电子发烧友论坛|
嗨,我是mcc的新手,我一直(几天:/)尝试使用i2c接口和mcc生成的代码,但没有成功。也许你们中的一些人可以告诉我,我做的不好。当我调试时,我总是从r_status和w_status变成:I2C1_MESSAGE_FAIL或I2C1_MESSAGE_PENDINGSo,我没有任何通信……我使用的是:ICD 3程序18f25k22内部振荡器16Mhz(没有PLL,直接)MSSP1(RC3->SCL)。1和RC4->SDA1)从RTC时钟DS1307具有地址0x68标准速度100khz、4k7欧姆到+5vConnections,看起来一切正常。main.c:mcc.c:Pin_manager.c:
以上来自于百度翻译 以下为原文 Hi, I'm pretty new in mcc and i have been (for a few days :/) trying to use the i2c interface with the code generated by mcc without any success. Maybe some of you could tell me what i have been doing bad.. When I debug I always become from the r_status and w_status: I2C1_MESSAGE_FAIL or I2C1_MESSAGE_PENDING So I haven't any communication... I'm using: ICD 3 programmer pic18f25k22 internal oscillator 16Mhz (without PLL, directly) MSSP1 (RC3 -> SCL1 and RC4 -> SDA1) Slave RTC clock DS1307 with address 0x68 standard speed 100khz with 4k7 ohm to +5v Connections seems to be all ok. main.c : #include #include #include #include #include "mcc_generated_files/mcc.h" #define RTC_addres 0x68 // RTC slave device address //uint8_t RTC_read_time(); //uint8_t bcdToDec(uint8_t val); //uint8_t bcdToDec(uint8_t val); void main(void) { uint8_t second; uint8_t start_addres; uint8_t length; I2C1_MESSAGE_STATUS w_status; I2C1_MESSAGE_STATUS r_status; SYSTEM_Initialize(); while(1) { start_addres = 0; length = 1; I2C1_MasterWrite( &start_addres, length, RTC_addres, &w_status); I2C1_MasterRead( &second, 1, RTC_addres, &r_status); } return; } mcc.c: #pragma config FOSC = INTIO67 // Oscillator Selection bits->Internal oscillator block #pragma config PLLCFG = OFF // 4X PLL Enable->Oscillator used directly #pragma config PRICLKEN = ON // Primary clock enable bit->Primary clock enabled #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit->Fail-Safe Clock Monitor disabled #pragma config IESO = OFF // Internal/External Oscillator Switchover bit->Oscillator Switchover mode disabled // CONFIG2L #pragma config PWRTEN = OFF // Power-up Timer Enable bit->Power up timer disabled #pragma config BOREN = SBORDIS // Brown-out Reset Enable bits->Brown-out Reset enabled in hardware only (SBOREN is disabled) #pragma config BORV = 190 // Brown Out Reset Voltage bits->VBOR set to 1.90 V nominal // CONFIG2H #pragma config WDTEN = OFF // Watchdog Timer Enable bits->Watch dog timer is always disabled. SWDTEN has no effect. #pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits->1:32768 // CONFIG3H #pragma config CCP2MX = PORTC1 // CCP2 MUX bit->CCP2 input/output is multiplexed with RC1 #pragma config PBADEN = OFF // PORTB A/D Enable bit->PORTB<5:0> pins are configured as digital I/O on Reset #pragma config CCP3MX = PORTB5 // P3A/CCP3 Mux bit->P3A/CCP3 input/output is multiplexed with RB5 #pragma config HFOFST = ON // HFINTOSC Fast Start-up->HFINTOSC output and ready status are not delayed by the oscillator stable status #pragma config T3CMX = PORTC0 // Timer3 Clock input mux bit->T3CKI is on RC0 #pragma config P2BMX = PORTB5 // ECCP2 B output mux bit->P2B is on RB5 #pragma config MCLRE = EXTMCLR // MCLR Pin Enable bit->MCLR pin enabled, RE3 input pin disabled // CONFIG4L #pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit->Stack full/underflow will cause Reset #pragma config LVP = OFF // Single-Supply ICSP Enable bit->Single-Supply ICSP disabled #pragma config XINST = OFF // Extended Instruction Set Enable bit->Instruction set extension and Indexed Addressing mode disabled (Legacy mode) #pragma config DEBUG = OFF // Background Debug->Disabled // CONFIG5L #pragma config CP0 = OFF // Code Protection Block 0->Block 0 (000800-001FFFh) not code-protected #pragma config CP1 = OFF // Code Protection Block 1->Block 1 (002000-003FFFh) not code-protected #pragma config CP2 = OFF // Code Protection Block 2->Block 2 (004000-005FFFh) not code-protected #pragma config CP3 = OFF // Code Protection Block 3->Block 3 (006000-007FFFh) not code-protected // CONFIG5H #pragma config CPB = OFF // Boot Block Code Protection bit->Boot block (000000-0007FFh) not code-protected #pragma config CPD = OFF // Data EEPROM Code Protection bit->Data EEPROM not code-protected // CONFIG6L #pragma config WRT0 = OFF // Write Protection Block 0->Block 0 (000800-001FFFh) not write-protected #pragma config WRT1 = OFF // Write Protection Block 1->Block 1 (002000-003FFFh) not write-protected #pragma config WRT2 = OFF // Write Protection Block 2->Block 2 (004000-005FFFh) not write-protected #pragma config WRT3 = OFF // Write Protection Block 3->Block 3 (006000-007FFFh) not write-protected // CONFIG6H #pragma config WRTC = OFF // Configuration Register Write Protection bit->Configuration registers (300000-3000FFh) not write-protected #pragma config WRTB = OFF // Boot Block Write Protection bit->Boot Block (000000-0007FFh) not write-protected #pragma config WRTD = OFF // Data EEPROM Write Protection bit->Data EEPROM not write-protected // CONFIG7L #pragma config EBTR0 = OFF // Table Read Protection Block 0->Block 0 (000800-001FFFh) not protected from table reads executed in other blocks #pragma config EBTR1 = OFF // Table Read Protection Block 1->Block 1 (002000-003FFFh) not protected from table reads executed in other blocks #pragma config EBTR2 = OFF // Table Read Protection Block 2->Block 2 (004000-005FFFh) not protected from table reads executed in other blocks #pragma config EBTR3 = OFF // Table Read Protection Block 3->Block 3 (006000-007FFFh) not protected from table reads executed in other blocks // CONFIG7H #pragma config EBTRB = OFF // Boot Block Table Read Protection bit->Boot Block (000000-0007FFh) not protected from table reads executed in other blocks #include "mcc.h" void SYSTEM_Initialize(void) { INTERRUPT_Initialize(); PIN_MANAGER_Initialize(); OSCILLATOR_Initialize(); I2C1_Initialize(); } void OSCILLATOR_Initialize(void) { // SCS INTOSC; IRCF 16MHz_HFINTOSC/4; IDLEN disabled; OSCCON = 0x72; // PRISD enabled; SOSCGO disabled; MFIOSEL disabled; OSCCON2 = 0x04; // INTSRC disabled; PLLEN disabled; TUN 0; OSCTUNE = 0x00; // Set the secondary oscillator } Pin_manager.c : #include #include "pin_manager.h" void PIN_MANAGER_Initialize(void) { LATB = 0x0; LATA = 0x0; LATC = 0x0; ANSELA = 0x0; ANSELB = 0x0; ANSELC = 0x0; TRISB = 0x0; TRISC = 0x0; WPUB = 0xFF; TRISA = 0x0; INTCON2bits.nRBPU = 0x1; } void PIN_MANAGER_IOC(void) { } interrupt_manager.c : #include "interrupt_manager.h" #include "mcc.h" void INTERRUPT_Initialize (void) { // Disable Interrupt Priority Vectors (16CXXX Compatibility Mode) IPEN = 0; // Clear peripheral interrupt priority bits (default reset value) // BCLI IPR2bits.BCL1IP = 0; // SSPI IPR1bits.SSP1IP = 0; } void interrupt INTERRUPT_InterruptManager (void) { // interrupt handler if(PIE2bits.BCL1IE == 1 && PIR2bits.BCL1IF == 1) { I2C1_BusCollisionISR(); } else if(PIE1bits.SSP1IE == 1 && PIR1bits.SSP1IF == 1) { I2C1_ISR(); } else { //Unhandled Interrupt } } |
9个回答
你是说你的代码被困在I2C1MeAxaGEIORIOR2C1YMasaQuestPuto循环中?你有一个范围可以探测这两条线吗?
