ET5014 高速4路电平转换IC,强快速驱动 UQFN12 ET2104 4路电平转换IC,适用通讯电平转换, 开漏输入/输出. TSSOP10/CSP12 ET2102 2路电平转换IC,适用通讯电平转换, 开漏输入/输出. uDFN8 Features ● Bi-Directional Interface between Any Two Levels:1.65V to 5.5V ● No Direction Control Needed ● Internal 10K Pull-Up Resistors ● System GPIO Resources Not Required when OE tied to VCCA ● I2C-Bus Isolation ● A/B Port VOL = 175mV (Typical), VIL = 150mV, IOL = 6mA ● Open-Drain Inputs / Outputs ● Works in Push Pull Environment ● Accommodates Standard-Mode and Fast-Mode I2C-Bus Devices ● Supports I2C Clock Stretching & Multi-Master ● Fully Configurable: Inputs and Outputs Track VCC ● Non-Preferential Power-Up; Either VCC Can Power-Up First ● Outputs Switch to 3-State if Either VCC is at GND ● Tolerant Output Enable: 5V |
相关推荐 |
GMT+8, 2024-9-7 02:15 , Processed in 0.543360 second(s), Total 42, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
