您好,这是我的设置:-E3646A-串行电缆连接到连接到我的笔记本电脑的FTDI串口到USB适配器 - 使用Minicom作为我的终端-9600波特率,无奇偶校验,2个停止位当我启动设备时,
终端上没有弹出任何内容,我无法输入任何内容。 但是,我可以按下按键组合以获得设备上的错误,所以我知道至少有信号转到单元。 但是,终端没有提示。 任何想法?谢谢,杰克 以上来自于谷歌翻译 以下为原文 Hello, Here's my setup: -E3646A -Serial cable hooked up to an FTDI serial-to-USB adapter hooked up to my laptop -Using Minicom as my terminal -9600 baud rate, no parity, 2 stop bits When I start up the unit, nothing pops up on the terminal, and I'm not able to type anything. However, there are combinations of keys I can press to get an error on the unit, so I know there's at least signals going to unit. However, there's no prompt on the terminal. Any ideas? Thanks, Jake |
1个回答
你好,所以我下载了cutecom,并且能够通过RS-232成功地将命令发送到E3646A。
但是,当我输入查询时(例如'VOLT?'),我没有得到任何回报。 如果我之后尝试发出另一个命令,我会收到一个错误,输入410,'QUERY INTERRUPTED'。 我在另一个论坛上看到DTR / DSR握手的东西。 显然,回送信息的缓冲区未被成功清除。 这看起来应该是非常基本的,我已经得到了一些中国乐器,无需做任何特别的工作......杰克 以上来自于谷歌翻译 以下为原文 Hello, So I downloaded cutecom, and was able to successfully transmit commands over RS-232 to the E3646A. However, I'm not getting anything back when I type a query (e.g. 'VOLT?'). If I try to issue another command right afterwards, I get an error, type 410, 'QUERY INTERRUPTED'. I read in another forum post something at DTR/DSR handshaking. Obviously the buffer to send information back is not being cleared successfully. This seems like it should be pretty basic, I've gotten some knock-off Chinese instruments to work without having to do anything special... Jake |
只有小组成员才能发言,加入小组>>
2102 浏览 1 评论
1860 浏览 1 评论
1715 浏览 5 评论
2584 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1564 浏览 4 评论
505浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
364浏览 0评论
1413浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
275浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-29 01:53 , Processed in 1.065566 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
