电子发烧友论坛扫一扫,分享给好友
嗨,我觉得我很傻。在和声框架设置中,我使用了密码库。但是在WOLSSL中也有WORFCRIPT,它在和声密码中复制了相当多的模块。难道我不能启用和声的密码库吗?快乐的人
以上来自于百度翻译 以下为原文 Hi, I think I'm being silly. In HARMony Framework setup, I have Use Cryptographic Library ticked. But there is also WolfCrypt within WolfSSL, which duplicates quite a few modules in Harmony crypto. Should I not enable harmony's crypto library? Cheers Martin |
8个回答
是的,它们是多余的。我记得有过同样的问题。但是两者都很大,你确定你需要两者吗?
以上来自于百度翻译 以下为原文 Yes, they are redundant. I remember having the same problem. But both are quite large, are you sure you need both? |
我怀疑我两个都需要。我在一个月前或2年前工作过。我把它关掉了,因为比较容易看出包里发生了什么。这周我把它重新打开,但是失败了,所以我正在检查在和谐中需要什么。我现在正在努力编写一个编译系统,更不用说工作系统了!
以上来自于百度翻译 以下为原文 I doubt I need both. I had WolfSSL working a month or two ago. I switched it off as it's easier to see what is going on in the packets. This week I've switched it back on but it's failing, so I'm examining what is needed within harmony. I'm struggling to get a compiling system at the moment, let alone a working one! |
1。在进行更改之前,始终保存工作代码。2。你看了什么样的应用程序检查。
以上来自于百度翻译 以下为原文 1. Always save working code before you make changes. 2. Did you look at what the sample apps have checked. |
实际上,在Velon控件中,复制到另一个FooDoLoT点,我现在就检查一下。
以上来自于百度翻译 以下为原文 indeed - in verson control and copied to another folder good point, I'll check that now |
它与使用MZ上的硬件密码模块有关吗?如果是这样,我们在框架/密码库中固定的一些东西还没有被引入到WOLFSSL的源代码中。我们已经向他们提供了,但他们还没有合并。
以上来自于百度翻译 以下为原文 Is it related to using the hardware crypto module on MZ? If so, there are some things that we've fixed in the framework/crypto library that have not been brought into WolfSSL's source code. We've provided it to them, but they haven't incorporated it yet. |
嗨,拉里,是的,我发现我必须关掉硬件加密,否则它会挂起“等待引擎”。但是在我的项目中,我关掉了硬件加密,而不是更改Harmony配置——我一直在试图避免在Harmony中重新运行代码生成。我不确定为什么我有问题,它几个月前在Harmony 1.08上工作得很好。不管怎样,我和谐地关掉了硬件加密,重新生成了代码,现在一切正常。CheersMartin
以上来自于百度翻译 以下为原文 Hi Larry, Yes I found I had to switch off hardware crypto, otherwise it hangs "waiting for engine" However in my project I had switched off hardware crypto myself rather than changing Harmony config - I've been trying to avoid re-running code generation in Harmony. I'm not sure why I had a problem, it was working fine with Harmony 1.08 a few months ago. Anyway, I switched off hardware crypto in harmony, regenerated the code and all is now well. Cheers Martin |
你能提供更多的信息吗?我拼命想使密码芯片运行,到目前为止,我没有运气。也许你可以提供补丁文件?我现在已经为Web服务器运行了WolfSSL,但是只要我查看“使用PIC32MZ硬件加密”,就不再提供网页了。
以上来自于百度翻译 以下为原文 Could you provide more information on that? I am desperately trying to get the crypto chip running and so far I had no luck. Maybe you could provide a patch file? I have WolfSSL running for the web server now, but as soon as I check the "Use PIC32MZ Hardware Cryptography" no webpages are delivered anymore. (I am currently running Harmony 2.03b) |
我读到2.03b有最新的WolfSSL,但这并不一定意味着Wolf已经集成了由Micro.-Larry提供的硬件密码修复程序。Larry应该能够确认这一点。我仍然在和声1.09上运行,没有硬件加密。如果Larry不能提供,那就太好了。他加密补丁,如果他们还没有在最新的WOLFSSL。
以上来自于百度翻译 以下为原文 I read that 2.03b had latest WolfSSL, but that doesn't necessarily mean that Wolf have incorporated the hardware crypto fixes provided to them by Microchip - Larry should be able to confirm this. I'm still on harmony 1.09 and running without hardware crypto. It would be great if Larry could provide the crypto patches if they're not already in latest WolfSSL. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:00 , Processed in 1.055290 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1161
