tiTLE " TWO WIRE/I2C BUS INTERFACE WITH PIC16C5x "
; LIST P=16C54 ;***************************************************************************** ;** Two wire/I2C Bus READ/WRITE Sample Routines of Microchip's ;** 24Cxx / 85Cxx serial CMOS EEPROM interfacing to a ;** PIC16C54 8-bit CMOS single chip microcomputer ;** Revsied Version 2.0 (4/2/92). ;** ;** Part use = PIC16C54-XT/JW ;** Note: 1) All timings are based on a reference crystal frequency of 2MHz ;** which is equivalent to an instruction cycle time of 2 usec. ;** 2) Address and literal values are read in octal unless otherwise ;** specified. ; ; ; Program: I2CBUS.ASM ; Revision Date: ; 12-12-95 Compatibility with MPASMWIN 1.30 ; ;********************************************************************** ; ;***************************************************************************** ; ;----------------------------------------------------------------------------- ; Files Assignment ;----------------------------------------------------------------------------- ; PC EQU 2 ; Program counter STAT EQU 3 ; PIC status byte FSR EQU 4 ; File Select Register RA EQU 5 ; Port A use to select device address RB EQU 6 ; RB7 = SDA, RB6 = SCL ; STATUS EQU 08 ; Status register FLAG EQU 09 ; Common flag bits register EEPROM EQU 0A ; Bit buffer ERCODE EQU 0B ; Error code (to indicate bus status) ADDR EQU 10 ; Address register DATAI EQU 11 ; Stored data input register DATAO EQU 12 ; Stored data output register SLAVE EQU 13 ; Device address (1010xxx0) TXBUF EQU 14 ; TX buffer RXBUF EQU 15 ; RX buffer COUNT EQU 16 ; Bit counter ; TIMER0 EQU 18 ; Delay timer0 TIMER1 EQU 19 ; Delay timer1 ; ; ;----------------------------------------------------------------------------- ; Bit Assignments ;----------------------------------------------------------------------------- ; ; Status bits ; Z EQU 2 C EQU 0 ; ; FLAG Bits ; ERR1 EQU 0 ; Error flag ; ; Instruction Destination Bits ; F EQU 1 W EQU 0 ; ; EEPROM Bits ; DI EQU 7 ; EEPROM input DO EQU 6 ; EEPROM output ; ; I2C Device Bits ; SDA EQU 7 ; RB7, data in/out SCL EQU 6 ; RB6, serial clock ; ;END FILES/BITS EQUATE PAGE ; ;----------------------------------------------------------------------------- ; Two wire/I2C - CPU communication error status table and subroutine ;----------------------------------------------------------------------------- ; input : W-reg = error code ; output : ERCODE = error code ; FLAG(ERR1) = 1 ; ; code error status mode ; ------- ------------------------------------------------------ ; 1 : SCL locked low by device (bus is still busy) ; 2 : SDA locked low by device (bus is still busy) ; 3 : No acknowledge from device (no handshake) ; 4 : SDA bus not released for master to generate STOP bit ;----------------------------------------------------------------------------- ; ;Subroutine to identify the status of the serial clock (SCL) and serial data ;(SDA) condition according to the error status table. Codes generated are ;useful for bus/device diagnosis. ; ERR BTFSS FLAG,ERR1 ; Remain as first error encountered MOVWF ERCODE ; Save error code BSF FLAG,ERR1 ; Set error flag RETLW 0 ; ;----------------------------------------------------------------------------- ; START bus communication routine ;----------------------------------------------------------------------------- ; input : none ; output : initialize bus communication ;----------------------------------------------------------------------------- ; ;Generate START bit (SCL is high while SDA goes from high to low transition) ;and check status of the serial clock. BSTART MOVLW B'00111111' ; Put SCL, SDA line in output state TRIS RB ;*************************************************************************** bsf RB,SDA ;make sure sda is high ;*************************************************************************** BSF RB,SCL ; Set clock high MOVLW 1 ; Ready error status code 1 BTFSS RB,SCL ; Locked? CALL ERR ; SCL locked low by device BCF RB,SDA ; SDA goes low during SCL high NOP ; Timing adjustment NOP NOP BCF RB,SCL ; Start clock train RETLW 0 ; ;END SUB PAGE ; ;----------------------------------------------------------------------------- ; STOP bus communication routine ;----------------------------------------------------------------------------- ; Input : None ; Output : Bus communication, STOP condition ;----------------------------------------------------------------------------- ; ;Generate STOP bit (SDA goes from low to high during SCL high state) ;and check bus conditions. ; BSTOP ;**************************************************************************** MOVLW B'00111111' ; Put SCL, SDA line in output state TRIS RB ;**************************************************************************** BCF RB,SDA ; Return SDA to low BSF RB,SCL ; Set SCL high nop nop nop MOVLW 1 ; Ready error code 1 BTFSS RB,SCL ; High? CALL ERR ; No, SCL locked low by device BSF RB,SDA ; SDA goes from low to high during SCL high MOVLW 4 ; Ready error code 4 BTFSS RB,SDA ; High? CALL ERR ; No, SDA bus not release for STOP RETLW 0 ; ;END SUB ; ;----------------------------------------------------------------------------- ; Serial data send from PIC to serial EEPROM, bit-by-bit subroutine |
1 个讨论
有人有STM8H1K08T连接TM1650的源码吗,可以直接使用的那种,我的代码在烧录之后数码管一直处于熄灭状态
271 浏览 0 评论
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
493 浏览 0 评论
589 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
891 浏览 0 评论
1436 浏览 2 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16926 浏览 31 评论
/9
GMT+8, 2025-12-4 10:16 , Processed in 0.664421 second(s), Total 38, Slave 29 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2939
