#include
#include #define nop _nop_() #define uchar unsigned char #define uint unsigned int uchar k ; ***it ACC7= ACC^7; ***it ACC0= ACC^0; ***it rs=P3^5;//1602 引脚 ***it wr=P3^6; ***it e=P3^4; ***it rst=P3^3; //1302引脚 ***it sclk=P3^2; ***it io=P2^4; uchar code table1[] = {0x00,0x00,0x00,0x05,0x00,0x00,0x00}; uchar code week[][3] = {{"SUN"},{"MON"},{"TUE"},{"WED"},{"THU"},{"FRI"},{"SAT"}}; uchar data line1[] = {"2012/07/30"}; uchar code table2[] = {"0123456789"}; uchar data line2[] = {"00:00:00"}; void lcd_busy_wait() //CD1602 忙等待 { rs = 0; wr = 1; e = 1; P0 = 0xff; while (P0&0x80); P0 = 0; } void delay(uint z) //延时函数 { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void writecom(uchar b) { lcd_busy_wait(); rs=0; //根据时序图 wr=0; P0=b; delay(1); e=1; delay(1); e=0; } void writedate(uchar b) { rs=1; //根据时序图 wr=0; P0=b; delay(1); e=1; delay(1); e=0; } void init() //初始函数1602 { wr=0; //写 e=0; delay(15); writecom(0x38); //设置16x2显示,5x7点阵,8位数据口 delay(5); writecom(0x38); delay(5); writecom(0x38); delay(5); writecom(0x38); writecom(0x08); delay(5); writecom(0x0c); //设置开显示,显光标,光标闪烁 writecom(0x06); // 写一个字符地址指针加1 writecom(0x01); //显示清0;数据指针清0 } void writebit(uchar q)//1302写一字节 { uchar i; ACC=q; for(i=8;i>0;i--) { sclk=0; io=ACC0; sclk=1; ACC =ACC>>1; } } uchar readbit(void)//读一字节 { uchar i; for(i=8;i>0;i--) { ACC7=io; sclk=0; ACC7=ACC>>1; sclk=1; } return(ACC); } /*uchar readbit()//读一字节 { uchar i,date; delay(2); for(i=0;i>8;i++); { date>>=1; if(io==1) date|=0x80; sclk=1; nop; nop; nop; sclk=0; delay(2); } return(date); } void writebit (uchar q)//写一字节 { uchar i,num; for(i=8;i>0;i--) { sclk=1; nop; nop; nop; num=q; io=num&0x01; q>>=1; sclk=0; } }*/ void write1302(uchar add,uchar date)//往1302写入数据 { rst=0; nop; sclk=0; nop; rst=1; nop; writebit(add); writebit(date); sclk=1; rst=0; } uchar read1302(uchar add)//从1302读取数据 { uchar date; rst=0; nop; sclk=0; nop; rst=1; writebit(add); date=readbit(); sclk=1; rst=0; return(date); } void set1302(uchar *a)//1302初始化 { uchar i,add=0x80; write1302(0x8e,0x00);//禁止写 保护 for(i=7;i>0;i--) { write1302(add,*a); a++; add+=2; } write1302(0x8e,0x80); //允许写保护 } void get1302(uchar table[])//将1302读取的数据存到数组中 { uchar i,ad=0x81; for(i=0;i<7;i++) { table=read1302(ad); ad+=2; } } void display() //1602显示 { uchar a,i,j; wr=0; e=0; writecom(0x81); lcd_busy_wait(); for(a=0;a<10;a++) { writedate(line1[a]); delay(5); } writecom(0x80+0x0c); lcd_busy_wait(); for(i=0;i<3;i++) { writedate(week[k]); delay(5); } writecom(0x80+0x43); lcd_busy_wait(); for(j=0;j<8;j++) { writedate(line2[j]); delay(5); } } main() { init() ; set1302(table1); while(1) { get1302(table1); line1[2]=table2[table1[6]/0x10]; line1[3]=table2[table1[6]%0x10]; line1[5]=table2[table1[5]/0x10]; line1[6]=table2[table1[5]%0x10]; line1[8]=table2[table1[4]/0x10]; line1[9]=table2[table1[4]%0x10]; k=table2[table1[3]%0x10]-'0'; line2[0]=table2[table1[2]/0x10]; line2[1]=table2[table1[2]%0x10]; line2[3]=table2[table1[1]/0x10]; line2[4]=table2[table1[1]%0x10]; line2[6]=table2[table1[0]/0x10]; line2[7]=table2[table1[0]%0x10]; display(); } } |
1个回答
DS1302+LCD1602显示C程序
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
/9
GMT+8, 2025-12-2 10:55 , Processed in 1.002987 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4226
