devices (Keyboard, Mouse, Remote Control) • Sports and Leisure Equipment • Mobile Phone Accessories • Consumer Electronics 20120228112741756.gif 图1.CC2541方框图 20120228112742927.gif 图2.CC2541应用电路图 CC2541评估模块 The CC2541 Evaluation Module Kit contains two CC2541 Bluetooth low energy Evaluation Modules, which can be used either as standalone modules (requires a power source and a simple carrier board like the SoC Battery Board or connected to e.g. the SmartRF05EB Evaluation Boards (included in the CC2540DK) for full control from the PC. The evaluation modules can be used as a reference board for prototyping and for verifying the performance of the CC2541 RF IC. CC2541评估模块主要特性: The CC2541EMK includes: 2 x CC2541EM Evaluation Modules 2 x 2.4 GHz Antennas Documentation 20120228112745369.gif 图3.CC2541评估模块外形图 注:CC2541评估模块要和CC2540DK开发套件的SmartRF05EB一起使用。 20120228112746537.gif 图4.CC2541评估模块电路图 CC2541评估模块材料清单见: 20120228112752243.gif 图5.CC2541评估模块采用TPS62370的电源电路图 采用TPS62370的CC2541EM电源材料清单见: xls.gif CC2541EM电源材料清单.rar(50.5 KB)2012-2-28 22:04 上传 -1 详情请见: swrs110a[1].pdf(785.84 KB)2012-2-28 22:05 上传 -1 和 swrr096.zip(820.87 KB)2012-2-28 22:05 上传 -1 以及 swrr095.zip(582.21 KB)2012-2-28 22:04 上传 -1 |
只有小组成员才能发言,加入小组>>
如何使用STM32+nrf24l01架构把有线USB设备无线化?
2339 浏览 7 评论
请问能利用51单片机和nRF24L01模块实现实时语音无线传输吗?
2088 浏览 5 评论
2786 浏览 3 评论
2532 浏览 8 评论
为什么ucosii上移植lwip后系统进入了HardFault_Handler?
2477 浏览 4 评论
546浏览 0评论
561浏览 0评论
328浏览 0评论
145浏览 0评论
GMT+8, 2024-4-27 01:25 , Processed in 0.996033 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