以上来自于百度翻译 以下为原文 You are saying that your code gets stuck in the I2C1_MESSAGE_FAIL or I2C1_MESSAGE_PENDING loop? Do you have a scope that you can probe the two lines? |
对。。当我调试时,我变成了2C1YMasaGeIORIORIO2C1MIXAGEJOPEN,所以我没有与奴隶的通信:(有什么想法吗?对不起,我的英语不是最好的
以上来自于百度翻译 以下为原文 Yes.. when i debug i become I2C1_MESSAGE_FAIL or I2C1_MESSAGE_PENDING, So i do not have communication with the slave :( Any idea? Sorry my english is not the best |
我相信你注册的TISISC是错误的,我也有同样的问题。MCC没有正确地生成它们。我相信您希望TRISC=0x18,而不是0x00.0x18=0 0 0 1 1 0 RC5 RC4 RC3 RC2 RC1 RC0您希望TRISC中的位是I2C使用的引脚的1。请告诉我,如果这样做,我可能已经看得太快了。
以上来自于百度翻译 以下为原文 I believe your register setting for TRISC is wrong, I had the same problem. MCC doesn't generate them correctly. I believe you want TRISC = 0x18 instead of 0x00. 0x18 = 0 0 0 1 1 0 0 0 RC5 RC4 RC3 RC2 RC1 RC0 You want the bits in TRISC to be a 1 for the pins you are using for I2C. Let me know if this works, I may have looked at it too quickly. |
谢谢你的回答,但这对我不起作用:TISISC是你问题的根源吗?或者你的解决方案是什么?
以上来自于百度翻译 以下为原文 Thanks for your answer but it doesn't works for me :/ Were the TRISC the source of your problem? or what was your solution? |
我认为这是我的问题的根源。另外,我必须把我使用的时钟源从锁相环换成高频内部振荡器。你有没有检查过你的线路,看看引脚是否至少驱动高/低?线路上有上拉电阻吗?
以上来自于百度翻译 以下为原文 I think that was the source of my issues. Also I had to change the clock source I was using from a PLL to the HF internal oscillator. Have you ever probed your lines to see if the pins are at least driving high/low? do you have pull-up resistors on the lines? |
嗯,我在16MHz不带锁相环的情况下使用iToSc。在线路中有4K7电阻+5V。不知道它为什么不工作。你能把你的配置位张贴出来吗?这些是我的:Apple PrimaMac配置文件FoC= iTIO67//振荡器选择位-gt;内部振荡器块α-PrAPMA配置PLLCFG=O//4x PLL使能& GT;直接使用μ* PrimaMac配置PICLLKEN=ON//主时钟使能位-GT;主时钟使能锁定监视器启用位-gt;故障安全时钟监视器禁用,γ-Pracm配置,IESO=OF//内部/外部振荡器切换位-GT;振荡器切换模式禁用/ /CONT2L,PracMMA配置,PWRTEN = OF//上电定时器启用位-GT;停电定时器,禁用γ-PrimMA配置BBON=SBordIS//Brown Outlook重置使能比特-GT;仅在硬件中启用Brown Outlook复位(SBORN被禁用)α-PrAPMA配置BRV=190 / /棕色输出重置电压位-& VT,设置为1.90 V标称//CON2H H PARMAMA CONFIG WDTEN=OF//看门狗定时器允许位-GT;看门狗定时器总是禁用。StdEn没有影响。{ Trac-TimeFigTPs=32768 / /看门狗定时器后尺度选择位-gt;1:327 68 //CONT3Hα-PrAPMA配置CCP2MX=PULTC1//CCP2 MUX位-GT;CCP2输入/输出与RC1πPracMA配置PPBEN = OF//PORTB A/D允许位-GT;PORTB & LT;5:0&GT;PIN被配置为复位#pragma配置CCP3MX=PORTB5//P3A/CCP3多比特->P3A/CCP3输入/输出上的数字I/O与RB5#pragma配置HFOFST=ON//HFINTOSC快速启动>HFINTOSC输出和准备状态被振荡器稳定状态#pragma配置T3CMX=PORTC0//Timer3C3C不延迟。锁输入多重位>T3CKI在RC0#pragma配置P2BMX=PORTB5//ECCP2 B输出多重位->P2B在RB5\#pragma配置MCCP2B输出多重位->P2B在RB5\\#prpragma配置MCCPCPCP配置MCCPMCCPMCCPMCCP2MCCP2MCCP配置MCBMCCPMCBMCCLRE MCLRE=EX\\#prprprprpragma配置MCLCCCCCCCCCCCCCCCLMA MCLCPR配置MCLB配置MCLX/MCLX比特MCL堆栈full/下溢将导致重置#pragma config LVP=OFF//单电源ICSP启用位>单电源ICSP禁用#pragma config XINST=OFF//扩展指令集启用位>指令集扩展和索引寻址模式禁用(遗留模式)#pragma config