我可能会打死马,但我想知道是否可以编程一个古老的6002A电源。
我真正想做的就是能够将电压设置为0 V或48 V.因此,我不需要“编程”它,因为我需要能够远程打开/关闭它。我需要 有一个82357A USB到HPIB适配器和Agilent I / O套件16.0。 我希望能够使用“Agilent Connection Expert”gui中的“向该仪器发送命令”。 我不知道怎么做.6002手册谈到从计算器发送命令,命令是CMD“?U%”,“2960”或cmd 7,“?U%”,“2960”的形式 :? 是unlisten命令U是计算器通话地址%是6002监听地址2999是电源的第二范围(960)(。05V)= 48V outputThanks,DJL 以上来自于谷歌翻译 以下为原文 I may be beating a dead horse, but I'm wondering if it is possible to program an ancient 6002A power supply. All I really want to do is to be able to set the voltage to 0 V or 48 V. So, I don't need to "program" it as much as I need to be able to turn it on/off remotely. I have an 82357A USB to HPIB adapter and Agilent I/O suite 16.0. I would like to be able to just use the "Send commands to this instrument" from the "Agilent Connection Expert" gui. I do not see how to do that. The 6002 manual talks about sending commands from a calculator, the commands are in the form of CMD "?U%", "2960" or cmd 7, "?U%", "2960" Where: ? is the unlisten command U is the calculator talk address % is the 6002 listen address 2999 is the supply's 2nd range (960)(.05V)= 48V output Thanks, DJL |
3个回答
嗨,我从未见过这些耗材中的一个,但我做了一些挖掘,这个仪器上有一个GPIB(HP-IB)选项。
如果它有一个接口,你应该能够编程它。这是一个非常古老的电源,我从来没有使用它。 连接专家在扫描GPIB仪器时是否找到此电源? 如果它确实显示,你应该能够选择“发送命令...”从这个例子你不必担心“?U%”行,因为这是IO库的低级别GPIB寻址工作 为你。 它基本上释放了总线(?),说明控制器(在你的情况下是82357A)和监听器(6002A)。 如果它允许您发送命令,则只需发送数据字。 我要看看我们是否有这些产品中的一个,或者当这个产品还在销售时回到这里的其中一个人可以提供帮助。 以上来自于谷歌翻译 以下为原文 Hi, I have never seen one of these supplies but I did some digging and there was a GPIB (HP-IB) option on this instrument. If this does have a interface, you should be able to program it. This is a very old power supply and I have never used it. Does the connection expert find this power supply when it scans the GPIB instruments? If it does show up, you should be able to select "Send Commands ..." From the example you do no have to worry about the "?U%" line because that is low level GPIB addressing stuff that the IO Libraries will do for you. It is basically freeing up the bus (?) stating the controller (in your case the 82357A) and the listener (6002A). If it does allow you to send commands, you would just need to send the data word. I gotta see if we have one of these around or if one of the guys that were here back when this product was still being sold can help. |
感谢MattC的帮助!正如您的建议,最简单的答案是正确的答案。我所要做的就是从“安捷伦”的“向该仪器发送命令”对话框中输入命令字符串的“2960”部分
连接专家“gui and”发送“他们。谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Thanks for the help MattC! As you suggested, the simplest answer was the correct answer. All I had to do was enter the "2960" portion of the command string into the dialog box from "Send commands to this instrument" from the "Agilent Connection Expert" gui and "Send" them. Thanks for your help. |
它有效!
我试图看看我是否可以在办公室找到一个,但我没有太多运气。我很高兴你能够起床和奔跑。 以上来自于谷歌翻译 以下为原文 So it works! I was trying to see if I could find one in the office but I have not had much luck. I am glad you are up and running. |
只有小组成员才能发言,加入小组>>
971 浏览 0 评论
2250 浏览 1 评论
2028 浏览 1 评论
1907 浏览 5 评论
2772 浏览 3 评论
753浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
548浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
642浏览 0评论
2430浏览 0评论
1486浏览 0评论
GMT+8, 2024-9-5 11:24 , Processed in 1.340916 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
