玩了三个月的STM32,最初连c语言都不会,在论坛和技术支持的帮助下,基本实现了有线传输lwip,解码图像显示,同时存在很多问题,我现在抛砖引玉请大家多指点。//jpeg解码程序
//目前仅支持JFIF格式的JPEG/JPG //参考网上代码(创新论坛:超级大苹果) //占用SRAM : 14060 Bytes //发烧友@HYW //2009.03.21 //V1.0 //#include "mygirl.h" //#include "mygirl1.h" //#include "mygirl2.h" //#include "mygirl3.h" //#include "mine.h" #include "lcd.h" #include "jpeg.h" //#include "mygirl4.h" //#include "mygirl5.h" //#define M_SOF0 0xc0 //#define M_DHT 0xc4 //#define M_EOI 0xd9 //#define M_SOS 0xda //#define M_DQT 0xdb //#define M_DRI 0xdd //#define M_APP0 0xe0 ////开始显示的坐标值 long CurX=00; long CurY=00; //static int Zig_Zag[8][8]={{0,1,5,6,14,15,27,28}, // {2,4,7,13,16,26,29,42}, // {3,8,12,17,25,30,41,43}, // {9,11,18,24,37,40,44,53}, // {10,19,23,32,39,45,52,54}, // {20,22,33,38,46,51,55,60}, // {21,34,37,47,50,56,59,61}, // {35,36,48,49,57,58,62,63} // }; //#define W1 2841 /* 2048*sqrt(2)*cos(1*pi/16) */ //#define W2 2676 /* 2048*sqrt(2)*cos(2*pi/16) */ //#define W3 2408 /* 2048*sqrt(2)*cos(3*pi/16) */ //#define W5 1609 /* 2048*sqrt(2)*cos(5*pi/16) */ //#define W6 1108 /* 2048*sqrt(2)*cos(6*pi/16) */ //#define W7 565 /* 2048*sqrt(2)*cos(7*pi/16) */ ////************************************************************************************* //typedef char CHAR; //typedef short SHORT; //typedef long LONG; // //typedef unsigned long DWORD; //typedef int BOOL; //typedef unsigned char BYTE; //typedef unsigned short WORD; //typedef int HFILE; //typedef CHAR *LPSTR, *PSTR; //#define FALSE 0 //#define TRUE 1 ///* constants for the biCompression field */ //#define BI_RGB 0L //#define BI_RLE8 1L //#define BI_RLE4 2L //#define BI_BITFIELDS 3L //typedef struct tagRGBQUAD { // BYTE rgbBlue; // BYTE rgbGreen; // BYTE rgbRed; // BYTE rgbReserved; //} RGBQUAD; //typedef RGBQUAD * LPRGBQUAD; //#define MAKEWORD(a, b) ((WORD)(((BYTE)(a)) | ((WORD)((BYTE)(b))) << 8)) //#define MAKELONG(a, b) ((LONG)(((WORD)(a)) | ((DWORD)((WORD)(b))) << 16)) //#define LOWORD(l) ((WORD)(l)) //#define HIWORD(l) ((WORD)(((DWORD)(l) >> 16) & 0xFFFF)) //#define LOBYTE(w) ((BYTE)(w)) //#define HIBYTE(w) ((BYTE)(((WORD)(w) >> 8) & 0xFF)) // ////宏定义 //#define WIDTHBYTES(i) ((i+31)/32*4)//?????????? //#define PI 3.1415926535 ////函数返回值定义 //#define FUNC_OK 0 //#define FUNC_MEMORY_ERROR 1 //#define FUNC_FILE_ERROR 2 //#define FUNC_FORMAT_ERROR 3 //////////////////////////////////////////////////// ////JPEG 解码函数 ////BOOL LoadJpegFile(const unsigned char *BmpFileName); ////void showerror(int funcret); ////int InitTag(void); ////void InitTable(void); ////int Decode(void); ////int DecodeMCUBlock(void); ////int HufBlock(BYTE dchufindex,BYTE achufindex); ////int DecodeElement(void); ////void IQtIZzMCUComponent(short flag); ////void IQtIZzBlock(short *s ,int * d,short flag); ////void GetYUV(short flag); ////void StoreBuffer(void); ////BYTE ReadByte(void); ////void Initialize_Fast_IDCT(void); ////void Fast_IDCT(int * block); ////void idctrow(int * blk); ////void idctcol(int * blk); //////////////////////////////////////////////////// ////全局变量声明 DWORD NumColors; DWORD LineBytes; DWORD ImgWidth=0 , ImgHeight=0; char* lpPtr; //////////////////////////////////////////////////// ////在JPEG函数里面用到的变量 short SampRate_Y_H,SampRate_Y_V; short