问题:
1、启动起来(ttl连接)会在第4行(config u***..)停顿一下,然后就直接到最后一行了(中间内容一闪就打印完了),没有选择时间 2、完全启动后,键盘无法输入任何命令? 下面是启动的前部分过程。 U-Boot 1.1.3 (May 4 2013 - 16:04:53) Board: Ralink APSoC DRAM: 64 MB relocate_code Pointer at: 83fac000 config u***.. Set info->start[0]=BF000000 flash id 0x227e, sector count 128, size 0x800000 flash_protect ON: from 0xBF000000 to 0xBF01F6CF flash_protect ON: from 0xBF030000 to 0xBF030FFF *** Warning - bad CRC, using default environment ============================================ Ralink UBoot Version: 3.5.2.0 -------------------------------------------- ASIC 3052_MP2 (Port5<->None) DRAM component: 256 Mbits SDR DRAM bus: 32 bit Total memory: 64 MBytes Flash component: NOR Flash Date:May 4 2013 time:16:04:53 ============================================ icache: sets:256, ways:4, linesz:32 ,total:32768 dcache: sets:128, ways:4, linesz:32 ,total:16384 ##### The CPU freq = 384 MHZ #### SDRAM bus set to 32 bit estimate memory size =64 Mbytes Please choose the operation: 1: Load system code to SDRAM via TFTP. 2: Load system code then write to Flash via TFTP. 3: Boot system code via Flash (default). 4: Entr boot command line interface. 7: Load Boot Loader code then write to Flash via Serial. 9: Load Boot Loader code then write to Flash via TFTP. You choosed 0 3: System Boot system code via Flash. ## Booting image at bf050000 ... Image Name: Linux Kernel Image Created: 2013-10-24 14:14:45 UTC Image Type: MIPS Linux Kernel Image (lzma compressed) Data Size: 7255009 Bytes = 6.9 MB Load Address: 80000000 Entry Point: 803b8000 Verifying Checksum ... |
1个回答
只有小组成员才能发言,加入小组>>
197个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2106 浏览 6 评论
1919 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4482 浏览 1 评论
GMT+8, 2024-9-27 06:53 , Processed in 0.551175 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
