电子发烧友论坛|
请问有没有人使用过LWIP(1.4.1版本)中的ICMP协议实现设备PING PC机或其他设备的测试,有得话请指教,最好可以附上例程,感激不尽。。。
求助。。。 |
10个回答
太久没回来看帖,帐号直接被冻结。
其实机制很简单,ICMP其实基于IP层的,发送的时候只需要根据ICMP包的协议自己组一个一样的协议包就可以。至于时间的计算就是在发送的时候先获取一下单片机的运行时间,然后在ICMP Respond解析那里再一次获取一下单片机的运行时间,两个时间一减就是PING包的时间,不过肯定是有点延时的,但现在用起来其实还可以。 上码,不BB。 ICMP发送: err_t udp_sendicmp(struct udp_pcb *pcb, struct pbuf *p, struct ip_addr *dst_ip, u16_t dst_port) { struct netif *netif; LWIP_DEBUGF(UDP_DEBUG | LWIP_DBG_TRACE | 3, ("udp_sendn")); /* find the outgoing network interface for this packet */ #if LWIP_IGMP netif = ip_route((ip_addr_ismulticast(dst_ip))?(&(pcb->multicast_ip))dst_ip)); #else netif = ip_route(dst_ip); #endif /* LWIP_IGMP */ /* no outgoing network interface could be found? */ if (netif == NULL) { LWIP_DEBUGF(UDP_DEBUG | 1, ("udp_send: No route to 0x%"X32_F"n", dst_ip->addr)); UDP_STATS_INC(udp.rterr); return ERR_RTE; } return udp_sendto_ping(pcb, p, dst_ip, dst_port, netif); } err_t udp_sendto_ping(struct udp_pcb *pcb, struct pbuf *p, struct ip_addr *dst_ip, u16_t dst_port, struct netif *netif) { // struct udp_hdr *udphdr; struct ip_addr *src_ip; err_t err; struct pbuf *q; /* q will be sent down the stack */ struct icmp_echo_hdr *icmphdr; //kaishui /* not enough space to add an UDP header to first pbuf in given p chain? */ if (pbuf_header(p, sizeof(struct icmp_echo_hdr))) { /* allocate header in a separate new pbuf */ // q = pbuf_alloc(PBUF_IP, sizeof(struct icmp_echo_hdr), PBUF_RAM); q = pbuf_alloc(PBUF_IP, sizeof(struct icmp_echo_hdr)+ IP_HLEN + ICMP_DEST_UNREACH_DATASIZE, PBUF_RAM); /* new header pbuf could not be allocated? */ /* chain header q in front of given pbuf p */ pbuf_chain(q, p); /* first pbuf q points to header pbuf */ } /* q now represents the packet to be sent */ icmphdr = (struct icmp_echo_hdr *)q->payload; icmphdr->type = 8; icmphdr->code = 0; icmphdr->id =htons(0x0100) ; icmphdr->seqno =htons(0x51d1); icmphdr->chksum = 0; // icmphdr->chksum = inet_chksum(p->payload, 10); icmphdr->chksum = inet_chksum(icmphdr, q->len); /* PCB local address is IP_ANY_ADDR? */ if (ip_addr_isany(&pcb->local_ip)) { /* use outgoing network interface IP address as source address */ src_ip = &(netif->ip_addr); } else { /* check if UDP PCB local IP address is correct * this could be an old address if netif->ip_addr has changed */ /* use UDP PCB local IP address as source address */ src_ip = &(pcb->local_ip); } err = ip_output_if(q, src_ip, dst_ip, pcb->ttl, pcb->tos, IP_PROTO_ICMP, netif); snmp_inc_udpoutdatagrams(); /* did we chain a separate header pbuf earlier? */ if (q != p) { /* free the header pbuf */ pbuf_free(q); q = NULL; /* p is still referenced by the caller, and will live on */ } UDP_STATS_INC(udp.xmit); pbuf_free(p);//important return err; } void PingInit(void) { struct ip_addr ipaddr; unsigned int port = 2000; //69 p = pbuf_alloc(PBUF_RAW,10,PBUF_RAM); p->payload=(void *)UDPData; IP4_ADDR(&ipaddr,0,0,0,0); UDPpcb = udp_new(); udp_bind(UDPpcb,&ipaddr, port); } void ICMP_Ping(void) { struct ip_addr dstipaddr; p = pbuf_alloc(PBUF_RAW,10,PBUF_RAM); p->payload=(void *)UDPData; OSTimeDlyHMSM(0, 0, 0, 500); //wait 200ms memcpy(&dstipaddr.addr,&flash_read.lwip_msg->dns2,4); if(mt_client.respond_flag ==0) { cnt_1ms = 0; } else { mt_client.ping_end.end_time.tv_usec = 1000; mt_client.timeout_flag = 1; } udp_sendicmp(UDPpcb,p,&dstipaddr,2000); mt_client.respond_flag = 1; ntx_packet++; mt_client.ping_before.end_time.tv_sec = get_running_time(); mt_client.ping_before.end_time.tv_usec = get_1mstime();//ms } ICMP接收:(icmp.c) void icmp_input(struct pbuf *p, struct netif *inp) { .... case ICMP_ER: /* This is OK, echo reply might have been parsed by a raw PCB (as obviously, an echo request has been sent, too). */ #ifdef PINGPACK_TEST nrx_packet ++; mt_client.ping_after.end_time.tv_sec = get_running_time(); mt_client.ping_after.end_time.tv_usec = get_1mstime();//ms mt_client.ping_end.end_time.tv_sec = 0; mt_client.ping_end.end_time.tv_usec = mt_client.ping_after.end_time.tv_usec - mt_client.ping_before.end_time.tv_usec; mt_client.respond_flag = 0; if(mt_client.ping_end.end_time.tv_usec > 10)//ms { mt_client.timeout_flag = 1; } #endif break; ... } |
@原子哥速来求解,感谢!!!
这个功能没用过哦,帮顶.
已经通过UDP的方式发送ping包了,但是要取得respond的延时时间,还在搞
谢谢原子哥
楼主你这后面还有下文吗?搞出来没?
搞出来了
正好项目需要,可以发一份完整的源码给我吗,谢谢你 516182660@qq.com
请问楼主对端收到udp数据包后能解析出来是icmp报文?
还有这种操作,666
只有小组成员才能发言,加入小组>>
926 浏览 0 评论
如何使用STM32+nrf24l01架构把有线USB设备无线化?
3087 浏览 7 评论
请问能利用51单片机和nRF24L01模块实现实时语音无线传输吗?
2987 浏览 5 评论
3846 浏览 3 评论
3311 浏览 8 评论
请教各位大咖:有没有接收频率32M左右的芯片推荐的?先感谢啦!
1266浏览 1评论
1212浏览 0评论
882浏览 0评论
973浏览 0评论
926浏览 0评论
/9
GMT+8, 2025-12-2 06:09 , Processed in 0.771029 second(s), Total 59, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
664