SampRate_U_H,SampRate_U_V; short SampRate_V_H,SampRate_V_V; short H_YtoU,V_YtoU,H_YtoV,V_YtoV; short Y_in_MCU,U_in_MCU,V_in_MCU; unsigned char *lpJpegBuf; unsigned char *lp; short qt_table[3][64]; short comp_num; BYTE comp_index[3]; BYTE YDcIndex,YAcIndex,UVDcIndex,UVAcIndex; BYTE HufTabIndex; short *YQtTable,*UQtTable,*VQtTable; BYTE And[9]={0,1,3,7,0xf,0x1f,0x3f,0x7f,0xff}; short code_pos_table[4][16],code_len_table[4][16]; unsigned short code_value_table[4][256]; unsigned short huf_max_value[4][16],huf_min_value[4][16]; short BitPos,CurByte; short rrun,vvalue; short MCUBuffer[10*64]; int QtZzMCUBuffer[10*64]; short BlockBuffer[64]; short ycoef,ucoef,vcoef; BOOL IntervalFlag; short interval=0; int Y[4*64],U[4*64],V[4*64]; DWORD sizei,sizej; short restart; static long iclip[1024]; static long *iclp; //读取JPEG代码,并解码 BOOL LoadJpegFile (const unsigned char *JpegFileName) { DWORD JpegBufSize; const unsigned char *hJpegBuf; int funcret; hJpegBuf=JpegFileName;//JPEG文件头 lpJpegBuf=(unsigned char*)hJpegBuf;//转换为变量指针 InitTable(); if((funcret=InitTag())!=FUNC_OK)//初始化表头不成功 { showerror(funcret);//错误信息显示 return FALSE; } if((SampRate_Y_H==0)||(SampRate_Y_V==0)) { return FALSE ; } funcret=Decode(); if(funcret==FUNC_OK)//解码成功 { return TRUE; } else { return FALSE; } } //错误提示函数 void showerror(int funcret) { switch(funcret) { case FUNC_MEMORY_ERROR: // printf("Error alloc memoryn!"); break; case FUNC_FILE_ERROR: // printf("File not found!n"); break; case FUNC_FORMAT_ERROR: // printf("File format error!n"); break; } } //////////////////////////////////////////////////////////////////////////////// int InitTag() { BOOL finish=FALSE; BYTE id; short llength; short i,j,k; short huftab1,huftab2; short huftabindex; BYTE hf_table_index; BYTE qt_table_index; BYTE comnum; unsigned char *lptemp; short colorount; lp=lpJpegBuf+2;//跳过两个字节SOI(0xFF,0xD8 Start of Image) while (!finish) { id=*(lp+1);//取出低位字节(高位在前,低位在后) lp+=2; //跳过取出的字节 switch (id) { case M_APP0: //JFIF APP0 segment marker (0xE0) llength=MAKEWORD(*(lp+1),*lp); lp+=llength; break; case M_DQT: //定义量化表(0xFF,0xDB) llength=MAKEWORD(*(lp+1),*lp);//(量化表长度) qt_table_index=(*(lp+2))&0x0f;//量化表信息bit 0..3: QT 号(0..3, 否则错误) //bit 4..7: QT 精度, 0 = 8 bit, 否则 16 bit lptemp=lp+3; //n 字节的 QT, n = 64*(精度+1) if(llength<80) //精度为 8 bit { for(i=0;i<64;i++) qt_table[qt_table_index]=(short)*(lptemp++); } else //精度为 16 bit { for(i=0;i<64;i++)qt_table[qt_table_index]=(short)*(lptemp++); qt_table_index=(*(lptemp++))&0x0f; for(i=0;i<64;i++)qt_table[qt_table_index]=(short)*(lptemp++); } lp+=llength; //跳过量化表 break; case M_SOF0: //帧开始 (baseline JPEG 0xFF,0xC0) llength=MAKEWORD(*(lp+1),*lp); //长度 (高字节, 低字节), 8+components*3 ImgHeight=MAKEWORD(*(lp+4),*(lp+3));//图片高度 (高字节, 低字节), 如果不支持 DNL 就必须 >0 ImgWidth=MAKEWORD(*(lp+6),*(lp+5)); //图片宽度 (高字节, 低字节), 如果不支持 DNL 就必须 >0 comp_num=*(lp+7);//components 数量(1 byte), 灰度图是 1, YCbCr/YIQ 彩色图是 3, CMYK 彩色图是 4 if((comp_num!=1)&&(comp_num!