大家好,我有一个应用程序,如果主日志文件不可用(即网络故障),它将在辅助日志文件中生成一个条目。一旦打开日志文件,我将其保持打开状态直到应用程序结束但是,如果
主文件没有问题,可能无法打开辅助文件。 当用户按下“完成”按钮时,我使用“To_File / Execute Close”对象来确保两个文件都已正确关闭。 没问题,一切都运行良好,即使有鼻子文件。最近我决定允许操作员更改辅助文件的目录,所以我为To_Fileobject提供了文件名控制输入引脚。 不幸的是,在这种情况下,Vee的行为有点不同 - 如果文件不存在,Vee创建它然后,Iassume,关闭它。 出于多种原因,我不希望生成空数据文件。 实际上,我不希望生成任何sortbeing的空文件。 这是一个合法且理想的Vee“功能”吗?我知道在DOS时代关闭文件是一件大事。 在Windows 2000机器上留下Vee应用程序时,我真的需要“执行关闭”吗?Barriewhoi 以上来自于谷歌翻译 以下为原文 Hi folks, I have an application that will make an entry in a secondary log file only if the primary log file is not available (i.e. network failure). Once a log file has been opened, I leave it open until the application ends but, if the primary file has no problems, the secondary file may never be opened. When the user presses the "Done" button, I use a "To_File/Execute Close" object to make sure both files have been closed correctly. No problem, everything works well even if there is no secondary file. Recently I decided to allow the operator to change the secondary file's directory so I provided a file name control input pin to the To_File object. Unfortunately, Vee acts a little differently under this condition - if the file doesn't exist, Vee creates it and then, I assume, closes it. For a number of reasons, I don't want empty data files being generated. In fact, I don't want empty files of any sort being generated. Is this a legitimate and desirable Vee "feature"? I know closing a file was a big deal back in the DOS days. Do I really need to "execute close" when leaving a Vee application on a Windows 2000 machine? Barrie whoi --- You are currently subscribed to vrf as: r***@soco.agilent.com To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
1个回答
Barrie - >在Windows 2000>机器上离开Vee>应用程序时,我真的需要“执行>关闭”吗?我会 - 即使文件是经常写入的。
唯一的原因是因为这是冲洗我所知道的缓存/缓冲区的唯一方法(无论如何都不会过度参与)。 如果发生了可怕的事情,那么数据丢失的可能性会降低。无论如何,您应该能够通过在To To文件之前使用From File来检查文件是否存在(在打开文件之前)。 在文件中粘贴anerror pin。 如果文件不存在......你知道。我知道它不是kosh来解决错误,但有时它只是有意义。-SHAWN ----你目前订阅vrf为:r***@soco.agilent.comTo 取消订阅会发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@it.lists.it.agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 Barrie - > Do I really need to "execute > close" when leaving a Vee > application on a Windows 2000 > machine? I would - even if the file is written to frequently. The only reason is because that's the only way of flushing the cache/buffers I know of (without getting over involved anyway). If something terrible happens there's less chance of data loss. Anyway, you should be able to check for the existence of a file (before opening it for writing) by using a From File before a To File. Stick an error pin on the from file. If the file doesn't exist... you know. I know it's not kosh to fire errors, but sometimes it just makes sense. -SHAWN- --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 09:54 , Processed in 0.698136 second(s), Total 93, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1437