DEBUG=OFF//Back地面调试->.bled//CONFIG5L#pragma配置CP0=OFF//代码保护块0->块0(000800-001FFFh)没有代码保护#pragma配置CP1=OFF//代码保护块1->块1(002000-003FFFh)没有代码保护#pragma配置CP2=OFF//代码保护块2->块2(002000-003FFFh)004000-005FFFh)没有代码保护#pragma配置CP3=OFF//代码保护块3->块3->(006000-007FFFh)没有代码保护//CONFIG5H#pragma配置CPB=OFF//引导块代码保护位->引导块(000000-0007FFh)没有代码保护#pragma配置CPD=OFF//数据EEPROM代码P保护位->数据EEPROM没有代码保护//CONFIG6L#pragma配置WRT0=OFF//写保护块0->块0(000800-001FFFh)没有写保护#pragma配置WRT1=OFF//写保护块1->块1(002000-003FFFh)没有写保护#pragma配置WRT2=OFF//写P保护块2->块2(004000-005FFFh)未写保护#pragma配置WRT3=OFF//写保护块3->块3(006000-007FFFh)未写保护//CONFIG6H#pragma配置WRTC=OFF//配置寄存器写保护位->配置寄存器(300000-3000FFh)无t写保护#pragma配置WRTB=OFF//引导块写保护位-&g t;引导块(000000-0007FFh)未写保护#pragma配置WRTD=OFF//数据EEPROM写保护位-&g t;数据EEPROM未写保护//CONFIG7L#pragma配置EBTR0=OFF//表读保护块0-&g块0(000800-001FFFh)不受其他块中执行的表读取的保护pragma配置EBTR1=OFF//表读取保护块1->块1(002000-003FFFh)不受其他块中执行的表读取的保护pragma配置EBTR2=OFF//表读取保护块2->块2004000-005FFFh)未被保护以免在其他块中执行的表读取#pragma config EBTR3=OFF//表读取保护块3->块3->块3(006000-007FFFh)未被保护以免在其他块中执行的表读取//CONFIG7H#pragma config EBTRB=OFF//引导块表读取保护位->BoOT块(000000 -000 07FFH)未被保护在其他块中执行的表读取
以上来自于百度翻译 以下为原文 Mmm I'm using INTOSC at 16Mhz without PLL. I have a 4K7 resistor to +5v in the lines. No idea why it doesn't work. Could you maybe post your configuration bits? These are mine: #pragma config FOSC = INTIO67 // Oscillator Selection bits->Internal oscillator block #pragma config PLLCFG = OFF // 4X PLL Enable->Oscillator used directly #pragma config PRICLKEN = ON // Primary clock enable bit->Primary clock enabled #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit->Fail-Safe Clock Monitor disabled #pragma config IESO = OFF // Internal/External Oscillator Switchover bit->Oscillator Switchover mode disabled // CONFIG2L #pragma config PWRTEN = OFF // Power-up Timer Enable bit->Power up timer disabled #pragma config BOREN = SBORDIS // Brown-out Reset Enable bits->Brown-out Reset enabled in hardware only (SBOREN is disabled) #pragma config BORV = 190 // Brown Out Reset Voltage bits->VBOR set to 1.90 V nominal // CONFIG2H #pragma config WDTEN = OFF // Watchdog Timer Enable bits->Watch dog timer is always disabled. SWDTEN has no effect. #pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits->1:32768 // CONFIG3H #pragma config CCP2MX = PORTC1 // CCP2 MUX bit->CCP2 input/output is multiplexed with RC1 #pragma config PBADEN = OFF // PORTB A/D Enable bit->PORTB<5:0> pins are configured as digital I/O on Reset #pragma config CCP3MX = PORTB5 // P3A/CCP3 Mux bit->P3A/CCP3 input/output is multiplexed with RB5 #pragma config HFOFST = ON // HFINTOSC Fast Start-up->HFINTOSC output and ready status are not delayed by the oscillator stable status #pragma config T3CMX = PORTC0 // Timer3 Clock input mux bit->T3CKI is on RC0 #pragma config P2BMX = PORTB5 // ECCP2 B output mux bit->P2B is on RB5 #pragma config MCLRE = EXTMCLR // MCLR Pin Enable bit->MCLR pin enabled, RE3 input pin disabled // CONFIG4L #pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit->Stack full/underflow will cause Reset #pragma config LVP = OFF // Single-Supply ICSP Enable bit->Single-Supply ICSP disabled #pragma config XINST = OFF // Extended Instruction Set Enable bit->Instruction set extension and Indexed Addressing mode disabled (Legacy mode) #pragma config DEBUG = OFF // Background Debug->Disabled // CONFIG5L #pragma config CP0 = OFF // Code Protection Block 0->Block 0 (000800-001FFFh) not code-protected #pragma config CP1 = OFF // Code Protection Block 1->Block 1 (002000-003FFFh) not code-protected #pragma config CP2 = OFF // Code Protection Block 2->Block 2 (004000-005FFFh) not code-protected #pragma config CP3 = OFF // Code Protection Block 3->Block 3 (006000-007FFFh) not code-protected // CONFIG5H #pragma config CPB = OFF // Boot Block Code Protection bit->Boot block (000000-0007FFh) not code-protected #pragma config CPD = OFF // Data EEPROM Code Protection bit->Data EEPROM not code-protected // CONFIG6L #pragma config WRT0 = OFF // Write Protection Block 0->Block 0 (000800-001FFFh) not write-protected #pragma config WRT1 = OFF // Write Protection Block 1->Block 1 (002000-003FFFh) not write-protected #pragma config WRT2 = OFF // Write Protection Block 2->Block 2 (004000-005FFFh) not write-protected #pragma config WRT3 = OFF // Write Protection Block 3->Block 3 (006000-007FFFh) not write-protected // CONFIG6H #pragma config WRTC = OFF // Configuration Register Write Protection bit->Configuration registers (300000-3000FFh) not write-protected #pragma config WRTB = OFF // Boot Block Write Protection bit->Boot Block (000000-0007FFh) not write-protected #pragma config WRTD = OFF // Data EEPROM Write Protection bit->Data EEPROM not write-protected // CONFIG7L #pragma config EBTR0 = OFF // Table Read Protection Block 0->Block 0 (000800-001FFFh) not protected from table reads executed in other blocks #pragma config EBTR1 = OFF // Table Read Protection Block 1->Block 1 (002000-003FFFh) not protected from table reads executed in other blocks #pragma config EBTR2 = OFF // Table Read Protection Block 2->Block 2 (004000-005FFFh) not protected from table reads executed in other blocks #pragma config EBTR3 = OFF // Table Read Protection Block 3->Block 3 (006000-007FFFh) not protected from table reads executed in other blocks // CONFIG7H #pragma config EBTRB = OFF // Boot Block Table Read Protection bit->Boot Block (000000-0007FFh) not protected from table reads executed in other blocks |
SSP2STAT=0x00;SSP2CON1=0x0;SSP2CON3=0x0;SSP2ADD=0x03;PIR2位.SSP2IF=0x03;PIR2比特.SSP2P2IF=0;PI2比特.SSP2IF=0;PIE2比特.SSP2IE=0;PIE2bits.SSP2IE=1;LATC=0XX=0XX=0X00;LATC=0x00=0x00;WPUA=0x00;WPUC=0x00;WPUC=0x00=0x00;ANSELA=0x37;ANSELC=0x37;ANSELC=0x05;ANSELC=0x05;0x05;TRISC=0gt;MSSP2:SCL2;RC1PPSbits.RC1PPS=0x1B;t;MSSP2:SDA2;#pragma config FEXTOSC=OFF//FEXTOSC外部振荡器模式选择位->未启用的振荡器#pragma config RSTOSC=HFINT1//COSC位的断电默认值->HFINTOSC#pragma config CLKOUTEN=OFF//Clock Out Enable bit-> CLKOUT功能被禁用;I/O或oscOSC2#pragma config CSWEN=ON//Clock Switch Enable bit->写入NOSC和NDIV上的振荡器功能#pragma config FCMEN=ON//Fail-Safe Clock Monitor Enable->Fail-Safe Clock Monitor Enable->Fail-Safe Clock Monitor Enable//CONFIG2#pragma config MCLRE=ON//Master Clear Enable bit-> MCLR/VPP引脚功能离子是MCLR;弱上拉启用#pragma配置PWRTE=OFF//上电定时器启用位->PWRT禁用#pragma配置WDTE=OFF//看门狗定时器启用位->WDT禁用;SWDTEN被忽略#pragma配置LPBOREN=OFF//低功率BOR启用位->ULPBOR禁用#pragma配置BOREN=ON//Brown-out Reset Enable位->Brown-out Reset启用,SBOREN位忽略#pragma配置BORV=LOW//Brown-out Reset电压选择位->Brown-out电压(Vbor),设置为2.45V#pragma配置PPS1WAY=ON//PPSLOCK位单向设置Enable位-> PPSLOCK位只能被清除和设置一旦;在一个清除/设置周期#pragma配置STVREN=ON//堆栈溢出/下溢复位启用位>堆栈溢出或下溢将导致复位#pragma配置DEBUG=OFF//调试器启用位>后台调试器禁用//CONFIG3#pragma配置WRT=OFF//用户NVM自写保护位->写保护#pragma配置LVP=ON//低压编程启用位->低压编程启用。