=3))return FUNC_FORMAT_ERROR; if(comp_num==3) //YCbCr/YIQ 彩色图 { comp_index[0]=*(lp+8); //component id (1 = Y, 2 = Cb, 3 = Cr, 4 = I, 5 = Q) SampRate_Y_H=(*(lp+9))>>4; //水平采样系数 SampRate_Y_V=(*(lp+9))&0x0f;//垂直采样系数 YQtTable=(short *)qt_table[*(lp+10)];//通过量化表号取得量化表地址 comp_index[1]=*(lp+11); //component id SampRate_U_H=(*(lp+12))>>4; //水平采样系数 SampRate_U_V=(*(lp+12))&0x0f; //垂直采样系数 UQtTable=(short *)qt_table[*(lp+13)];//通过量化表号取得量化表地址 comp_index[2]=*(lp+14); //component id SampRate_V_H=(*(lp+15))>>4; //水平采样系数 SampRate_V_V=(*(lp+15))&0x0f; //垂直采样系数 VQtTable=(short *)qt_table[*(lp+16)];//通过量化表号取得量化表地址 } else //component id { comp_index[0]=*(lp+8); SampRate_Y_H=(*(lp+9))>>4; SampRate_Y_V=(*(lp+9))&0x0f; YQtTable=(short *)qt_table[*(lp+10)];//灰度图的量化表都一样 comp_index[1]=*(lp+8); SampRate_U_H=1; SampRate_U_V=1; UQtTable=(short *)qt_table[*(lp+10)]; comp_index[2]=*(lp+8); SampRate_V_H=1; SampRate_V_V=1; VQtTable=(short *)qt_table[*(lp+10)]; } lp+=llength; break; case M_DHT: //定义 Huffman Table(0xFF,0xC4) llength=MAKEWORD(*(lp+1),*lp);//长度 (高字节, 低字节) if (llength<0xd0) // Huffman Table信息 (1 byte) { huftab1=(short)(*(lp+2))>>4; //huftab1=0,1(HT 类型,0 = DC 1 = AC) huftab2=(short)(*(lp+2))&0x0f; //huftab2=0,1(HT 号 ,0 = Y 1 = UV) huftabindex=huftab1*2+huftab2; //0 = YDC 1 = UVDC 2 = YAC 3 = UVAC lptemp=lp+3; for (i=0; i<16; i++) //16 bytes: 长度是 1..16 代码的符号数 code_len_table[huftabindex]=(short)(*(lptemp++));//码长为i的码字个数 j=0; for (i=0; i<16; i++) //得出HT的所有码字的对应值 { if(code_len_table[huftabindex]!=0) { k=0; while(k { code_value_table[huftabindex][k+j]=(short)(*(lptemp++)); k++; } j+=k; } } i=0; while (code_len_table[huftabindex]==0)i++; for (j=0;j { huf_min_value[huftabindex][j]=0; huf_max_value[huftabindex][j]=0; } huf_min_value[huftabindex]=0; huf_max_value[huftabindex]=code_len_table[huftabindex]-1; for (j=i+1;j<16;j++) { huf_min_value[huftabindex][j]=(huf_max_value[huftabindex][j-1]+1)<<1; huf_max_value[huftabindex][j]=huf_min_value[huftabindex][j]+code_len_table[huftabindex][j]-1; } code_pos_table[huftabindex][0]=0; for (j=1;j<16;j++) code_pos_table[huftabindex][j]=code_len_table[huftabindex][j-1]+code_pos_table[huftabindex][j-1]; lp+=llength; } //if else { hf_table_index=*(lp+2); lp+=2; while (hf_table_index!=0xff) { huftab1=(short)hf_table_index>>4; //huftab1=0,1 huftab2=(short)hf_table_index&0x0f; //huftab2=0,1 huftabindex=huftab1*2+huftab2; lptemp=lp+1; colorount=0; for (i=0; i<16; i++) { code_len_table[huftabindex]=(short)(*(lptemp++)); colorount+=code_len_table[huftabindex]; } colorount+=17; j=0; for (i=0; i<16; i++) { if(code_len_table[huftabindex]!=0) { k=0; while(k { code_value_table[huftabindex][k+j]=(short)(*(lptemp++)); k++; } j+=k; } } i=0; while (code_len_table[huftabindex]==0)i++; for (j=0;j { huf_min_value[huftabindex][j]=0; huf_max_value[huftabindex][j]=0; } huf_min_value[huftabindex]=0; huf_max_value[huftabindex]=code_len_table[huftabindex]-1; for (j=i+1;j<16;j++) { huf_min_value[huftabindex][j]=(huf_max_value[huftabindex][j-1]+1)<<1; huf_max_value[huftabindex][j]=huf_min_value[huftabindex][j]+code_len_table[huftabindex][j]-1; } code_pos_table[huftabindex][0]=0; for (j=1;j<16;j++) code_pos_table[huftabindex][j]=code_len_table[huftabindex][j-1]+code_pos_table[huftabindex][j-1]; lp+=colorount; hf_table_index=*lp; } //while } //else break; case M_DRI: llength=MAKEWORD(*(lp+1),*lp); restart=MAKEWORD(*(lp+3),*(lp+2)); lp+=llength; break; case M_SOS: llength=MAKEWORD(*(lp+1),*lp); comnum=*(lp+2); if(comnum!