5962-87702042X 产品描述 CMOS 12-Bit Buffered Multiplying DAC With Internal Data Latches 封装 20 ld LCC
AD7545ATQ 产品描述 CMOS 12-Bit Buffered Multiplying DAC With Internal Data Latches 封装 20 ld CerDIP AD7545AUQ 产品描述 CMOS 12-Bit Buffered Multiplying DAC With Internal Data Latches 封装 20 ld CerDIP 5962-89657023A 产品描述 Dual 12-Bit CMOS DAC with Parallel Load Input Structure 封装 28 ld LCC 5962-8965702LX 产品描述 Dual 12-Bit CMOS DAC with Parallel Load Input Structure 封装 24 ld CerDIP GLASS SEAL 5962-8965703LX 产品描述 Dual 12-Bit CMOS DAC with Parallel Load Input Structure 封装 24 ld CerDIP GLASS SEAL AD7548TQ/883B 产品描述 12-Bit, Multiplying, IOUT DAC, 8-Bit Bus 封装 20 ld CerDIP 5962-8876501RX 产品描述 12-Bit, Dual, Multiplying, Iout 封装 20 ld CerDIP GLASS SEAL 5962-8876502RX 产品描述 12-Bit, Dual, Multiplying, Iout 封装 20 ld CerDIP GLASS SEAL AD766SD/883B 产品描述 16-Bit Current-Steering DAC with Voltage Reference 封装 16 ld Side-Brazed CerDIP? 5962-8961701LA 产品描述 Microprocessor-Compatible 12-Bit D/A Converter 封装 24 ld S/B or B/B CerDIP AD767SD/883B 产品描述 Microprocessor-Compatible 12-Bit D/A Converter 封装 24 ld S/B or B/B CerDIP 5962-9451801MLA 产品描述 LC2MOS Complete, Dual 12-Bit MDAC, (8 + 4) Loading Structure 封装 24 ld CerDIP GLASS SEAL AD7837SQ 产品描述 LC2MOS Complete, Dual 12-Bit MDAC, (8 + 4) Loading Structure 封装 24 ld CerDIP GLASS SEAL AD7840SQ/883B 产品描述 Complete 14-Bit CMOS DAC 封装 24 ld CerDIP GLASS SEAL AD7845SQ 产品描述 Complete 12-Bit CMOS Multiplying DAC 封装 24 ld CerDIP GLASS SEAL AD7845SQ/883B 产品描述 Complete 12-Bit CMOS Multiplying DAC 封装 24 ld CerDIP GLASS SEAL AD7845TQ 产品描述 Complete 12-Bit CMOS Multiplying DAC 封装 24 ld CerDIP GLASS SEAL AD7845TQ 产品描述 Complete 12-Bit CMOS Multiplying DAC 封装 24 ld CerDIP GLASS SEAL 5962-89697013A 产品描述 16-Bit Voltage Output CMOS DAC 封装 28 ld LCC 5962-8969701XA 产品描述 16-Bit Voltage Output CMOS DAC 封装 28 ld CerDIP GLASS SEAL 5962-9461802MLA 产品描述 LC2MOS Complete, Dual 12-Bit MDAC, Parallel Loading Structure 封装 24 ld CerDIP GLASS SEAL 产品描述 LC2MOS Complete, Dual 12-Bit MDAC, Parallel Loading Structure ADDAC87CBI-V 产品描述 Complete Low Cost Hybrid 12-Bit D/A Converter, -55 to +125°C 封装 24 ld CerDIP (Hybrid Side-Brazed) ADDAC87CBI-V/883B 产品描述 Complete Low Cost Hybrid 12-Bit D/A Converter, -55 to +125°C 封装 24 ld CerDIP (Hybrid Side-Brazed) 5962-8757101XA 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack 5962-8757102XA 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack 5962-8757103XA 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack 5962-8757104XA 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590JF 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590JF/883B 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590KF 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590KF/883B 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590KR 产品描述 Two Terminal IC Temperature Transducer 封装 8 ld SOIC AD590LF 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590LF/883B 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590MF 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack AD590MF/883B 产品描述 Two Terminal IC Temperature Transducer 封装 2 ld Flat Pack 5962-89805012A 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 20 ld LCC 5962-8980501CA 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 14 ld Bottom-Brazed CerDIP 5962-8980501IA 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 10 ld TO_100 AD536ASD 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 14 ld Bottom-Brazed CerDIP AD536ASD/883B 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 14 ld Bottom-Brazed CerDIP AD536ASE/883B 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 20 ld LCC AD536ASH 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 10 ld TO_100 AD536ASH/883B 产品描述 Complete Monolithic IC Which Performs True RMS-to-DC Conversion 封装 10 ld TO_100 5962-8963701CA 产品描述 High Precision, Wideband RMS-to-DC Converter 封装 14 ld CerDIP AD637SD 产品描述 High Precision, Wideband RMS-to-DC Converter 封装 14 ld Bottom-Brazed CerDIP AD637SD/883B 产品描述 High Precision, Wideband RMS-to-DC Converter 封装 14 ld Bottom-Brazed CerDIP AD637SQ/883B 产品描述 High Precision, Wideband RMS-to-DC Converter 封装 14 ld CerDIP AD1362SD/883B 产品描述 16-Channel, 12-Bit Data Acquisition System 封装 32 ld BB Hybrid DIP AD2S44-TM11B 产品描述 Low Cost, 14-Bit, Dual Channel Synchro/Resolver-to-Digital? 封装 32 ld BB Hybrid DIP AD2S44-TM12B 产品描述 Low Cost, 14-Bit, Dual Channel Synchro/Resolver-to-Digital? 封装 32 ld BB Hybrid DIP AD2S44-TM18B 产品描述 Low Cost, 14-Bit, Dual Channel Synchro/Resolver-to-Digital? 封装 32 ld BB Hybrid DIP AD2S44-UM18B 产品描述 Low Cost, 14-Bit, Dual Channel Synchro/Resolver-to-Digital? 封装 32 ld BB Hybrid DIP 5962-8982401PA 产品描述 High Precision 5 V Reference 封装 8 ld CerDIP 5962-8982402PA 产品描述 High Precision 5 V Reference 封装 8 ld CerDIP AD586SQ 产品描述 High Precision 5 V Reference 封装 8 ld CerDIP AD586TQ 产品描述 High Precision 5 V Reference 封装 8 ld CerDIP 5962-8982502PA 产品描述 High Precision 10 V Reference 封装 8 ld CerDIP 5962-8982503PA 产品描述 High Precision 10 V Reference 封装 8 ld CerDIP AD587UQ 产品描述 High Precision 10 V Reference 封装 8 ld CerDIP 5962-89728022A 产品描述 High Precision Voltage Reference 封装 20 ld LCC AD588TE/883B 产品描述 High Precision Voltage Reference 封装 20 ld LCC AD588TQ/883B 产品描述 High Precision Voltage Reference 封装 16 ld CerDIP 5962-9321401MEA 产品描述 High Precision ±10 V Reference 封装 16 ld CerDIP 62-8958101PA 产品描述 +10V Precision Voltage Reference 封装 8 ld CerDIP GLASS SEAL REF01AJ/883C 产品描述 +10V Precision Voltage Reference 封装 8 ld Header 85514012A 产品描述 +5V Precision Voltage Reference/Temperature Transducer 封装 20 ld LCC |
相关推荐 |
GMT+8, 2024-9-29 05:01 , Processed in 0.584741 second(s), Total 66, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
