逻辑分析的时候只有一个警告Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance. 用modelsim仿真看波形也没问题,可是我全编译后出现如图所示的警告,烧到板子上结果也不对,没找到解答,求大佬告知这有可能是什么问题
4个回答
warning主要有两个:
01.NUM_PARALLEL_PROCESSORS值过大,软件建议修改为合理范围的值; 02.引脚分配未完成。Warning (15714): Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details。 Critical Warning主要有两个: 01.缺少引脚约束文件'test_hex6.sdc'。 02.时序约束不满足。(可能由以上三点导致) //----------关于仿真 01.功能仿真不需要引脚约束,不涉及时序管理; 02.时序仿真需要对引脚分配,还涉及时序管理分析。 03.我这边只进行了功能仿真,验证程序没有问题。但是实际使用的时候有一点要注意,就是人眼的分辨率不能识别1kHz的刷新频率,所以我后面将代码改成了10分频。 //----------关于结果 01.“用modelsim仿真看波形也没问题”:功能仿真正常,代码没有逻辑缺陷,可以正常使用; 02.“可是我全编译后出现如图所示的警告,烧到板子上结果也不对”:结果不对可能是多个原因 02-a.是涉及的IO没有分配而无法对外输出/对内输入而缺少逻辑控制; 02-b.代码说明数码管是共阳数码管,对此应检查硬件是否匹配;另外就是确定晶振等硬件是否工作正常。 02-c.原代码中数码管刷新频率1kHz过高,人眼不易识别,导致看到的结果全部是“8”。此时建议降低分频频率/刷新频率,我将代码改成了10Hz。
最佳答案
6 条评论
警告图被压了,全编译的警告如下
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance. Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance. Warning (292013): Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature. Warning (15714): Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance. Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance. Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance. |
还有以下的Critical Warning:
Critical Warning (332012): Synopsys Design Constraints File file not found: 'test_hex6.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design. Critical Warning (332012): Synopsys Design Constraints File file not found: 'test_hex6.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design. Critical Warning (332148): Timing requirements not met Info (11105): For recommendations on closing timing, run Report Timing Closure Recommendations in the TimeQuest Timing Analyzer. Critical Warning (332148): Timing requirements not met Info (11105): For recommendations on closing timing, run Report Timing Closure Recommendations in the TimeQuest Timing Analyzer. Critical Warning (332148): Timing requirements not met Info (11105): For recommendations on closing timing, run Report Timing Closure Recommendations in the TimeQuest Timing Analyzer. |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
252 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1501 浏览 0 评论
907 浏览 0 评论
855 浏览 0 评论
658 浏览 0 评论
4427 浏览 63 评论
/9
GMT+8, 2025-12-2 21:08 , Processed in 0.869584 second(s), Total 56, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1543
