ZH128资料
这颗芯片主要是HDMI转CVBS带缩放 1》General Description The ZH128 is a single chip HDMI to CVBS/S-Video converter with embedded MCU and memory. It consists of HDMI receiver, NTSC/PAL encoder with 10-bit Video DAC for output, with 10-bit Audio DAC, integrated OSD function. It is capable of video enhancement, 3D noise reduction,brightness/saturation/sharpness and hue adjustment, which can help the designer acquire the required video quality. No programming technology can help customers to reduce production cost and cycle. 2》Features HDMI Receiver Support HDMI 1.4b/DVI 1.0 Max Resolution up to 4K@60Hz for YUV420 format input Support HDCP 1.4 Support 8/10/12/16-bit color depth Input format auto detection Auto-mode Detection Auto Position (Blank) Detection Scaler Independent horizontal and vertical scaling up and down from (1/8)x to 8x Frame rate conversion Video Enhancement Black/white level expansion Color transition improvement Dynamic peaking Brightness, saturation, contrast and hue adjustable Embedded OSD Supports 1 bit DRCS character mode Zoom in One OSD window with alpha-blending Output Format 10-bit triple-DAC for component video output Supports CVBS and S-Video output Supports NTSC(J,M,4.43) and PAL(B,D,G,H,I,M,N,Nc,60) Audio Support Industry-standard SPDIF output Support Analog Stereo Audio Output Supports Compressed Dolby Digital, DTS digital audio Transmission Supports sample rate at 32K/44.1K/48K/88.2K/96K/176.4K/192K sample rate MCU On-chip MCU On-chip ROM/RAM/IO/Timer Internal ROM code and external EEPROM for customization System On-chip power on reset External 27Mhz Crystal Package QFN-48 plastic(7mm×7mm) PB-free and RoHS |
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
1503 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
408 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
969 浏览 0 评论
2476 浏览 3 评论
1053 浏览 1 评论
GMT+8, 2024-4-24 13:45 , Processed in 0.559312 second(s), Total 71, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
