扫一扫,分享给好友
我使用MPLAB X IDE V3.35和Hyror 2.0B。我已经使用配置器映射了我的外设和GPIO。现在我想将引脚设置导出到电子表格,以便将它们传递给进行电路板布局的人。在配置器窗口内,按下导出按钮2。显示“导出”菜单。选择“MPLAB和谐配置器引脚图和引脚表”。3。导出按钮在窗口的底部启用。按下“导出”按钮。4。为Excel文件选择一个位置并按下“打开”按钮。在MPLLAB HARMony Configurator窗口中,可以看到数百行,例如:
以上来自于百度翻译 以下为原文 I am using MPLAB X IDE v3.35 and Harmony 2.00b. I have mapped my peripherals and GPIO using the configurator. Now I would like to export the pin settings to a spreadsheet to pass them along to the person doing the board layout. To export the pin settings, I am using the following steps: 1. Inside the Configurator window, press the Export button 2. The Export Menu is displayed. Select "MPLAB Harmony Configurator Pin Diagram and Pin Table". 3. The Export button is enabled at the bottom of the window. Press the "Export" Button. 4. Select a location for the Excel file and press the Open button. In the MPLAB Harmony Configurator window I can see hundreds of lines such as: There are no errors in this tab but there is one silent error. The silent error is an Unexpected Exception in Java (which I have attached). The results are: A PNG file is created but the pin names at the top and bottom of the chip are cropped off of the diagram. The Excel file is not created. A zero byte file with the correct name exists. I was not able to find this as being a known issue. Does this functionality exist in MPLAB v3.30 and Harmony 1.08? I may have created my project using MPLAB v3.30 and Harmony 1.08 and then upgraded to MPLAB v3.35 and Harmony 2.00b. Could the upgrade be causing a problem? Is this tool still too new to use on a large project? Attachment(s) Error during export to Excel.txt (13.58 KB) - downloaded 282 times |
1个回答
我同意在某些项目上会发生这种情况。几个月前我买了一张票。支持报道,他们已经能够复制的问题,所以它会得到固定在一段时间!也许会再给你一个支持?
以上来自于百度翻译 以下为原文 I agree that is what happens on some projects. I raised a ticket a few months ago. Support reported that they have been able to reproduce the issue, so it will get fixed at some time! Maybe raise another support ticktet? |
只有小组成员才能发言,加入小组>>
5081 浏览 9 评论
1954 浏览 8 评论
1888 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3116 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2189 浏览 5 评论
634浏览 1评论
509浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
372浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
539浏览 0评论
441浏览 0评论
GMT+8, 2024-10-1 06:38 , Processed in 0.906075 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