=comp_num) return FUNC_FORMAT_ERROR; lptemp=lp+3; for (i=0;i if(*lptemp==comp_index[0]) { YDcIndex=(*(lptemp+1))>>4; //Y 使用的 Huffman 表 YAcIndex=((*(lptemp+1))&0x0f)+2; } else { UVDcIndex=(*(lptemp+1))>>4; //U,V UVAcIndex=((*(lptemp+1))&0x0f)+2; } lptemp+=2; } lp+=llength; finish=TRUE; break; case M_EOI://图片结束 return FUNC_FORMAT_ERROR; break; default: if ((id&0xf0)!=0xd0) { llength=MAKEWORD(*(lp+1),*lp); lp+=llength; } else lp+=2; break; } //switch } //while return FUNC_OK; } //初始化量化表,全部清零 void InitTable() { short i,j; sizei=sizej=0; ImgWidth=ImgHeight=0; rrun=vvalue=0; BitPos=0; CurByte=0; IntervalFlag=FALSE; restart=0; for(i=0;i<3;i++) //量化表 for(j=0;j<64;j++) qt_table[j]=0; comp_num=0; HufTabIndex=0; for(i=0;i<3;i++) comp_index=0; for(i=0;i<4;i++) for(j=0;j<16;j++){ code_len_table[j]=0; code_pos_table[j]=0; huf_max_value[j]=0; huf_min_value[j]=0; } for(i=0;i<4;i++) for(j=0;j<256;j++) code_value_table[j]=0; for(i=0;i<10*64;i++){ MCUBuffer=0; QtZzMCUBuffer=0; } for(i=0;i<64;i++){ Y=0; U=0; V=0; BlockBuffer=0; } ycoef=ucoef=vcoef=0; } //调用顺序: Initialize_Fast_IDCT() :初始化 // DecodeMCUBlock() Huffman Decode // IQtIZzMCUComponent() 反量化、反DCT // GetYUV() Get Y U V // StoreBuffer() YUV to RGB int Decode() { int funcret; Y_in_MCU=SampRate_Y_H*SampRate_Y_V;//YDU YDU YDU YDU U_in_MCU=SampRate_U_H*SampRate_U_V;//cRDU V_in_MCU=SampRate_V_H*SampRate_V_V;//cBDU H_YtoU=SampRate_Y_H/SampRate_U_H; V_YtoU=SampRate_Y_V/SampRate_U_V; H_YtoV=SampRate_Y_H/SampRate_V_H; V_YtoV=SampRate_Y_V/SampRate_V_V; Initialize_Fast_IDCT(); while((funcret=DecodeMCUBlock())==FUNC_OK) //After Call DecodeMCUBUBlock() { interval++; //The Digital has been Huffman Decoded and if((restart)&&(interval % restart==0))//be stored in MCUBuffer(YDU,YDU,YDU,YDU IntervalFlag=TRUE; // UDU,VDU) Every DU := 8*8 else IntervalFlag=FALSE; IQtIZzMCUComponent(0); //反量化 and IDCT The Data in QtZzMCUBuffer IQtIZzMCUComponent(1); IQtIZzMCUComponent(2); GetYUV(0); //得到Y cR cB GetYUV(1); GetYUV(2); StoreBuffer(); //To RGB sizej+=SampRate_Y_H*8; if(sizej>=ImgWidth) { sizej=0; sizei+=SampRate_Y_V*8; } if ((sizej==0)&&(sizei>=ImgHeight))break; } return funcret; } // 入口 QtZzMCUBuffer 出口 Y[] U[] V[] //得到YUV色彩空间 void GetYUV(short flag) { short H,VV; short i,j,k,h; int *buf; int *pQtZzMCU; switch(flag) { case 0://亮度分量 H=SampRate_Y_H; VV=SampRate_Y_V; buf=Y; pQtZzMCU=QtZzMCUBuffer; break; case 1://红色分量 H=SampRate_U_H; VV=SampRate_U_V; buf=U; pQtZzMCU=QtZzMCUBuffer+Y_in_MCU*64; break; case 2://蓝色分量 H=SampRate_V_H; VV=SampRate_V_V; buf=V; pQtZzMCU=QtZzMCUBuffer+(Y_in_MCU+U_in_MCU)*64; break; } for (i=0;i for(h=0;h<8;h++) buf[(i*8+k)*SampRate_Y_H*8+j*8+h]=*pQtZzMCU++; } extern u16 POINT_COLOR;//默认红色 //将解出的字按RGB形式存储 lpbmp (BGR),(BGR) ......入口Y[] U[] V[] 出口lpPtr void StoreBuffer() { short i,j; unsigned char R,G,B; int y,u,v,rr,gg,bb; long color; for(i=0;i if((sizei+i) for(j=0;j if((sizej+j) y=Y[i*8*SampRate_Y_H+j]; u=U[(i/V_YtoU)*8*SampRate_Y_H+j/H_YtoU]; v=V[(i/V_YtoV)*8*SampRate_Y_H+j/H_YtoV]; rr=((y<<8)+18*u+367*v)>>8; gg=((y<<8)-159*u-220*v)>>8; bb=((y<<8)+411*u-29*v)>>8; R=(unsigned char)rr; G=(unsigned char)gg; B=(unsigned char)bb; if (rr&0xffffff00) if (rr>255) R=255; else if (rr<0) R=0; if (gg&0xffffff00) if (gg>255) G=255; else if (gg<0) G=0; if (bb&0xffffff00) if (bb>255) B=255; else if (bb<0) B=0; color=R>>3; color=color<<6; color |=(G>>2); color=color<<5; color |=(B>>3); //在这里送给LCD显示 POINT_COLOR=color; LCD_DrawPoint(sizej+j+CurX,sizei+i+CurY);//显示图片 } else break; } } else break; } } |
