如果在Genesys中使用无源滤波器模板,则可以生成N = 3 - Cauer-Chebyshev,Equal - Full Transform集总元素滤波器。
最终的拓扑是在输入端并联LC与地并联,然后串联并联LC,串联另一个并联LC并在输出端并联LC接地。 输入和输出处的分流元件是对称的。 我其实想要这个网络的双重性。 在被动模板的最后,我认为没有任何方法可以要求双重模板。 我一直试图弄清楚如何使用S / Filter来实现这种拓扑。 我可以靠近,但我最终得到了过滤器中间的一个或多个元素,我无法摆脱它。 我可以使用无源滤波器输出并使用MathCAD计算双重输出,但它变得乏味。 有人可以带我完成S / Filter的步骤吗? 以上来自于谷歌翻译 以下为原文 If you use the passive filter template in Genesys you can generate an N = 3 - Cauer-Chebyshev, Equal - Full Transform lumped element filter. Final topology is parallel LC to ground at input, then a parallel LC in series, another parallel LC in series and parallel LC to ground at output. Shunt elements at input and output are symmetrical. I actually want the dual of this network. At the end of the passive template I don't think there is any way to ask for the dual. I have been trying to figure out how to get to this topology with S/Filter. I can get close, but I end up with one or more elements in the middle of the filter that I can't get rid of. I can take the passive filter output and compute the dual with MathCAD but it is getting tedious. Can someone walk me through the steps for S/Filter? |
2个回答
亲爱的D. G.-(我讨厌看到这里没有回复的帖子。)我没有S / filt,所以无法帮助你。
您使用的是什么版本? 如果您有支持,您应该通过电子邮件发送“门票”。 你擅长MATLAB吗? 如果是这样,您可以在“数学语言”中编写一个宏来自动完成Genesys内部的工作。 对不起,除此之外情不自禁。 标记 以上来自于谷歌翻译 以下为原文 Dear D. G.- (I hate to see unanswered posts here.) I don't have S/filt anymore, so can't help you there. What release are you using? If you are on support, you should email a 'ticket'. Are you pretty good at MATLAB? If so, you might could write a macro in "Math Language" to automate your job inside Genesys. Sorry, can't help beyond that. Mark |
滤波器模块使用查找值并完成简单设计,它不会为输入过程提供串行或分流。
在你的情况下,系列是inout。 s / filter模块也不会这样做,它是极点软件。 您需要做的是将s / filter作为参考低通,然后将简单的等式添加到工作空间,以将参考低通转换为带通。 希望这可以帮助。 以上来自于谷歌翻译 以下为原文 The filter module uses look up values and completes the simple design, it does not offer you the input process as being either series or shunt. Which in your case is series inout. The s/filter module will not do it either, it is a pole place software. What you need to do is run s/filter as the reference lowpass and then add the simple equations to the work space for converting the reference low pass to a bandpass. Hope this helps. |
只有小组成员才能发言,加入小组>>
2130 浏览 1 评论
1908 浏览 1 评论
1758 浏览 5 评论
2633 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1598 浏览 4 评论
576浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
489浏览 0评论
2296浏览 0评论
1343浏览 0评论
GMT+8, 2024-6-26 21:05 , Processed in 1.143498 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
