扫一扫,分享给好友
void LwIP_Init(void)
{ /* Initializes the dynamic memory heap defined by MEM_SIZE.*/ mem_init(); /* Initializes the memory pools defined by MEMP_NUM_x.*/ memp_init(); } void mem_init(void) { struct mem *mem; LWIP_ASSERT("Sanity check alignment", (SIZEOF_STRUCT_MEM & (MEM_ALIGNMENT-1)) == 0); /* align the heap */ ram = LWIP_MEM_ALIGN(ram_heap); /* initialize the start of the heap */ mem = (struct mem *)ram; mem->next = MEM_SIZE_ALIGNED; mem->prev = 0; mem->used = 0; /* initialize the end of the heap */ ram_end = (struct mem *)&ram[MEM_SIZE_ALIGNED]; ram_end->used = 1; ram_end->next = MEM_SIZE_ALIGNED; ram_end->prev = MEM_SIZE_ALIGNED; mem_sem = sys_sem_new(1); /* initialize the lowest-free pointer to the start of the heap */ lfree = (struct mem *)ram; MEM_STATS_AVAIL(avail, MEM_SIZE_ALIGNED); } void memp_init(void) { struct memp *memp; u16_t i, j; for (i = 0; i < MEMP_MAX; ++i) { MEMP_STATS_AVAIL(used, i, 0); MEMP_STATS_AVAIL(max, i, 0); MEMP_STATS_AVAIL(err, i, 0); MEMP_STATS_AVAIL(avail, i, memp_num); } memp = LWIP_MEM_ALIGN(memp_memory); /* for every pool: */ for (i = 0; i < MEMP_MAX; ++i) { memp_tab = NULL; /* create a linked list of memp elements */ for (j = 0; j < memp_num; ++j) { memp->next = memp_tab; memp_tab = memp; memp = (struct memp *)((u8_t *)memp + MEMP_SIZE + memp_sizes #if MEMP_OVERFLOW_CHECK + MEMP_SANITY_REGION_AFTER_ALIGNED #endif ); } } |
8个回答
/** This array holds a textual description of each pool. */
#ifdef LWIP_DEBUG static const char *memp_desc[MEMP_MAX] = { #define LWIP_MEMPOOL(name,num,size,desc) (desc), #include "lwip/memp_std.h" }; #endif /* LWIP_DEBUG */ /** This is the actual memory used by the pools. */ static u8_t memp_memory[MEM_ALIGNMENT - 1 #define LWIP_MEMPOOL(name,num,size,desc) + ( (num) * (MEMP_SIZE + MEMP_ALIGN_SIZE(size) ) ) #include "lwip/memp_std.h" ]; 是这个吗? |
就是在这个数组
看内存池的地址在哪里?
首地址没啊,貌似分配了个数组,然后查找首地址
谢谢,原子哥,解决了!
您好,请问您这个是怎么处理的?我这样添加了
static u8_t memp_memory[MEM_ALIGNMENT - 1 #define LWIP_MEMPOOL(name,num,size,desc) + ( (num) * (MEMP_SIZE + MEMP_ALIGN_SIZE(size) ) ) #include "lwip/memp_std.h" ] __attribute__((at(0x68000000))); 请问还要怎么处理呢? O(∩_∩)O谢谢 |
就这样就没问题了!
恩,验证通过了,谢谢O(∩_∩)O~
只有小组成员才能发言,加入小组>>
如何使用STM32+nrf24l01架构把有线USB设备无线化?
2542 浏览 7 评论
请问能利用51单片机和nRF24L01模块实现实时语音无线传输吗?
2327 浏览 5 评论
3146 浏览 3 评论
2798 浏览 8 评论
为什么ucosii上移植lwip后系统进入了HardFault_Handler?
2758 浏览 4 评论
请教各位大咖:有没有接收频率32M左右的芯片推荐的?先感谢啦!
602浏览 1评论
852浏览 0评论
961浏览 0评论
617浏览 0评论
443浏览 0评论
GMT+8, 2024-11-19 17:53 , Processed in 1.193557 second(s), Total 91, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