MCLR/VPP引脚功能是MCLR。忽略MCLRE配置位。//CONFIG4#pragma配置CP=OFF//用户NVM程序内存代码保护位->用户NVM代码保护禁用#pragma配置CPD=OFF//数据NVM内存代码保护位->数据NVM代码保护禁用
以上来自于百度翻译 以下为原文 SSP2STAT = 0x00; SSP2CON1 = 0x28; SSP2CON3 = 0x00; SSP2ADD = 0x03; PIR2bits.SSP2IF = 0; PIE2bits.SSP2IE = 1; LATA = 0x00; LATC = 0x00; WPUA = 0x00; WPUC = 0x00; ANSELA = 0x37; ANSELC = 0x05; TRISC = 0x3A; TRISA = 0x13; RC4PPSbits.RC4PPS = 0x1A; //RC4->MSSP2:SCL2; RC1PPSbits.RC1PPS = 0x1B; //RC1->MSSP2:SDA2; #pragma config FEXTOSC = OFF // FEXTOSC External Oscillator mode Selection bits->Oscillator not enabled #pragma config RSTOSC = HFINT1 // Power-up default value for COSC bits->HFINTOSC #pragma config CLKOUTEN = OFF // Clock Out Enable bit->CLKOUT function is disabled; I/O or oscillator function on OSC2 #pragma config CSWEN = ON // Clock Switch Enable bit->Writing to NOSC and NDIV is allowed #pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable->Fail-Safe Clock Monitor is enabled // CONFIG2 #pragma config MCLRE = ON // Master Clear Enable bit->MCLR/VPP pin function is MCLR; Weak pull-up enabled #pragma config PWRTE = OFF // Power-up Timer Enable bit->PWRT disabled #pragma config WDTE = OFF // Watchdog Timer Enable bits->WDT disabled; SWDTEN is ignored #pragma config LPBOREN = OFF // Low-power BOR enable bit->ULPBOR disabled #pragma config BOREN = ON // Brown-out Reset Enable bits->Brown-out Reset enabled, SBOREN bit ignored #pragma config BORV = LOW // Brown-out Reset Voltage selection bit->Brown-out voltage (Vbor) set to 2.45V #pragma config PPS1WAY = ON // PPSLOCK bit One-Way Set Enable bit->The PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle #pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable bit->Stack Overflow or Underflow will cause a Reset #pragma config DEBUG = OFF // Debugger enable bit->Background debugger disabled // CONFIG3 #pragma config WRT = OFF // User NVM self-write protection bits->Write protection off #pragma config LVP = ON // Low Voltage Programming Enable bit->Low Voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored. // CONFIG4 #pragma config CP = OFF // User NVM Program Memory Code Protection bit->User NVM code protection disabled #pragma config CPD = OFF // Data NVM Memory Code Protection bit->Data NVM code protection disabled |
谢谢你的支持!但我还是有问题…
以上来自于百度翻译 以下为原文 Thanks for your support!! but i still having the problem.. |
跟踪Atttp://www. McCHIP.COM/FUMMS/M944 121.ASPX
以上来自于百度翻译 以下为原文 follows up at http://www.microchip.com/forums/m944121.aspx |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 05:42 , Processed in 0.994605 second(s), Total 91, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2870