5个回答
//Huffman Decode MCU 出口 MCUBuffer 入口Blockbuffer[ ]
int DecodeMCUBlock() { short *lpMCUBuffer; short i,j; int funcret; if (IntervalFlag)//差值复位 { lp+=2; ycoef=ucoef=vcoef=0; BitPos=0; CurByte=0; } switch(comp_num) { case 3: //comp_num 指图的类型(彩色图、灰度图) lpMCUBuffer=MCUBuffer; for (i=0;i funcret=HufBlock(YDcIndex,YAcIndex);//解码4 * (8*8) if (funcret!=FUNC_OK) return funcret; BlockBuffer[0]=BlockBuffer[0]+ycoef;//直流分量是差值,所以要累加。 ycoef=BlockBuffer[0]; for (j=0;j<64;j++) *lpMCUBuffer++=BlockBuffer[j]; } for (i=0;i funcret=HufBlock(UVDcIndex,UVAcIndex); if (funcret!=FUNC_OK) return funcret; BlockBuffer[0]=BlockBuffer[0]+ucoef; ucoef=BlockBuffer[0]; for (j=0;j<64;j++) *lpMCUBuffer++=BlockBuffer[j]; } for (i=0;i funcret=HufBlock(UVDcIndex,UVAcIndex); if (funcret!=FUNC_OK) return funcret; BlockBuffer[0]=BlockBuffer[0]+vcoef; vcoef=BlockBuffer[0]; for (j=0;j<64;j++) *lpMCUBuffer++=BlockBuffer[j]; } break; case 1: //Gray Picture lpMCUBuffer=MCUBuffer; funcret=HufBlock(YDcIndex,YAcIndex); if (funcret!=FUNC_OK) return funcret; BlockBuffer[0]=BlockBuffer[0]+ycoef; ycoef=BlockBuffer[0]; for (j=0;j<64;j++) *lpMCUBuffer++=BlockBuffer[j]; for (i=0;i<128;i++) *lpMCUBuffer++=0; break; default: return FUNC_FORMAT_ERROR; } return FUNC_OK; } //Huffman Decode (8*8) DU 出口 Blockbuffer[ ] 入口 vvalue int HufBlock(BYTE dchufindex,BYTE achufindex) { short count=0; short i; int funcret; //dc HufTabIndex=dchufindex; funcret=DecodeElement(); if(funcret!=FUNC_OK) return funcret; BlockBuffer[count++]=vvalue;//解出的直流系数 //ac HufTabIndex=achufindex; while (count<64) { funcret=DecodeElement(); if(funcret!=FUNC_OK) return funcret; if ((rrun==0)&&(vvalue==0)) { for (i=count;i<64;i++) BlockBuffer=0; count=64; } else { for (i=0;i BlockBuffer[count++]=vvalue;//解出的值 } } return FUNC_OK; } //Huffman 解码 每个元素 出口 vvalue 入口 读文件ReadByte int DecodeElement() { int thiscode,tempcode; unsigned short temp,valueex; short codelen; BYTE hufexbyte,runsize,tempsize,sign; BYTE newbyte,lastbyte; if(BitPos>=1) //BitPos指示当前比特位置 { BitPos--; thiscode=(BYTE)CurByte>>BitPos;//取一个比特 CurByte=CurByte&And[BitPos]; //清除取走的比特位 } else //取出的一个字节已用完 { //新取 lastbyte=ReadByte(); //读出一个字节 BitPos--; //and[]:=0x0,0x1,0x3,0x7,0xf,0x1f,0x2f,0x3f,0x4f newbyte=CurByte&And[BitPos]; thiscode=lastbyte>>7; CurByte=newbyte; } codelen=1; //与Huffman表中的码字匹配,直自找到为止 while ((thiscode (thiscode>huf_max_value[HufTabIndex][codelen-1])) { if(BitPos>=1)//取出的一个字节还有 { BitPos--; tempcode=(BYTE)CurByte>>BitPos; CurByte=CurByte&And[BitPos]; } else { lastbyte=ReadByte(); BitPos--; newbyte=CurByte&And[BitPos]; tempcode=(BYTE)lastbyte>>7; CurByte=newbyte; } thiscode=(thiscode<<1)+tempcode; codelen++; if(codelen>16)return FUNC_FORMAT_ERROR; } //while temp=thiscode-huf_min_value[HufTabIndex][codelen-1]+code_pos_table[HufTabIndex][codelen-1]; hufexbyte=(BYTE)code_value_table[HufTabIndex][temp]; rrun=(short)(hufexbyte>>4); //一个字节中,高四位是其前面的零的个数。 