PIC32MX575F512H。任何输入复位(MCLR,软复位,WDT复位)都给出相同的结果:最初一切正常,MCLR复位MC,程序从开始启动。几分钟后,任何复位开始作为一个触发器工作:在第一次复位(MCLR,软复位,WDT复位)后,MC挂断,所有引脚都处于Z状态。一些时间延迟下一次复位重新启动MC和一个周期,它正常工作。第三复位将MC再次挂起一段时间,比先前的时间长。这一次MC再次正确工作,直到下一次重置。捕食时间随着时间的推移而增长一个小时,可能更多。我们用三个MC观察到类似的效果。很长一段时间,我们不能相信微芯片会因为松动很多时间而销售有缺陷的MC。但后来我们了解到它在中国有制造业,现在对其质量有疑问。这种情况可能是中国有缺陷的违禁品PIC32MX MC造成的吗?
以上来自于百度翻译 以下为原文 PIC32MX575F512H. Any input Reset (MCLR, Soft Reset, WDT Reset) gives the same result: Initially everithing works as usual, MCLR resets the MC and program starts from begin. After some minutes any resets start to work as a trigger: after first reset (MCLR, Soft Reset, WDT Reset) the MC hangs up, all pins are in Z state. Afrer some time delay next reset restarts MC and one cycle it works properly. Third reset hangs the MC up on some time again, longer than earlier one. After this time MC works properly once cyrcle again, up to next reset. The hunging up time grows with the time up to a hour and may be more. Similar effect we observe with three MC. Very long time we couldn't belive the MicroChip may sale the defective MCs because loose a lot of time. But then we learn it has the manufacturing in China and now are in doubt about its quality. May this situation be effect of chinese defective contraband PIC32MX MC? |
2个回答
你能张贴你的电路板的原理图吗?像这样的神秘问题通常可以追溯到Vcap引脚上的不正确的电容器,或者Vdd引脚上的旁路电容器不足。
以上来自于百度翻译 以下为原文 Can you post the schematic of your board? Mysterious problems like this are often traceable to incorrect capacitors on the Vcap pin, or not enough bypass capacitors on the Vdd pins. |
我可以再说一遍:同样的PIC32MX575F512H,但是两年前买的作品都很好,这一切都是由相同的原理图制作的。样品是在马来西亚制造的。
以上来自于百度翻译 以下为原文 I can say more: the same PIC32MX575F512H, but have bought 2 years ago earlier works very well all this time made by the same schematic. The sample was made at Malaysia. |
只有小组成员才能发言,加入小组>>
4837 浏览 9 评论
1842 浏览 8 评论
1756 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2966 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2070 浏览 5 评论
467浏览 1评论
1120浏览 1评论
299浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
371浏览 0评论
268浏览 0评论
GMT+8, 2024-5-5 00:53 , Processed in 1.011056 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
