我正在运行ADVANCED DESIGN SYSTEM 2009.我在显示窗口中的图表会自动显示为GHz。
谁能告诉我如何将轴单位更改为MHz? 谢谢。 以上来自于谷歌翻译 以下为原文 I am running ADVANCED DESIGN SYSTEM 2009. My plots in the display window automatically show up in GHz. Can anyone tell me how to change the axis units to MHz? Thanks. |
9个回答
如果您正在运行S参数或其他模拟,则必须定义从100MHz到300MHz步进100KHz的扫描范围。
Axis自动缩放。 你不必做任何事情。 该图应仅基于模拟时间或扫描频率绘制数据。 如果你得到GHz是因为你没有定义扫描或频率扫描。 你是如何使用这个程序的? S参数? 发送您正在做的事情的屏幕截图。 以上来自于谷歌翻译 以下为原文 If you are running S-Parameter or other simulation, you have to define the sweep range from say 100MHz to 300MHz step 100KHz. The Axis gets scaled automatically by itself. You don't have to do anything. The plot should only plot data based on the simulation time or sweep frequency. If you are getting GHz is because your are not defining the sweep or frequency sweeps. How are you using this program? S-Parameters? Send a screen shot of what you are doing. |
我对我的帖子有一些看法。
1.似乎很多其他人对这个主题感兴趣,所以我认为他们可能在改变比例单位方面遇到同样的问题。 2.安捷伦的技术支持人员似乎也没有在论坛上回答问题。 如果他们这样做了,我相信他们会知道我的问题的答案,并且在这个帖子获得170次观看之前很久就会回答。 以上来自于谷歌翻译 以下为原文 I have some observations regarding my post. 1. It appears that many others are interested in this topic so I assume that they are possibly having the same problem I am with changing the scale units. 2. It also appears that the technical support people at Agilent do not answer questions on the forums. If they did, I am sure they would know the answer to my question and would have answered it long before this thread acquired 170 views. |
60user66 发表于 2019-5-9 15:44 嗨JSMill,我为任何误解道歉。 ADS论坛是一个点对点社区,旨在让您直接与世界各地成千上万的其他ADS用户进行交流。 ADS论坛不是联系Agilent EEsof技术支持的最佳或主要方式。 请访问http://edocs.soco.agilent.com/display/support/ADS+Support+Home,以访问ADS文档,培训材料和大量应用程序库,并寻求技术支持帮助。 我们试图在论坛的主页上明确这一点,但看起来我们还有更多的工作要做。 我会看看我是否可以从技术支持部门找到回复您问题的人。 Joe Civello ADS产品经理 以上来自于谷歌翻译 以下为原文 Hi JSMill, I apologize for any misunderstanding. The ADS Discussion Forum is a peer-to-peer community created to allow you to communicate directly with the thousands of other ADS users around the world. The ADS Discussion Forum is not the best or primary means to contact Agilent EEsof Technical Support. Please visit http://edocs.soco.agilent.com/display/support/ADS+Support+Home for access to ADS documentation, training materials, and extensive library of applications and to ask for technical support help. We've tried to make this clear on the forum's main page, but it looks like we still have more work to do. I'll see if I can get someone from Tech Support to respond to your question here. Joe Civello ADS Product Manager |
lksmcd 发表于 2019-5-9 15:57 乔,我很抱歉我对这个论坛的误解。 我显然没有仔细阅读信息页面并假设安捷伦技术支持将出现在本论坛上,因为它们出现在我参与的许多技术论坛上。我们的ADS软件支持许可证已过期,这就是原因 我没有直接与此问题联系Agilent / ADS技术支持。 我错误地认为,我可以在此论坛中获得安捷伦科技支持我们的ADS 2009软件,而无需支付我们的许可证支持。 我为这个误会道歉。 以上来自于谷歌翻译 以下为原文 Joe, I am sorry for my misunderstanding of this forum. I clearly did not read the information page carefully and made the assumption that Agilent technical support would be present on this forum as they are on many of the technical forums I participate in. Our support license for our ADS software has expired and that is the reason I have not contacted Agilent/ADS tech support directly with this question. It was my mistake to think that I could get Agilent Tech support for our ADS 2009 software in this forum without paying for the support with our license. I apologize for the misunderstanding. |