runsize=hufexbyte&0x0f; //后四位为后面字的尺寸 if(runsize==0) { vvalue=0; return FUNC_OK; } tempsize=runsize; if(BitPos>=runsize) { BitPos-=runsize; valueex=(BYTE)CurByte>>BitPos; CurByte=CurByte&And[BitPos]; } else { valueex=CurByte; tempsize-=BitPos; while(tempsize>8) { lastbyte=ReadByte(); valueex=(valueex<<8)+(BYTE)lastbyte; tempsize-=8; } //while lastbyte=ReadByte(); BitPos-=tempsize; valueex=(valueex< CurByte=lastbyte&And[BitPos]; } //else sign=valueex>>(runsize-1); if(sign)vvalue=valueex;//解出的码值 else { valueex=valueex^0xffff; temp=0xffff< } return FUNC_OK; } //反量化MCU中的每个组件 入口 MCUBuffer 出口 QtZzMCUBuffer void IQtIZzMCUComponent(short flag) { short H,VV; short i,j; int *pQtZzMCUBuffer; short *pMCUBuffer; switch(flag){ case 0: H=SampRate_Y_H; VV=SampRate_Y_V; pMCUBuffer=MCUBuffer; pQtZzMCUBuffer=QtZzMCUBuffer; break; case 1: H=SampRate_U_H; VV=SampRate_U_V; pMCUBuffer=MCUBuffer+Y_in_MCU*64; pQtZzMCUBuffer=QtZzMCUBuffer+Y_in_MCU*64; break; case 2: H=SampRate_V_H; VV=SampRate_V_V; pMCUBuffer=MCUBuffer+(Y_in_MCU+U_in_MCU)*64; pQtZzMCUBuffer=QtZzMCUBuffer+(Y_in_MCU+U_in_MCU)*64; break; } for(i=0;i } //要量化的字 //反量化 8*8 DU void IQtIZzBlock(short *s ,int * d,short flag) { short i,j; short tag; short *pQt; int buffer2[8][8]; int *buffer1; short offset; switch(flag) { case 0: //亮度 pQt=YQtTable; offset=128; break; case 1: //红 pQt=UQtTable; offset=0; break; case 2: //蓝 pQt=VQtTable; offset=0; break; } for(i=0;i<8;i++) for(j=0;j<8;j++) { tag=Zig_Zag[j]; buffer2[j]=(int)s[tag]*(int)pQt[tag]; } buffer1=(int *)buffer2; Fast_IDCT(buffer1);//反DCT for(i=0;i<8;i++) for(j=0;j<8;j++) d[i*8+j]=buffer2[j]+offset; } //快速反DCT void Fast_IDCT(int * block) { short i; for (i=0; i<8; i++)idctrow(block+8*i); for (i=0; i<8; i++)idctcol(block+i); } //从源文件读取一个字节 BYTE ReadByte() { BYTE i; i=*(lp++);// lp 为解码的起始位置 if(i==0xff)lp++; BitPos=8; CurByte=i; return i; } //初始化快速反DCT void Initialize_Fast_IDCT() { short i; iclp = iclip+512; for (i= -512; i<512; i++) iclp = (i<-256) ? -256 : ((i>255) ? 255 : i); } //////////////////////////////////////////////////////////////////////// void idctrow(int * blk) { int x0, x1, x2, x3, x4, x5, x6, x7, x8; //intcut if (!((x1 = blk[4]<<11) | (x2 = blk[6]) | (x3 = blk[2]) | (x4 = blk[1]) | (x5 = blk[7]) | (x6 = blk[5]) | (x7 = blk[3]))) { blk[0]=blk[1]=blk[2]=blk[3]=blk[4]=blk[5]=blk[6]=blk[7]=blk[0]<<3; return; } x0 = (blk[0]<<11) + 128; // for proper rounding in the fourth stage //first stage x8 = W7*(x4+x5); x4 = x8 + (W1-W7)*x4; x5 = x8 - (W1+W7)*x5; x8 = W3*(x6+x7); x6 = x8 - (W3-W5)*x6; x7 = x8 - (W3+W5)*x7; //second stage x8 = x0 + x1; x0 -= x1; x1 = W6*(x3+x2); x2 = x1 - (W2+W6)*x2; x3 = x1 + (W2-W6)*x3; x1 = x4 + x6; x4 -= x6; x6 = x5 + x7; x5 -= x7; //third stage x7 = x8 + x3; x8 -= x3; x3 = x0 + x2; x0 -= x2; x2 = (181*(x4+x5)+128)>>8; x4 = (181*(x4-x5)+128)>>8; //fourth stage blk[0] = (x7+x1)>>8; blk[1] = (x3+x2)>>8; blk[2] = (x0+x4)>>8; blk[3] = (x8+x6)>>8; blk[4] = (x8-x6)>>8; blk[5] = (x0-x4)>>8; blk[6] = (x3-x2)>>8; blk[7] = (x7-x1)>>8; } ////////////////////////////////////////////////////////////////////////////// void idctcol(int * blk) { int x0, x1, x2, x3, x4, x5, x6, x7, x8; //intcut if (!