嗨,我正在创建一个Visual-C ++应用程序,它通过IVI-COM驱动程序接口自动化安捷伦电源。此应用程序旨在用于不同的位置,用户可能使用不同的Agilent电源模型。因此,我的应用程序应该
可以互换,因此用户可以选择他拥有的特定Agilent PS型号,并且特定的驱动程序将动态链接到我的应用程序。 我的用户将无法访问源代码,但只有一个关闭的可执行文件。阅读本文后:http://ivifoundation.org/downloads/IVI% ... 202011.pdf我注意到这可以通过 IVISessionFactory.I安装了IVI共享组件。但是,我似乎没有C: Program files IVI Foundation IVI Data下的任何内容,因为该文档声称它应该包含IviConfigurationStore.xml.Moreover,我不知道 看看我如何创建这个工厂的实例。 我很乐意得到一些C ++代码示例,展示这个以及有关IVISessionFactory以及如何将其绑定到特定工具的更多解释。谢谢,Hagai。 以上来自于谷歌翻译 以下为原文 Hi, I'm creating a Visual-C++ application which automating an Agilent Power Supply via IVI-COM driver interface. This application is intended to be used on different locations, where users might have different Agilent Power supplies models. Therefore, my application should be interchangeable so the user can choose the specific Agilent PS model he owns, And and the specific driver will be dynamically linked to my application. My users won't have any access to the source code but only having a close executable file. After reading this: http://ivifoundation.org/downloads/IVI% ... 202011.pdf I've noticed this could be achieved via IVISessionFactory. I have IVI Shared Components installed. However, I don't seem to have anything under C:Program filesIVI FoundationIVIData as the document claims it should contain the IviConfigurationStore.xml. Moreover, I don't see how can i create an instance of this factory. I will be happy to get some C++ code examples showing this and some more explanation about the IVISessionFactory and how to bind it to the specific instrument. Thanks in advance, Hagai. |
3个回答
嗨Hagai,我不知道我的头顶的答案,但我们正在研究它。
以上来自于谷歌翻译 以下为原文 Hi Hagai, I do not know the answer off the top of my head but we are looking into it. |
嗨,谢谢你的代码。你能解释一下我如何创建一个硬件资产和一个软件模块并将它链接到我用你的代码创建的逻辑名?目前这个代码在运行时在这行中失败了powerSupply
= sessionFactory-> CreateSession(“PowerSupply”);我想这是因为它没有链接到任何硬件/软件模块。谢谢,Hagai。 以上来自于谷歌翻译 以下为原文 Hi, thank you for this code. Can you please explain how do I create a Hardware Asset and a Software Module and link it to the logical name I've created using your code? At the moment this code fails at runtime in this line powerSupply = sessionFactory->CreateSession("PowerSupply"); I suppose this is because it does not linked to any hardware / software module. Thanks in advance, Hagai. |
附件是一个演示文稿,解释了IVI配置存储中必须设置的可互换性。对Config Store进行更改的最简单方法是使用NI的Config Store编辑器工具。
要安装该工具,请确保已安装NI-MAX,然后从http://www.ni.com下载并安装NI IVI合规性包。您将查看NI IVI帮助主题“概述 - 配置IVI仪器 使用MAX“。如果安装了MATLAB仪器控制工具箱,可以使用tmtool编辑IVI配置存储 以上来自于谷歌翻译 以下为原文 Attached is a presentation that explains what has to be setup in the IVI Config Store for interchangeability. The easiest way to make changes to the Config Store is using NI's Config Store editor tool. To install that tool, make sure you have NI-MAX installed, then download and install the NI IVI Compliance Package from http://www.ni.com You'll want to look at the NI IVI help topic "Overview-Configuring IVI Instruments Using MAX". If you have the MATLAB Instrument Control Toolbox installed, you can use tmtool to edit the IVI Config Store 附件 |
只有小组成员才能发言,加入小组>>
1854 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3475 浏览 3 评论
1854浏览 0评论
427浏览 0评论
/9
GMT+8, 2025-12-8 17:07 , Processed in 0.952775 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1954
