本范例根据应用于现有 Recordset 的指定条件,使用 Filter 属性来打开新的 Recordset。RecordCount 属性用于显示两个 Recordset 中记录的数目。运行此过程需要 FilterField 函数。
Public Sub FilterX()
Dim rstPublishers As ADODB.Recordset
Dim rstPublishersCountry As ADODB.Recordset
Dim strCnn As String
Dim intPublisherCount As Integer
Dim strCountry As String
Dim strMessage As String
' Open recordset with data from Publishers table.
strCnn = "Provider=sqloledb;" & _
"Data Source=srv;Initial Catalog=Pubs;User Id=sa;Password=; "
Set rstPublishers = New ADODB.Recordset
rstPublishers.CursorType = adOpenStatic
rstPublishers.Open "publishers", strCnn, , , adCmdTable
' Populate the Recordset.
intPublisherCount = rstPublishers.RecordCount
' Get user input.
strCountry = Trim(InputBox( _
"Enter a country to filter on:"))
If strCountry <> "" Then
' Open a filtered Recordset object.
Set rstPublishersCountry = _
FilterField(rstPublishers, "Country", strCountry)
If rstPublishersCountry.RecordCount = 0 Then
MsgBox "No publishers from that country."
Else
' Print number of records for the original
' Recordset object and the filtered Recordset
' object.
strMessage = "Orders in original recordset: " & _
vbCr & intPublisherCount & vbCr & _
"Orders in filtered recordset (Country = '" & _
strCountry & "'): " & vbCr & _
MsgBox strMessage
End If
rstPublishersCountry.Close
End If
End Sub
Public Function FilterField(rstTemp As ADODB.Recordset, _
strField As String, strFilter As String) As ADODB.Recordset
' Set a filter on the specified Recordset object and then
' open a new Recordset object.
rstTemp.Filter = strField & " = '" & strFilter & "'"
Set FilterField = rstTemp
End Function
注意 当要选择的数据已知时,使用 SQL 语句打开 Recordset 通常更为有效。本范例显示如何创建唯一的 Recordset 并从特定的国家(地区)获取记录。
Public Sub FilterX2()
rstPublishers.Open "SELECT * FROM publishers " & _
"WHERE Country = 'USA'", strCnn, , , adCmdText
' Print current data in recordset.
rstPublishers.MoveFirst
Do While Not rstPublishers.EOF
Debug.Print rstPublishers!pub_name & ", " & _
rstPublishers!country
rstPublishers.MoveNext
Loop
rstPublishers.Close
End Sub
