FUNCtiONAL DESCRIPTION
The ZCC8801 series is a CMOS-based positive low-dropout linear regulator (LDO) featuring 500 mA/ 1.0A that provides high PSRR, high output voltage accuracy, low-noise and low supply current It consists of a voltage reference, an error amplifier, a resistor-ladder for output voltage setting. It also has under-voltage lockout (UVLO), over current/short circuit protection circuit and over temperature shutdown circuit. The ZCC8801 typically has 90mV dropout voltage (DFN1216-8,Iout=500mA,Vout=1.8V) and 180mA dropout voltage (DFN1216-8, Iout=1A, Vout=1.8V) and chip enable function (EN) for long battery life. Excellent ripple rejection, load transient and line transient response make it ideal for the power sources of mobile communication devices or camera modules in low light condition. It can also turn on under full load condition, making it suitable for harsh system environment. The ZCC8801 series LDOs have option for output current limit between 1.0A or 500mA by alternating the LCON pin between “H” or “L” for DFN1216-8 package version. MAIN FEATURES Supply Current (no load) : 85μA (typ.) Supply Current (Standby) : 0.1μA (typ.) Dropout Voltage: 180mV (DFN1216-8, Iout=1A, Vout=1.8V, typ.) High-PSRR 95dB (f=5kHz, Iout=10mA, lower Vout settings, typ.) 85dB (f=5kHz, Iout=150mA, lower Vout settings, typ.) Output Noise: 15μVrms (10-100KHz, 0.9V output voltage settings, typ.) Line Regulation: 0.01%/V Output Voltage Range: 0.85V to 4.3V with 0.05V step, 0.835V(min.) Built-in Short Current Protection Limit: 120mA (LCON=’H’, 1.0A, typ.) Bulit-in Peak Current Protection Limit: 1.7A (LCON=’H’, 1.0A, typ.) Built-in Thermal Shutdown Temperature: 165°C (typ.) Built-in Soft-Start and Inrush Current Suppression APPLICATIONS Portable Device , Tablets and Smartphone Cameras, VCRs and Car Dash Cameras Low Light & Low Noise Cameras Applications Communications and Infrastructure AR or VR Application
ZCC8801-Datasheet-VC1.3.pdf
(8.86 MB, 下载次数: 2
886 浏览 0 评论
1093 浏览 1 评论
1251 浏览 1 评论
1335 浏览 1 评论
使用鑫鼎盛的TX4139直流降压芯片时,目的是输入24V,输出11V,为啥实际测量输出电压为20.2V?
1956 浏览 3 评论
GMT+8, 2024-12-28 14:58 , Processed in 0.633524 second(s), Total 69, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
