你好,我的朋友们,我需要你们的帮助,我有一个“启动工具包PIC32 MZ”,用“4.3”WQVGA PCAP显示板,几乎所有的工作都很好。我开发了一个菜单系统,并且在一些屏幕上,当我把我的程序充电到我的启动套件中时,一些像按钮或静态文本或编辑文本之类的对象不会在D中画出。EVICE的屏幕,但在其他屏幕的同一个对象中,对象都画出了问题。我不知道为什么魔术的方式,对象不出现在屏幕上的设备。我使用和声1.0801,和MPLAB V.3.35.谢谢你的关注。
以上来自于百度翻译 以下为原文 Hello my friends, I need your help, I have a 'Starter Kit PIC32MZ', with '4.3" WQVGA PCAP Display Board', almost all work fine. I am develop a menu system, and in some screens, when I charge my program into my Starter kit some objects like as buttons or static text or edit text does not draw in the device's screen, but in others screen of the same proyect the objects are drawing with out problem. I dont know why of magic way the objects does not appear in the screen of the device. I use hARMony 1.08.01, and mplab v.3.35. Thanks for your attention. |
5个回答
您好,问题很可能是您的对象超过屏幕的边缘。剪辑是这个版本中的一个已知问题。尝试移动对象,使它们完全在屏幕内。我的建议是移到最新版本的和声V2.02B。在这个版本中,图形库和工具是全新的,并且像剪辑之类的东西可以从你所拥有的版本中解决。请注意,除了在MHC插件版本之间移动之外,还可以同时加载2个版本的和声。所以,如果你想尝试更近的版本,那么你可能已经失去了什么。
以上来自于百度翻译 以下为原文 Hello, The problem is most likely that your objects exceed the edges of the screen. Clipping is a known issue in this version. Try either moving the objects so they are entirely within the screen. My advice is to move to the latest version of Harmony v2.02b. In this version the graphics library and tools are entirely new, and things like clipping are resolved from the version that you have. If you are just trying things out, be aware that other than moving between MHC plug in versions, it is possible to have 2 versions of Harmony loaded at the same time. So nothing that you may have done is lost if you want to experiment with more recent versions. |
谢谢,我知道你说我,问题不在屏幕的边缘。我修改了,我删除了其他对象,出现了当我减少我的屏幕对象数量时没有出现的对象,我只能把13个对象放在一个屏幕上,但是我只放了14个对象。在其他屏幕上,我可以放置更多的对象,换句话说,它不遵循任何逻辑。在这一刻,我安装MPLAB 3.51,我将探索和谐1.10和2.02b……我会说什么发生得太早,
以上来自于百度翻译 以下为原文 Thanks, I probe that you said me, and the problem is not with the edge of the screen. I modified, and I deleted other objects, and appear the objects that did not appear when I reduce de number of objects of my screen, I only can put 13 objects in one screen but into other screen I only put 14 objects and into others screens I can put much more objects, in other words Its does no follow any logic. In this moment I am installing mplab 3.51, and I am going to probe with harmony 1.10 and 2.02b.... I will say what happen too early,,,, |
可能会有很多问题。是否设置绘制状态?大约13,大约14。你的堆够大了吗?1.10和2.02b具有完全不同的图形库。
以上来自于百度翻译 以下为原文 There can be a lot of issues. Are you setting the DRAW state? some 13, some 14. Is your Heap big enough? 1.10 and 2.02b have total different graphics libraries. |
http://066W-D6G66VFU2VxTGZ5RL9JZ0E/VIEWHTTPS://DRIVE.GoGoLe.COM/FIL/D/0B6W-DHDG6VFWK1YD2DVD0VQWEK/VIEW
以上来自于百度翻译 以下为原文 https://drive.google.com/file/d/0B6W-DHdgr6vFU2VXTGZ5Rl9JZ0E/view https://drive.google.com/file/d/0B6W-DHdgr6vFWk1Yd2dVd0VQWEk/view |
可以将堆大小设置为和谐。在MHC的底部都是这样。
以上来自于百度翻译 以下为原文 You can set the heap size in harmony. It is all the way at the bottom in MHC. |
只有小组成员才能发言,加入小组>>
5198 浏览 9 评论
2016 浏览 8 评论
1940 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3188 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2243 浏览 5 评论
753浏览 1评论
639浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
526浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
650浏览 0评论
552浏览 0评论
GMT+8, 2024-12-3 05:21 , Processed in 1.414657 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
