电子发烧友论坛|
烧写资料中的uboot、uImage、fs:jz2440/CD5--ziliao/bin/下的u-boot.bin
jz2440/CD5--ziliao/bin/下的uImage jz2440/CD5--ziliao/bin/下的fs_mini.yaffs2 均使用u***烧写到nand: uboot: u*** 1 30000000 nand erase 0 40000 nand write 30000000 0 40000 -------------------------------------- uImage: nand 1 30000000 nnad erase 60000 200000 nand write 30000000 60000 200000 ------------------------------------------- fs: u*** 1 30000000 nand erase 260000 900000 nand write 30000000 260000 900000 ------------------------------------------- 重启,执行结果如下: U-Boot 1.1.6 (Nov 26 2010 - 08:49:16) DRAM: 64 MB Flash: 2 MB NAND: 256 MiB *** Warning - bad CRC or NAND, using default environment In: serial Out: serial Err: serial UPLLVal [M:38h,P:2h,S:2h] MPLLVal [M:5ch,P:1h,S:1h] CLKDIVN:5h +---------------------------------------------+ | S3C2440A USB Downloader ver R0.03 2004 Jan | +---------------------------------------------+ USB: IN_ENDPOINT:1 OUT_ENDPOINT:3 FORMAT: NOTE: Power off/on or press the reset button for 1 sec in order to get a valid USB device address. Hit any key to stop autoboot: 1 U-Boot 1.1.6 (Nov 26 2010 - 08:49:16) DRAM: 64 MB Flash: 0 kB NAND: 256 MiB *** Warning - bad CRC or NAND, using default environment In: serial Out: serial Err: serial UPLLVal [M:38h,P:2h,S:2h] MPLLVal [M:5ch,P:1h,S:1h] CLKDIVN:5h +---------------------------------------------+ | S3C2440A USB Downloader ver R0.03 2004 Jan | +---------------------------------------------+ USB: IN_ENDPOINT:1 OUT_ENDPOINT:3 FORMAT: NOTE: Power off/on or press the reset button for 1 sec in order to get a valid USB device address. Hit any key to stop autoboot: 0 Booting Linux ... NAND read: device 0 offset 0x60000, size 0x200000 Reading data from 0x25f800 -- 100% complete. 2097152 bytes read: OK ## Booting image at 30007fc0 ... Image Name: Linux-2.6.22.6 Created: 2013-08-23 7:33:38 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1848668 Bytes = 1.8 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK XIP Kernel Image ... OK Starting kernel ... Uncompressing Linux....................................................................... Linux version 2.6.22.6 (book@book-desktop) (gcc version 3.4.5) #1 Fri Aug 23 15:33:35 CST3 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 Machine: SMDK2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz S3C24XX Clocks, (c) 2004 Simtec Electronics CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists. Total pages: 16256 Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0 irq: clearing subpending status 00000002 PID hash table entries: 256 (order: 8, 1024 bytes) timer tcon=00500000, tcnt a2c1, tcfg 00000200,00000000, usec 00001eb8 Console: colour dummy device 80x30 Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60976KB available (3264K code, 458K data, 140K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 S3C2410 Power Management, (c) 2004 Simtec Electronics S3C2440: Initialising architecture S3C2440: IRQ Support S3C2440: Clock Support, DVS off S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4800000, irq 33 DMA channel 1 at c4800040, irq 34 DMA channel 2 at c4800080, irq 35 DMA channel 3 at c48000c0, irq 36 SCSI subsystem initialized u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NetWinder Floating Point Emulator V0.97 (double precision) Registering GDB sysrq handler JFFS2 version 2.2. (NAND) .. 