嗨,我们正在与MIWI Pro合作,我们有一个PAN协调器和5-6个终端设备(节点设备)。它工作在星形拓扑中。我们检查了PAN协调器的代码以及终端设备。我们在PAN协调器代码(ConfigApp.h)中发现,它被定义为:#definenNWK_ROLE_COORDINATORfor终端设备,它被定义为:#definenNWK_ROLE_END_DEVICESo,对于网格拓扑,我们保持了泛坐标。tor和终端设备相距很远,这样范围就不会到达,而在中间级别,我们保留了另一个协调器(与pan协调器相同)。获得0x0100的短地址然后切换到终端设备。现在当我们从泛协调器发送命令时,它没有到达终端设备。可能有什么问题。任何人可以让我们工作网格堆栈。
以上来自于百度翻译 以下为原文 Hi, We are working with miwi pro where we have one pan coordinator and 5-6 end devices (node devices). it is working in star topology. We checked the code for PAN co-ordinator as well as end device. We have found in PAN co-ordinator code (ConfigApp.h) it is defined as: #define NWK_ROLE_COORDINATOR for end device it is defined as: #define NWK_ROLE_END_DEVICE So, for mesh topology we have kept pan co-ordinator and end device far apart such that range will not come, and in intermediate level we have kept another co-ordinator (same as that pan co-ordinator). first we have switched on pan co-ordinator, which is getting short address of 0x0000 then another co-ordinator (inter mediate co-ordinator) which is getting short address of 0x0100 then switched on end device. now when we are sending command from pan co-ordinator it is not reaching to end device. what could be problem. can any one could get us working mesh stack. |
只有小组成员才能发言,加入小组>>
4847 浏览 9 评论
1846 浏览 8 评论
1763 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2974 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2076 浏览 5 评论
472浏览 1评论
1123浏览 1评论
314浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
376浏览 0评论
270浏览 0评论
GMT+8, 2024-5-15 12:25 , Processed in 0.985466 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
