Purpose
This product is applicable for the corrosive gas test for the protection layer of components, parts,(linpin) electronic and electrical parts and metal materials and industrial products. Chamber Structure A waterproof structure is adopted between the chamber cover and chamber body and thus there is no gas overflow(linpin). The chamber cover is made of transparent materials so that the operator can see the situation of the tested sample in the chamber. Double gas filters are equipped in order to ensure the air exhausted outdoor will not pollute the environment(linpin). Control System Adopts P, I, D+S, S or R. microprocessor integrated controller with LED digital display. Adopts multi-system protection,(linpin) ensuring reliable and safe use. Gas is produced with gas cylinder method or titration method. Standards Applied GB/T2423.19-81, GB/T10125-97, GB/T9789, IEC, 60068-2-42/43 Technical Parameters: Model (CM) S02 -250 S02 -750 Workroom Dimensions 60*90*50 75*110*50 Exterior Dimensions 77*144*125 92*164*145 Power 1.5(KW) 2.5(KW) Temperature Range RT+10℃~50℃ Humidity Range 85~95% R.H Test Time 0.1~999.9 (S, M, H) adjustable Gas Density 0.1~1% adjustable |
1 个讨论
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
673 浏览 0 评论
反激电源模块输出电压稳定,但输出电流不稳定,从0跳变到1A,这是怎么回事?
974 浏览 0 评论
1096 浏览 1 评论
1813 浏览 0 评论
675 浏览 0 评论
GMT+8, 2024-12-13 01:39 , Processed in 0.637189 second(s), Total 41, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
