你好Gregg C Levine之前我发现自己重新发明轮子我以为我会问问题。可以用VEE来收集来自一个I / O设备的数据,比如一个RS232port,然后将它流式传输到另一个吗?
显然,两个类似的设备会有不同的地址,以免混淆系统.--- Gregg C Levine 以上来自于谷歌翻译 以下为原文 Hello from Gregg C Levine Before I find myself reinventing the wheel I thought I'd ask a question. Can VEE be used to collect data from one I/O Device, say an RS232 port, and then stream it to another? Obviously both devices while similar would have different addresses to save confusing the system. --- |
3个回答
大家好,我们有兴趣获得一个允许创建我们自己的PID方程的运动控制器。
我们的项目需要有一个运动控制器,允许我们根据系统的负载重新计算PID方程(实时可用!),有时是非常惯性的负载,有时非常摩擦,有间隙传输和几个位置精度。我们有 看着加利尔和国民的产品,但似乎没有一个(或至少没有明确说明..),有这样的低级别控制。 你们中的任何一个都有运动控制器的经验,允许这种低水平????谢谢提前,ÂPaco---要订阅发送空白电子邮件请求到“join-vrf@lists.it.agilent.com”。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“www.oswegosw.com/vrf_archive/”上搜索“unofficial vrf archive”。 以上来自于谷歌翻译 以下为原文 Hello all, Â Â We are interested in acquiring a motion controller that permits to create our own PID equations. Our project needs to have a motion controller that allows us to recalculate the PID equation depending on the load of the system (real time if available!), sometimes very inertial loads, sometimes very frictionals, with backlash transmisions and several position accuracy. Â We have looked to Galil and National products but none of them seems (or at least is not clearly specified..), to have such low-level control. Any of you has experience with motion controllers that allows this low level???? Â Â Thanks in advance, Â Â Paco --- To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 10:09 , Processed in 0.807435 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2228
