大家好,有人通过网络配置标签成功地改变IP地址吗?我必须补充一点:我的板上没有外部EEPROM或SPI闪存,所以我的IP地址的变化似乎没有保存,所以它总是保留默认IP。
以上来自于百度翻译 以下为原文 Hello every body Is there anyone that succeed to change IP address through network configuration tab? i have to add the point that: i do not have external eeprom or spi flash on my board so it seems that my changes on ip address is not saved so it always remains with default ip. |
5个回答
您好,您是指TCPIP配置文件吗?
以上来自于百度翻译 以下为原文 Hi, Are you referring to the TCPIP configuration files ? |
您是否尝试更改TCPIP CONFIG/TCPIP PIC32?YULY配置中的IP?定义了MyO.DeFultIpIdAdRyByTE1(192UL)定义MyO-DeultTypIdAdRuleByTE2(168UL)定义MyO-DeFultTypIdAdRyByTE3(0UL)定义MyO-DeultTyIpAdDRyByTE4(194UL),并注释了定义STACKYUSE.AutoIP的定义
以上来自于百度翻译 以下为原文 Have you tried changing the ip in TCPIP config/TCPIP PIC32_YOUR_CONFIGURATION.h ? Eg. #define MY_DEFAULT_IP_ADDR_BYTE1 (192ul) #define MY_DEFAULT_IP_ADDR_BYTE2 (168ul) #define MY_DEFAULT_IP_ADDR_BYTE3 (0ul) #define MY_DEFAULT_IP_ADDR_BYTE4 (194ul) and comment out #define STACK_USE_AUTO_IP |
是的,一切都可以,但我想改变我的IP添加从浏览器当你打开网页//IP添加你会看到网络配置点击的LF,从那里你可以改变你的IP和其他配置时,DHCP是不允许的。当我改变IP与新的一个,那么我不能连接到新的IP和AGAI。n和旧的一起工作
以上来自于百度翻译 以下为原文 yes all is ok but i want to change my ip add from browser when you open web page with //ip add you will see network configuration tap on the lef and from there you can change your ip and other configs when dhcp is disable. when i change ip with new one then i can not connect with the new ip and again it works with the old one |
你需要外部SPI闪存或EEPROM来完成。当IP地址改变时,PIC将重新启动。/ Ruben
以上来自于百度翻译 以下为原文 You need external SPI FLASH or EEPROM to do that. When the IP address is changed the PIC will restart. // All parsing complete! Save new settings and force a reboot SaveAppConfig(&newAppConfig); // Set the board to reboot and display reconnecting information strcpypgm2ram((char*)curHTTP.data, "/protect/reboot.htm?"); memcpy((void*)(curHTTP.data+20), (void*)newAppConfig.NetBIOSName, 16); curHTTP.data[20+16] = 0x00; // Force null termination /Ruben |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5794 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 13:48 , Processed in 0.976093 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1465