((x1 = (blk[8*4]<<8)) | (x2 = blk[8*6]) | (x3 = blk[8*2]) | (x4 = blk[8*1]) | (x5 = blk[8*7]) | (x6 = blk[8*5]) | (x7 = blk[8*3]))) { blk[8*0]=blk[8*1]=blk[8*2]=blk[8*3]=blk[8*4]=blk[8*5] =blk[8*6]=blk[8*7]=iclp[(blk[8*0]+32)>>6]; return; } x0 = (blk[8*0]<<8) + 8192; //first stage x8 = W7*(x4+x5) + 4; x4 = (x8+(W1-W7)*x4)>>3; x5 = (x8-(W1+W7)*x5)>>3; x8 = W3*(x6+x7) + 4; x6 = (x8-(W3-W5)*x6)>>3; x7 = (x8-(W3+W5)*x7)>>3; //second stage x8 = x0 + x1; x0 -= x1; x1 = W6*(x3+x2) + 4; x2 = (x1-(W2+W6)*x2)>>3; x3 = (x1+(W2-W6)*x3)>>3; x1 = x4 + x6; x4 -= x6; x6 = x5 + x7; x5 -= x7; //third stage x7 = x8 + x3; x8 -= x3; x3 = x0 + x2; x0 -= x2; x2 = (181*(x4+x5)+128)>>8; x4 = (181*(x4-x5)+128)>>8; //fourth stage blk[8*0] = iclp[(x7+x1)>>14]; blk[8*1] = iclp[(x3+x2)>>14]; blk[8*2] = iclp[(x0+x4)>>14]; blk[8*3] = iclp[(x8+x6)>>14]; blk[8*4] = iclp[(x8-x6)>>14]; blk[8*5] = iclp[(x0-x4)>>14]; blk[8*6] = iclp[(x3-x2)>>14]; blk[8*7] = iclp[(x7-x1)>>14]; } |
void udp_demo_test(void)
{ err_t err; struct udp_pcb *udppcb; //定义一个TCP服务器控制块 struct ip_addr rmtipaddr; //远端ip地址 u8 *tbuf; u8 key; u8 res=0; u8 t=0; u8 jpeg_num=0; //u8 *loadjpeg; //u8 load_i; u8 load_i=0; u8 load_j=0; udp_demo_set_remoteip();//先选择IP LCD_Clear(WHITE); //清屏 POINT_COLOR=RED; //红色字体 LCD_ShowString(30,30,200,16,16,"Explorer STM32F4"); LCD_ShowString(30,50,200,16,16,"UDP Test"); LCD_ShowString(30,70,200,16,16,"ATOM@ALIENTEK"); LCD_ShowString(30,90,200,16,16,"KEY0:Send data"); LCD_ShowString(30,110,200,16,16,"KEY_UPuit"); LCD_ShowString(30,130,200,16,16,"KEY1:Connect"); tbuf=mymalloc(SRAMIN,200); //申请内存 udp_demo_recvbuf=mymalloc(SRAMEX,4096*3*2); //申请内存 memset(udp_demo_recvbuf,0,4096*3*2); //数据接收缓冲区清零 loadjpeg=udp_demo_recvbuf; if(tbuf==NULL)return ; //内存申请失败了,直接退出 sprintf((char*)tbuf,"Local IP:%d.%d.%d.%d",lwipdev.ip[0],lwipdev.ip[1],lwipdev.ip[2],lwipdev.ip[3]);//服务器IP LCD_ShowString(30,150,210,16,16,tbuf); sprintf((char*)tbuf,"Remote IP:%d.%d.%d.%d",lwipdev.remoteip[0],lwipdev.remoteip[1],lwipdev.remoteip[2],lwipdev.remoteip[3]);//远端IP LCD_ShowString(30,170,210,16,16,tbuf); sprintf((char*)tbuf,"Remote Port:%d",UDP_DEMO_PORT);//客户端端口号 LCD_ShowString(30,190,210,16,16,tbuf); POINT_COLOR=BLUE; LCD_ShowString(30,210,210,16,16,"STATUSisconnected"); udppcb=udp_new(); if(udppcb)//创建成功 { IP4_ADDR(&rmtipaddr,lwipdev.remoteip[0],lwipdev.remoteip[1],lwipdev.remoteip[2],lwipdev.remoteip[3]); err=udp_connect(udppcb,&rmtipaddr,UDP_DEMO_PORT);//UDP客户端连接到指定IP地址和端口号的服务器 if(err==ERR_OK) { err=udp_bind(udppcb,IP_ADDR_ANY,UDP_DEMO_PORT);//绑定本地IP地址与端口号 if(err==ERR_OK) //绑定完成 { udp_recv(udppcb,udp_demo_recv,NULL);//注册接收回调函数 LCD_ShowString(30,210,210,16,16,"STATUS:Connected ");//标记连接上了(UDP是非可靠连接,这里仅仅表示本地UDP已经准备好) udp_demo_flag |= 1<<5; //标记已经连接上 POINT_COLOR=RED; LCD_ShowString(30,230,lcddev.width-30,lcddev.height-190,16,"Receive Data:");//提示消息 POINT_COLOR=BLUE;//蓝色字体 }else res=1; }else res=1; }else res=1; while(res==0) { key=KEY_Scan(0); if(key==WKUP_PRES)break; if(key==KEY0_PRES)//KEY0按下了,发送数据 { udp_demo_senddata(udppcb); } if(udp_demo_flag&1<<6)//是否收到数据? { jpeg_num++; if(jpeg_num%2==0)LCD_Clear(WHITE); //清屏 else LCD_Clear(BLACK); //清屏 