大家好。由于线程读取模式(AKA“树模式”)的ASPX设置中的一些错误,许多人在读取线程上的回复时遇到了问题。无论出于什么原因,这个新视图是新帐户的默认视图,并且由于配置文件设置似乎也搞砸了,我们很多人都陷入了这个bug中。EE =“假”(平坦模式)。只需将其添加到用户脚本管理器浏览器扩展工具,如Tampermonkey我已经在Tampermonkey(Chrome)上测试过这个脚本,它应该在Greasemonkey(FireFox)上工作。
以上来自于百度翻译 以下为原文 Hello everyone. Many of you have been having issues reading replies on threads due to some error in the ASPX settings for the Thread Reading Mode (AKA "tree mode"). For whatever reason this new view is the default to new accounts, and since profile settings seem to be screwed up as well, many of us are stuck with this bug. Anyways I made a script that checks if the a microchip.com/forums/ URL contains "tree=true" (designating tree mode) and replaces it with "tree=false" (Flat Mode). Just add it to a userscript manager browser extension tool like Tampermonkey I've tested this script on Tampermonkey (Chrome) and it should work on Greasemonkey (FireFox) as well. https://github.com/wheres...e%20Mode%20Fix.user.js |
3个回答
编辑:有几种特殊情况会导致无限循环地刷新页面(发生在查看我最近帖子的某个地方),不知道为什么会发生这种情况。自作自受!或者帮我修理一下!咧嘴笑:
以上来自于百度翻译 以下为原文 Edit: There are a couple of special cases that cause infinite loops of refreshing pages (happen to me somewhere within viewing my recent posts) Not sure why this is happening. Use at your own risk! Or help me fix it! grin: |
编辑2:到目前为止,唯一的bug似乎是我的脚本是导航通过最近的帖子页。例如,HTTP://www. McCHIP.COM/FUMMS/TM.ASPX?tree=true&m=942316&mpage=1没有与tree=false对应的URL,而是:http://www.micro..com/for./m938391.aspxI将尝试为该情况添加异常。
以上来自于百度翻译 以下为原文 Edit 2: So far the only URL that seems to bug my script is ones navigated through the recent posts page. For example, http://www.microchip.com/forums/tm.aspx?tree=true&m=942316&mpage=1 doesn't have a corresponding URL with tree=false but instead: http://www.microchip.com/forums/m938391.aspx I will try to add an exception to that case. |
编辑3:添加一个异常来删除不提供树=假链接的页面上的无休止循环。我没有找到一种方法来改变它的平坦模式没有?树=假字符串。现在,这些特殊情况需要您手动更改链接。还添加了有关GitHub链接的更多信息,介绍如何安装脚本。从本质上讲,这是一个简单的3步过程,让脚本在Chrome/Firefox上运行。
以上来自于百度翻译 以下为原文 Edit 3: Added an exception to remove the endless loops on pages that don't offer an tree=false link. I haven't found a way to make it change to the flat mode without the ?tree=false string. For now those special cases will require you to manually change the link. Also added more information on my GitHub link on how to install the script. Essentially its a simple 3 step process to getting the script working on Chrome/Firefox. |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1798浏览 0评论
GMT+8, 2024-4-24 16:08 , Processed in 1.666491 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
