请问专家:
我用样板工程Example_28335_Flash 加入程序文件.编译出错如下: "C:/ti/controlSUITE/device_support/f2833x/v132/DSP2833x_common/cmd/F28335.cmd", line 144: error: run placement fails for object ".ebss", size 0x3089 (page 1). Available ranges: RAML4 size: 0x1000 unused: 0x1000 max hole: 0x1000 .ebss : > RAML4 PAGE = 1 /* */ warning: entry-point symbol other than "_c_int00" specified: "code_start" error: errors encountered during linking; "Example_28335_Flash.out" not built 如果我把 F28335.cmd 中 .ebss : > RAML4 PAGE = 1 改为 .ebss : > FLASHB PAGE = 1 编译能通过.只有提示:warning: entry-point symbol other than "_c_int00" specified: "code_start" 但仿真运行时出现下面问题: C28xx: AutoRun: Target not run as breakpoint could not be set: Error programming AET Job: This task cannot be accomplished with the existing AET resources. code_start: .if WD_DISABLE == 1 LB wd_disable ;Branch to watchdog disable code -----程序进入到这个位置 .else LB _c_int00 ;Branch to start of boot.asm in RTS library .endif 再往下就不确定了.应怎么解决呢? |
5 个讨论
lvy,lin 关于合并RAM的某些段,例如
RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */ RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */ 合并后就是 RAMM0M1 : origin = 0x000050, length = 0x0007B0 /* on-chip RAM block M0M1 */ 即是把两段地址合在一起。 Eric - ERIC |
guigui_7044 发表于 2020-6-4 13:55 C28xx: AutoRun: Target not run as breakpoint could not be set: Error enabling this function: This task cannot be accomplished with the existing AET resources. 也出现类似错误,这是什么情况,我要是重启CCS就可以继续调试了 |
只有小组成员才能发言,加入小组>>
756 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1967 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3716 浏览 4 评论
5079 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1782 浏览 1 评论
CC3100BOOST使用CC3200lunchXL进行烧录
759浏览 2评论
815浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
786浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1259浏览 1评论
1850浏览 1评论
GMT+8, 2024-6-25 14:12 , Processed in 0.715447 second(s), Total 48, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