delay_ms(500); udp_demo_flag&=~(1<<6);//标记数据已经被处理了. } udp_jpeg=udp_demo_recvbuf+jpeg_num*4096; if((load_j==1)&&(jpeg_num==3)) { memset(udp_demo_recvbuf+1024*12,0,12*1024); } if((load_j==1)&&(jpeg_num<3)) { load_i=0; loadjpeg=udp_demo_recvbuf+4096*3; LoadJpegFile(loadjpeg); delay_ms(1800); delay_ms(1800); } if((udp_jpeg-udp_demo_recvbuf)>4096*2) { if(load_j==1) { loadjpeg=udp_demo_recvbuf; //memset(udp_demo_recvbuf+1024*12,0,12*1024); } LoadJpegFile(loadjpeg); delay_ms(1800); delay_ms(1800); if(((udp_jpeg-udp_demo_recvbuf)%(4096*3)==0)&&((udp_jpeg-udp_demo_recvbuf)>4096*3)) { load_i++; // if((load_i>0)&&(load_j==1)) // { // //memset(udp_demo_recvbuf+1024*12,0,12*1024); // load_i=0; // } loadjpeg=udp_demo_recvbuf+4096*3*load_i; //loadjpeg=udp_demo_recvbuf; LoadJpegFile(loadjpeg); delay_ms(1800); delay_ms(1800); } } if((jpeg_num%6==0)&&(jpeg_num>0)) { jpeg_num=0; memset(udp_demo_recvbuf,0,12*1024); udp_jpeg=udp_demo_recvbuf; load_j=1; } lwip_periodic_handle(); delay_ms(2); t++; if(t==200) { t=0; LED0=!LED0; } } udp_demo_connection_close(udppcb); myfree(SRAMIN,tbuf); myfree(SRAMEX,udp_demo_recvbuf); } //UDP回调函数 void udp_demo_recv(void *arg,struct udp_pcb *upcb,struct pbuf *p,struct ip_addr *addr,u16_t port) { u32 data_len = 0; struct pbuf *q; if(p!=NULL) //接收到不为空的数据时 { // memset(udp_demo_recvbuf,0,UDP_DEMO_RX_BUFSIZE); //数据接收缓冲区清零 for(q=p;q!=NULL;q=q->next) //遍历完整个pbuf链表 { //判断要拷贝到UDP_DEMO_RX_BUFSIZE中的数据是否大于UDP_DEMO_RX_BUFSIZE的剩余空间,如果大于 //的话就只拷贝UDP_DEMO_RX_BUFSIZE中剩余长度的数据,否则的话就拷贝所有的数据 if(q->len > (UDP_DEMO_RX_BUFSIZE-data_len)) memcpy(udp_jpeg+data_len,q->payload,(UDP_DEMO_RX_BUFSIZE-data_len));//拷贝数据 else memcpy(udp_jpeg+data_len,q->payload,q->len); data_len += q->len; if(data_len > UDP_DEMO_RX_BUFSIZE) break; //超出TCP客户端接收数组,跳出 } upcb->remote_ip=*addr; //记录远程主机的IP地址 upcb->remote_port=port; //记录远程主机的端口号 lwipdev.remoteip[0]=upcb->remote_ip.addr&0xff; //IADDR4 lwipdev.remoteip[1]=(upcb->remote_ip.addr>>8)&0xff; //IADDR3 lwipdev.remoteip[2]=(upcb->remote_ip.addr>>16)&0xff;//IADDR2 lwipdev.remoteip[3]=(upcb->remote_ip.addr>>24)&0xff;//IADDR1 udp_demo_flag|=1<<6; //标记接收到数据了 // LCD_Clear(BLACK); // LoadJpegFile(udp_demo_recvbuf); // delay_ms(1800); // delay_ms(1800); pbuf_free(p);//释放内存 }else { udp_disconnect(upcb); LCD_Clear(WHITE); //清屏 POINT_COLOR = RED; LCD_ShowString(30,30,200,16,16,"Explorer STM32F4"); LCD_ShowString(30,50,200,16,16,"UDP Test"); LCD_ShowString(30,70,200,16,16,"ATOM@ALIENTEK"); POINT_COLOR=BLUE; LCD_ShowString(30,90,200,16,16,"Connect break!"); LCD_ShowString(30,110,200,16,16,"KEY1:Connect"); udp_demo_flag &= ~(1<<5); //标记连接断开 } |
第一个和第二个是一个网友提供的jpeg解码函数,只要修改画点函数就可以了,为什么没用原子哥的函数,是因为ai_load 那个是打开文件夹的方式解码,不是很透明,这个相对来说好一点
本人在这里抛砖引玉,也是刚学stm32不久,上面代码存在以下问题:
1. 为什么用调试助手 时间间隔在1000ms容易丢包?在5000ms会正常。 2.有没有一款c语言的网络通信代码(小弟比较笨,没找到),希望大家发一个,调试助手的局限非常大还不透明——本代码支持数据的方式发送4096 3.不知道为什么用文件流的方式,每次是4096字节?? 用的是winhex和ue来转换图片为二进制,txt发送的 4.lwip的协议栈的内存多大?不是很清楚~~麻烦指点 |
谢谢 格纹论坛大神的指点~~
只有小组成员才能发言,加入小组>>
如何使用STM32+nrf24l01架构把有线USB设备无线化?
2571 浏览 7 评论
请问能利用51单片机和nRF24L01模块实现实时语音无线传输吗?
2366 浏览 5 评论
3212 浏览 3 评论
2839 浏览 8 评论
为什么ucosii上移植lwip后系统进入了HardFault_Handler?
2791 浏览 4 评论
请教各位大咖:有没有接收频率32M左右的芯片推荐的?先感谢啦!
669浏览 1评论
906浏览 0评论
1027浏览 0评论
672浏览 0评论
500浏览 0评论
GMT+8, 2024-12-24 04:52 , Processed in 1.505708 second(s), Total 90, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