60user66 发表于 2019-5-9 16:08 JSMill,感谢您使用ADS。 当他们有时间时,应用工程师和技术支持工程师会在论坛中监控和回答问题。 我们通常优先考虑通过直接技术支持渠道进行的呼叫。 由于ADS用户社区规模如此之大且不断增长,我们在此创建了论坛,并在LinkedIn上创建了ADS用户组,希望用户也可以互相帮助。 Joe Civello ADS产品经理 以上来自于谷歌翻译 以下为原文 JSMill, Thanks for using ADS. When they have time, application engineers and tech support engineers do monitor and respond to questions in the forum. We typically give priority to the calls that come in through direct tech support channels. Since the ADS user community is so large and growing, we've created the forum here and the ADS User Group on LinkedIn, with the hope that users can also help each other. Joe Civello ADS Product Manager |
60user66 发表于 2019-5-9 15:44 嗨JSMill,目前根据数据的最小值和最大值自动设置绘图轴untis。 如果最小值和最大值在GHz范围内,则单位将自动设置为GHz。 如果值的最小值和最大值在MHz范围内,则轴上的单位将为MHz。 遗憾的是,此时无法覆盖此自动设置。 我们的系统中已经有一个增强请求,允许直接设置绘图的单位。 谢谢,Edwin Yeung安捷伦EEsof技术支持 以上来自于谷歌翻译 以下为原文 Hi JSMill, Currently the plot axis untis are set automatically based on the min and max values of the data. If the min and max are in the GHz range, the units will be set automatically to GHz. If the min and max of the values are in MHz range, the units on the axis will be MHz. Unfortunately there is not a way to override this automatic setting at this time. An enhancement request is already in our system to allow the units of a plot to be set directly. Thanks, Edwin Yeung Agilent EEsof technical support |
埃德温,感谢您抽出宝贵时间来解答我的问题。
您提到数据的最小值和最大值设置了绘图轴。 这对于s参数模拟输入是否正确? 如果你注意到上面我发布了一些模拟的截图。 我的s参数块以MHz为单位定义,步长为kHz。 然而,我的输出显示都是GHz(参见其他截图)。 是否有另一种方法可以设置以MHz为单位的最小值和最大值以使显示输出以MHz为单位? 我没有在正确的位置设置最小值和最大值吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Edwin, Thank you for taking the time to address my question. You mention that the min and max for the data set the plot axis. Is that true for an s-parameter simulation input? If you notice above I had posted some screenshots of my simulation. My s-parameter block is defined in MHz with the step in kHz. Yet, my output displays are all in GHz (see other screenshot). Is there another way to set min and max in MHz to have the display outputs in MHz? Am I not setting min and max in the correct location? Thanks. |
嗨JSMill,由于您的扫描范围在GHz范围内,因此您在S参数控制器中使用哪些单位来定义起始和终止频率并不重要。
数据显示程序将根据起始值和停止值设置绘图单位,在您的情况下,这些值在GHz范围内。 目前没有办法手动设置轴上的单位。 这就是我们系统中增强请求的原因。 埃德温 以上来自于谷歌翻译 以下为原文 Hi JSMill, Since your swept range is in the GHz range, it does not matter what units you used in the S-parameter controller to define the start and stop frequency. The data display program will set the units of plot based on the start and stop values, which in your case are in the GHz range. There is not a way currently to set the units on the axis manually. That is the reason for the enhancement request in our system. Edwin |
谢谢Edwin澄清这一点。
最近确实在这个帖子上有一系列活动(几天内超过100次观看)。 似乎有许多ADS用户对能够手动更改比例感兴趣。 以上来自于谷歌翻译 以下为原文 Thank you Edwin for clarifying that. There sure was a flurry of activity on this thread recently (over 100 views in a couple of days). It appears there are many ADS users who are interested in having the ability to change the scale manually. |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1853 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1410浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 05:28 , Processed in 1.076993 second(s), Total 81, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
