图片中是遇到的问题:
下面是SPICE Error Log: Circuit: * G:LTspice projecttiA design2.asc WARNING: Node N002 is floating. WARNING: Less than two connections to node +5V. This node is used by V1. WARNING: Less than two connections to node -5V. This node is used by V2. WARNING: Less than two connections to node U1:100. This node is used by S:U1:2. WARNING: Less than two connections to node U1:101. This node is used by S:U1:3. WARNING: Less than two connections to node U1:105. This node is used by R:U1:F. WARNING: Less than two connections to node VO1. This node is used by R1. Direct Newton iteration failed to find .op point. (Use ".option noopiter" to skip.) Starting Gmin stepping Gmin = 10 vernier = 0.5 Gmin = 2.07126 vernier = 0.25 vernier = 0.125 vernier = 0.0625 vernier = 0.03125 Gmin = 2.20755 vernier = 0.015625 vernier = 0.0208333 Gmin = 2.13698 vernier = 0.0277778 vernier = 0.037037 Gmin = 1.99182 vernier = 0.0493827 Gmin = 1.78347 vernier = 0.0658435 vernier = 0.0877914 Gmin = 1.48254 vernier = 0.117055 vernier = 0.156073 Gmin = 1.10597 vernier = 0.0780367 vernier = 0.0390184 vernier = 0.0195092 vernier = 0.00975459 vernier = 0.0048773 vernier = 0.00243865 Gmin = 1.02446 vernier = 0.00121932 vernier = 0.000609662 vernier = 0.000457246 Gmin = 0 Gmin stepping failed Starting source stepping with srcstepmethod=0 Could not converge to DC with sources off! Starting source stepping with srcstepmethod=1 Could not converge to DC with sources off! Singular matrix: Check node u1:106 Iteration No. 16 Fatal Error: Singular matrix: check node u1:106 Iteration No. 16 This circuit has floating nodes.
1个回答
是不是电路没接地。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
252 浏览 0 评论
5V供电情况下JFET前级放大电路怎么实现,JFET能不能先将信号放大到2-3mv,然后在用单运放进行1000倍左右放大?
2020 浏览 0 评论
1209 浏览 0 评论
USB Type-C的双角色端口(DRP)我这样设计可以吗?
752 浏览 0 评论
1911 浏览 0 评论
/9
GMT+8, 2025-12-2 12:24 , Processed in 0.612825 second(s), Total 74, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2302
