你好,我最近得到了一张标有“infiniium示波器的扩展触发”的软盘,部分#54810-17632我似乎无法找到任何关于此的信息。
它是一个启动软盘,应该安装该选项,我在54825A上启动它并允许它安装它成功。 但我在触发菜单中找不到任何更改,并且帮助,关于选项卡不显示已安装选项。 有没有人有关于此选项的任何信息? 谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I recently got my hands on a floppy disk that's labeled "Extended triggering for infiniium oscilloscopes" Part # 54810-17632 I can't seem to find any information on this at all. It is a boot floppy that supposedly installs the option, I booted it on a 54825A and allowed it to install which it did successfully. But I cannot find any changes in the triggering menu, and the help, about tab does not show the option is installed. Does anyone have any information on this option? Thanks! |
4个回答
提出问题,然后你就可以自己找到它。
显然它可以启用欠幅触发,但我已经具备了这种能力,所以也许后来的软件版本免费赠送它。 这个范围有版本4.50,我认为是最新发布的版本。 以上来自于谷歌翻译 以下为原文 Ask a question, then you manage to find it on your own. Apparently it enables runt triggering, but I already had that capability, so maybe the later software versions gave it away for free. This scope has version 4.50 which I think is the last version that was released. |
嗨周杰伦,我的54832B(软件版本5.71 - 最新版本)在触发菜单下没有作为选项触发,虽然它确实有很多其他高级触发选项,例如建立和保持违规,模式,故障
当我搜索示波器的帮助部分时,它说可以通过软件选件N5414A或N5415A启用欠幅触发。 尽管如此,我还是找不到有关这些选项的信息,这些选项可用于54800系列示波器。 它们的唯一参考是针对8000/80000和9000/90000示波器。 你在哪里找到那个软件盘? 如果有更多可用的话,我想尝试一下我的范围! 此致,斯坦 以上来自于谷歌翻译 以下为原文 Hi Jay, My 54832B (software version 5.71--the latest version) does not have runt triggering as an option under the triggering menu, although it did have a lot of other advanced triggering options, such as setup and hold violations, pattern, glitch, etc. When I searched the scope's help section, it said that runt triggering could be enabled by software option N5414A or N5415A. In spite of that, I can find no information about either of these options ever having been available for the 54800-series scopes. The only references for them are for the 8000/80000 and 9000/90000 scopes. Where did you find that software disk? If there are any more available, I'd like to give it a try on my scope! Regards, Stan |
daichuangs 发表于 2019-4-30 12:22 54832和54855示波器非常不同。 安捷伦示波器在一段时间内具有HW欠幅触发功能,由许可证启用,但存在某种专利问题,因此他们几代人都没有。 目前的范围再次具备了这些功能,还有更多功能。 我知道,在54832示波器上启用欠幅触发是没有办法的。 它不在HW中。 人 以上来自于谷歌翻译 以下为原文 The 54832 and 54855 scopes were very different. Agilent scopes had HW runt triggering capabilities for a while, enabled by a license, but there was some sort of patent issue, so they didn't have it for a few generations. The current scopes have the capabilities once again, along with a whole lot more. There's no way, that I'm aware of, to enable runt triggering on a 54832 scope. It's just not in the HW. Al |
daichuangs 发表于 2019-4-30 12:22 嗨Stan,我在这里找到了对选项015的引用:http://www.mrtestequipment.com/getfile.php?s = Agilent +54845A + Infiniim + Oscilloscope + Data + Sheet.pdf它不适用于你的范围 主持人声明的原因,以及这是一个修改Windows 98操作系统上的注册表的启动盘的事实。 磁盘附带了我购买的54825A。 以上来自于谷歌翻译 以下为原文 Hi Stan, I found the reference to option 015 here: http://www.mrtestequipment.com/getfile.php?s=Agilent+54845A+Infiniim+Oscilloscope+Data+Sheet.pdf It would not work on your scope for the reasons that the moderators have stated, and the fact that this is a boot disk that modifies the registry on a Windows 98 OS. The disk came with a 54825A I purchased. |
只有小组成员才能发言,加入小组>>
1272 浏览 0 评论
2371 浏览 1 评论
2187 浏览 1 评论
2061 浏览 5 评论
2944 浏览 3 评论
1090浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
746浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
911浏览 0评论
1276浏览 0评论
GMT+8, 2024-12-19 22:37 , Processed in 1.341098 second(s), Total 54, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