2001-2006 Red Hat, Inc. yaffs Aug 23 2013 15:33:07 Installing. io scheduler noop registered io scheduler anticipatory registered (default) io scheduler deadline registered io scheduler cfq registered Console: switching to colour frame buffer device 60x34 fb0: s3c2410fb frame buffer device lp: driver loaded but no devices found ppdev: user-space parallel port driver S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled s3c2440-uart.0: s3c2410_serial0 at MMIO map 0x50000000 mem 0xf0400000 (irq = 70) is a S3C0 s3c2440-uart.1: s3c2410_serial1 at MMIO map 0x50004000 mem 0xf0404000 (irq = 73) is a S3C0 s3c2440-uart.2: s3c2410_serial2 at MMIO map 0x50008000 mem 0xf0408000 (irq = 76) is a S3C0 RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize loop: module loaded line 400 line 408 id_val=0 S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c2440-nand s3c2440-nand: Tacls=3, 30ns Twrph0=7 70ns, Twrph1=3 30ns NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit) Scanning device for bad blocks Bad eraseblock 529 at 0x04220000 Bad eraseblock 875 at 0x06d60000 Bad eraseblock 1013 at 0x07ea0000 Bad eraseblock 1019 at 0x07f60000 Creating 4 MTD partitions on "NAND 256MiB 3,3V 8-bit": 0x00000000-0x00040000 : "bootloader" 0x00040000-0x00060000 : "params" 0x00060000-0x00260000 : "kernel" 0x00260000-0x10000000 : "root" s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 u*** u***1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... u***core: registered new interface driver u***-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice s3c2410 TouchScreen successfully loaded input: s3c2410 TouchScreen as /class/input/input0 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2440-i2c s3c2440-i2c: slave address 0x10 s3c2440-i2c s3c2440-i2c: bus frequency set to 390 KHz s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter mapped channel 0 to 0 s3c2440-sdi s3c2440-sdi: powered down. s3c2440-sdi s3c2440-sdi: initialisation done. s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). s3c2440-sdi s3c2440-sdi: running at 196kHz (requested: 195kHz). s3c2440-sdi s3c2440-sdi: running at 196kHz (requested: 195kHz). s3c2440-sdi s3c2440-sdi: running at 196kHz (requested: 195kHz). u***core: registered new interface driver hiddev s3c2440-sdi s3c2440-sdi: CMD[TIMEOUT] #2 op:UNKNOWN(8) arg:0x000001aa flags:0x0875 retriee s3c2440-sdi s3c2440-sdi: CMD[TIMEOUT] #3 op:APP_CMD(55) arg:0x00000000 flags:0x0875 retrie u***core: registered new interface driver u***hid drivers/hid/u***hid/hid-core.c: v2.6:USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.14 (Thu May 31 09:03:25 2007 UTC). s3c2440-sdi s3c2440-sdi: CMD[TIMEOUT] #4 op:APP_CMD(55) arg:0x00000000 flags:0x0875 retrie ASoC version 0.13.1 s3c2440-sdi s3c2440-sdi: CMD[TIMEOUT] #5 op:APP_CMD(55) arg:0x00000000 flags:0x0875 retrie s3c2410iis_probe... s3c2440-sdi s3c2440-sdi: CMD[TIMEOUT] #6 op:APP_CMD(55) arg:0x00000000 flags:0x0875 retrie s3c2440-sdi s3c2440-sdi: CMD[TIMEOUT] #7 op:ALL_SEND_OCR(1) arg:0x00000000 flags:0x0861 re s3c2440-sdi s3c2440-sdi: powered down. UDA1341 audio driver initialized ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 1 drivers/rtc/hctosys.c: unable to open rtc device (rtc0) UDF-fs: No VRS found yaffs: dev is 32505859 name is "mtdblock3" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.3, "mtdblock3" yaffs: auto selecting yaffs2 block 511 is bad block 857 is bad block 995 is bad block 1001 is bad VFS: Mounted root (yaffs filesystem). Freeing init memory: 140K Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. 类似烧写不能进入系统的问题困扰了很久,望老师详细解答此问题,非常感谢! |
1个回答
烧:fs_qtopia.yaffs2,fs_mini.yaffs2不全;
挂载根文件系统出现"Kernel panic..."史上最全解决方案 https://mp.weixin.qq.com/s?__biz ... 6e4f59f821b903e6#rd |
只有小组成员才能发言,加入小组>>
296个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2466 浏览 6 评论
2201 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4828 浏览 1 评论
/9
GMT+8, 2025-12-2 22:57 , Processed in 0.606494 second(s), Total 77, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
999
