嗨,启动DAC时有点击声,现在我不想在DAC中断中浪费时间,但我还是想避免点击。因为没有办法访问DAC输出,所以不能在for循环中缓慢地构建,所以直接访问DAC输出是很方便的。我尝试了一些其他的方法:将更改通知中断设置为7,并设置标志,在中断中直接激活DAC,然后停留在中断中,用_._ms(1)构建中心点;仍然不能工作。那么,您如何用DSPIC33FJ128GP802内部DAC来修复它?问候语。
以上来自于百度翻译 以下为原文 Hi, there is a click sound when starting up the DAC, now i dont wanto waste cycles in the DAC interrupt, still i would like to avoid the click. Since there is no way to access the DAC output, you cannot build it slowly up in the for loop, it would be handy to have the DAC output directly accessible for this purpose. I tryd something else : Set the change notification interrupt to 7, and set the flag, in the interrupt directly activate the DAC, then stay in the interrupt, build the centerpoint up with _delay_ms( 1 ); Still not working. So how would you fix this with the DSPIC33FJ128GP802 internal DAC ? greetings. |
6个回答
嗨,我知道,我试图使用它:将更改通知中断设置为7,并设置标志,在中断中直接激活DAC,然后停留在中断中,用_._ms(1)@0构建中心点(DACDLFT);@0:我尝试在不浪费周期的情况下提升DAC,这就是全部要点。
以上来自于百度翻译 以下为原文 Hi, i know, i tryd to use it : Set the change notification interrupt to 7, and set the flag, in the interrupt directly activate the DAC, then stay in the interrupt, build the centerpoint (DACDLFT) up with _delay_ms( 1 ); @ zeros : i trying ramping up the DAC without wasting cycles, thats the whole point. |
DACDFLT将无法帮助:使用它导致一个“跳”到中点-据称确切地原因的阴谋!你必须“浪费”这些周期。他们没有被浪费——他们被“投资”到“反扑通”。
以上来自于百度翻译 以下为原文 DACDFLT won't help: using it results in a 'jump' to the midpoint - supposedly exactly the reason for the plot ! You'll have to 'waste' the cycles. They are not wasted - they are 'invested' into the 'anti-plop'. |
我想在启用int之前可能会增加DACDFLT?
以上来自于百度翻译 以下为原文 I was thinking of before enabling the int one might ramp up DACDFLT ? |
我假设int用于保持FIFO填充,如果FIFO是空的,那么DACDFLT将提供值。
以上来自于百度翻译 以下为原文 I was assuming the int was used to keep the fifo filled and if the fifo was empty then DACDFLT would supply the value |
对的。但是如果你喜欢,就有选择……创新!
以上来自于百度翻译 以下为原文 Correct. But if you like, there are options... Become innovative ! |
只有小组成员才能发言,加入小组>>
5110 浏览 9 评论
1969 浏览 8 评论
1907 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3138 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2206 浏览 5 评论
679浏览 1评论
561浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
431浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
580浏览 0评论
477浏览 0评论
GMT+8, 2024-10-22 01:17 , Processed in 1.158932 second(s), Total 58, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
