` 成果展示: 相关代码已经放在百度网盘上面了。 链接:https://pan.baidu.com/s/188AylEd2QgOiA6YFv01N3A
提取码:e2og
主要原理 原理示意图: 树莓派通过检测人脸位置,大致判断人脸相对自己的位置,然后转换成角度,控制云台运动。
代码编写:
这里主要看一下最重要的代码,就是在获取到一帧图像之后的处理流程,我把它放在slot_camera方法中
- 1 def slot_camera(self):
- 2 if (self.cap.isOpened()):
- 3 self.frame += 1
- 4 # get a frame
- 5 ret, img = self.cap.read()
- 6 height, width, bytesPerComponent = img.shape
- 7 bytesPerLine = bytesPerComponent * width
- 8
- 9 if self.frame % 1 == 0:
- 10 image_p = img.ctypes.data_as(ctypes.c_char_p)
- 11 self.alg_handle.alg_run.restype = ctypes.POINTER(ctypes.c_float)
- 12 result = self.alg_handle.alg_run(image_p, 11, height, width, 4)
- 13
- 14 # cls
- 15 if int(result[0]) == 0:
- 16 pass
- 17 # det
- 18 elif int(result[0]) == 1:
- 19 box_count = int(result[1])
- 20 for j in range(box_count):
- 21 cls = int(result[2 + j * 6 + 0])
- 22 prob = float(result[2 + j * 6 + 1])
- 23 if prob < 0.4:
- 24 continue
- 25 x1 = int(float(result[2 + j * 6 + 2]) * width)
- 26 y1 = int(float(result[2 + j * 6 + 3]) * height)
- 27 x2 = int(float(result[2 + j * 6 + 4]) * width)
- 28 y2 = int(float(result[2 + j * 6 + 5]) * height)
- 29 cv2.rectangle(img, (x1, y1), (x2, y2), (0, 0, 255), 1)
- 30 x_center = (float(result[2 + j * 6 + 2]) + float(result[2 + j * 6 + 4])) / 2
- 31 y_center = (float(result[2 + j * 6 + 3]) + float(result[2 + j * 6 + 5])) / 2
- 32 x_angle = int((x_center - 0.5) * 40 / 0.5)
- 33 y_angle = int((y_center - 0.5) * 40 / 0.5)
- 34 self.servo_cmd['x_dir'] = 'left' if x_angle <= 0 else 'right'
- 35 self.servo_cmd['x_angle'] = abs(x_angle)
- 36
- 37 cv2.cvtColor(img, cv2.COLOR_BGR2RGB, img)
- 38 cv2.putText(img, 'x:%s %d'%( self.servo_cmd['x_dir'], self.servo_cmd['x_angle']), (10, 40), cv2.FONT_HERSHEY_SIMPLEX, 1.2, (0, 0, 255), 2)
- 39 ServoControl('x', self.servo_cmd['x_dir'], self.servo_cmd['x_angle'])
- 40
- 41 self.image = QImage(img.data, width, height, bytesPerLine, QImage.Format_RGB888)
- 42 self.label_frame.setPixmap(QPixmap.fromImage(self.image).scaled(self.label_frame.width(), self.label_frame.height()))
- 43
- 44
复制代码
