电子发烧友论坛|
嗨,我正在尝试在PIC32 USB启动器工具包II上运行一个引导加载程序。我使用的是和谐V106和XC32 V1.40。我使用的是基本的USB HID引导加载程序,并且我已经设置它在PIC32启动工具包II上运行,并带有管理配置。我可以构建程序并运行它,得到闪烁的LeD1。我在哪里可以找到真正通过USB编程的PC应用程序?我已经测试了:MyCHIPSIOSSORDSIV2013-0615USB设备-引导加载程序 HID软件Windows可执行文件HIDBooToLoBule.EXE,但它不能识别设备,我不知道如何继续。我已经阅读了大约20次OrthWork文档中的Bootloader部分,但是它没有解释如果这个应用程序不识别该设备该怎么做。我已经用这个开发工具包工作了一年,没有问题,现在我正在尝试引导引导程序运行。我丢失了。有没有链接/文档解释这个例子?最重要的是,我似乎找不到一个PC应用程序,实际上可以找到板,并列举它当它在启动模式。任何帮助都将非常感谢。谢谢…
以上来自于百度翻译 以下为原文 Hi, I'm trying to get a bootloader running on the PIC32 USB Starter Kit II running. I'm using HARMony v1_06 and XC32 v1.40. I'm using the basic USB HID bootloader and I've set it up to run on the PIC32 starter kit II with manage configurations. I can build the program and run it and get the blinking LED1. Where can I find the pc app that actually programs it via USB? I've tried C:microchip_solutions_v2013-06-15USBDevice - BootloadersHIDSoftware Windows ExecutableHIDBootLoader.exe but it won't recognize the device and I'm not sure how to proceed. I've read the bootloader section in the Harmony documentation about 20 times but it doesn't explain what to do if this app does not recognize the device. I've been working with this dev kit for a year with no issues and now that I'm trying to get a bootloader running I'm lost. Is there a link/document that explains this as an example? The big thing is I can't seem to find a pc application that actually can find the board and enumerate to it when it's in the boot mode. Any help would very much be appreciated. Thanks... |
4个回答
在和声帮助文档中有一些信息…转到DOC/HTML/NETX.html和ATP应用程序帮助和gt;引导加载程序演示。
以上来自于百度翻译 以下为原文 there are some information in the harmony help doc... go to the doc/html/index.html and at Applications Help > Bootloader Demonstrations > Demonstrations > basic > Running the Demonstration |
试试V1.10版本。它仍然应该使用V1.06目标。您需要更新它的链接器脚本。
以上来自于百度翻译 以下为原文 Try the v1.10 version. It should still work with a v1.06 target. You will need to update its linker script. |
嗨,BMART,请使用这个链接。app.=en554836下载“AN1388源代码”,解压缩并使用“AN1388源代码2014_02_14.exe”,谢谢
以上来自于百度翻译 以下为原文 HI bmartin, Please use this link. http://www.microchip.com/wwwAppNotes/AppNotes.aspx?appnote=en554836 download "AN1388 Source Code", unzip and use "AN1388 Source Code 2014_02_14.exe" Thanks |
谢谢你提供的所有信息。我很感激。好的,我已经安装了文件Atttp://www. McCHIP.COM/WavaPabeSe/AppNo.ASPX?AppNote:En583636i在MPLABX建立了项目,并用“Basic”引导程序对设备进行编程。当我把它连接到USB端口时,LeD1闪烁1秒的间隔。当我运行PIC32 UBL.EXE时,我选择0x04D8VID和0x03F PID(我用和声编程)。程序称它不存在。我已经尝试了这两个PC驱动通过切换MPLABX和MPLAB与切换器。同样的结果,将无法识别设备。我注意到设备管理器的VID/PID是0x04D8/0Xe0,所以我尝试了这两个驱动程序,仍然无法识别设备。我确信它是在Bootloader模式下,我不能让PC应用程序识别它。
以上来自于百度翻译 以下为原文 All, Thanks for all the information. I appreciate it. Ok I've installed the files at http://www.microchip.com/wwwAppNotes/AppNotes.aspx?appnote=en554836 I've built the project in MPLABX and programmed the device with the "basic" bootloader. When I connect it to the u*** port LED1 blinks at a 1sec interval. When I run PIC32UBL.exe I select 0x04d8 VID and 0x03f PID(what I programmed with Harmony). Program says it doesn't exist. I've tried this using both pc drivers by switching between MPLABX and MPLAB with the switcher. Same result, won't recognize the device. I noticed in Device Manager that the VID/PID was 0x04d8/0xE0 so I tried that with both drivers and still won't recognize the device. I'm confident that it's in bootloader mode I just can't get the pc app to recognize it. Any suggestions would be appreciated. Thanks |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 21:49 , Processed in 0.782336 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
987
